Orin spi transfer time longgr than expected
Hi nvidia team:
we are using SPI coummunication.
but find SPI transfer time not instability.
below I have a test on Orin devkit.and print the time.
every time send 2116 byte.and delay 10ms
in theory ,when transfer 2116 byte. time should be 1.69ms [2116(byte) x 8(bit) x1000(ms) /10000000(HZ)]
1: --timeout[0] 0 s 033 671497 ns
1 is the test count .
timeout is the longer than 10ms num.
033 671497 ns is the actual time.
root@tegra-ubuntu:/home/file# ./spitest -f1.txt  -t10
open device /dev/spidev2.0
spi string : SPI (fd=3, mode=1, max_speed=10 M , bit_order=MSB first, bits_per_word=8, extra_flags=00)
1: --timeout[0] 0 s 004 157527 ns
2: --timeout[0] 0 s 003 023231 ns
3: --timeout[0] 0 s 012 357072 ns
4: --timeout[1] 0 s 002 311096 ns
5: --timeout[1] 0 s 014 651524 ns
6: --timeout[2] 0 s 014 274781 ns
7: --timeout[3] 0 s 003 604366 ns
8: --timeout[3] 0 s 002 421773 ns
9: --timeout[3] 0 s 013 899126 ns
10: --timeout[4] 0 s 004 358461 ns
11: --timeout[4] 0 s 002 423053 ns
12: --timeout[4] 0 s 014 413720 ns
13: --timeout[5] 0 s 004 107790 ns
14: --timeout[5] 0 s 002 430190 ns
15: --timeout[5] 0 s 013 588282 ns
16: --timeout[6] 0 s 013 692366 ns
17: --timeout[7] 0 s 014 639234 ns
18: --timeout[8] 0 s 003 702272 ns
19: --timeout[8] 0 s 002 822906 ns
20: --timeout[8] 0 s 013 592955 ns
21: --timeout[9] 0 s 013 361231 ns
22: --timeout[10] 0 s 004 099916 ns
23: --timeout[10] 0 s 002 075435 ns
24: --timeout[10] 0 s 004 750376 ns
25: --timeout[10] 0 s 002 788434 ns
26: --timeout[10] 0 s 004 387491 ns
27: --timeout[10] 0 s 002 421581 ns
28: --timeout[10] 0 s 004 794864 ns
29: --timeout[10] 0 s 002 034628 ns
30: --timeout[10] 0 s 014 176842 ns
31: --timeout[11] 0 s 014 026190 ns
32: --timeout[12] 0 s 013 677100 ns
33: --timeout[13] 0 s 013 771965 ns
34: --timeout[14] 0 s 014 030959 ns
35: --timeout[15] 0 s 013 743896 ns
36: --timeout[16] 0 s 013 378835 ns
37: --timeout[17] 0 s 013 481094 ns
38: --timeout[18] 0 s 014 094651 ns
39: --timeout[19] 0 s 014 296513 ns
40: --timeout[20] 0 s 003 895270 ns
41: --timeout[20] 0 s 002 628052 ns
42: --timeout[20] 0 s 014 086137 ns
43: --timeout[21] 0 s 013 807396 ns
44: --timeout[22] 0 s 013 938365 ns
45: --timeout[23] 0 s 003 842524 ns
46: --timeout[23] 0 s 002 034372 ns
47: --timeout[23] 0 s 005 401092 ns
48: --timeout[23] 0 s 002 185921 ns
49: --timeout[23] 0 s 002 534306 ns
50: --timeout[23] 0 s 002 409899 ns
51: --timeout[23] 0 s 004 408615 ns
52: --timeout[23] 0 s 013 971428 ns
53: --timeout[24] 0 s 003 588235 ns
54: --timeout[24] 0 s 002 443057 ns
55: --timeout[24] 0 s 013 869840 ns
56: --timeout[25] 0 s 003 750250 ns
57: --timeout[25] 0 s 002 213829 ns
58: --timeout[25] 0 s 013 919577 ns
59: --timeout[26] 0 s 004 472084 ns
60: --timeout[26] 0 s 002 298613 ns
61: --timeout[26] 0 s 014 191533 ns
62: --timeout[27] 0 s 013 954976 ns
63: --timeout[28] 0 s 004 540192 ns
64: --timeout[28] 0 s 002 319450 ns
65: --timeout[28] 0 s 013 697871 ns
66: --timeout[29] 0 s 004 590089 ns
67: --timeout[29] 0 s 002 030371 ns
68: --timeout[29] 0 s 003 927371 ns
69: --timeout[29] 0 s 002 210053 ns
70: --timeout[29] 0 s 003 816726 ns
71: --timeout[29] 0 s 002 244587 ns
72: --timeout[29] 0 s 003 683581 ns
73: --timeout[29] 0 s 002 221223 ns
74: --timeout[29] 0 s 004 210401 ns
75: --timeout[29] 0 s 002 164156 ns
76: --timeout[29] 0 s 014 062740 ns
77: --timeout[30] 0 s 004 274573 ns
78: --timeout[30] 0 s 002 419532 ns
79: --timeout[30] 0 s 014 307524 ns
80: --timeout[31] 0 s 013 453441 ns
81: --timeout[32] 0 s 004 180316 ns
82: --timeout[32] 0 s 002 076907 ns
83: --timeout[32] 0 s 003 516382 ns
84: --timeout[32] 0 s 002 407466 ns
85: --timeout[32] 0 s 014 480644 ns
86: --timeout[33] 0 s 013 426780 ns
87: --timeout[34] 0 s 014 012395 ns
88: --timeout[35] 0 s 003 306837 ns
89: --timeout[35] 0 s 002 136695 ns
90: --timeout[35] 0 s 012 941280 ns
91: --timeout[36] 0 s 003 464276 ns
92: --timeout[36] 0 s 002 124180 ns
93: --timeout[36] 0 s 014 351308 ns
94: --timeout[37] 0 s 013 199856 ns
95: --timeout[38] 0 s 013 459362 ns
96: --timeout[39] 0 s 003 844315 ns
97: --timeout[39] 0 s 002 017824 ns
98: --timeout[39] 0 s 004 029183 ns
99: --timeout[39] 0 s 002 170974 ns
100: --timeout[39] 0 s 003 759468 ns
101: --timeout[39] 0 s 002 415404 ns
102: --timeout[39] 0 s 014 654341 ns
103: --timeout[40] 0 s 013 387956 ns
104: --timeout[41] 0 s 016 393072 ns
105: --timeout[42] 0 s 013 362159 ns
106: --timeout[43] 0 s 004 513307 ns
107: --timeout[43] 0 s 005 872093 ns
108: --timeout[43] 0 s 013 655335 ns
109: --timeout[44] 0 s 013 735223 ns
110: --timeout[45] 0 s 013 799138 ns
111: --timeout[46] 0 s 004 695966 ns
112: --timeout[46] 0 s 002 703171 ns
113: --timeout[46] 0 s 003 704705 ns
114: --timeout[46] 0 s 002 811351 ns
115: --timeout[46] 0 s 013 621441 ns
116: --timeout[47] 0 s 003 948304 ns
117: --timeout[47] 0 s 012 322377 ns
118: --timeout[48] 0 s 012 269887 ns
119: --timeout[49] 0 s 002 379941 ns
120: --timeout[49] 0 s 003 846684 ns
121: --timeout[49] 0 s 002 281202 ns
122: --timeout[49] 0 s 013 710065 ns
123: --timeout[50] 0 s 003 885763 ns
124: --timeout[50] 0 s 002 050950 ns
125: --timeout[50] 0 s 003 529728 ns
126: --timeout[50] 0 s 002 420748 ns
127: --timeout[50] 0 s 004 972307 ns
128: --timeout[50] 0 s 002 270544 ns
129: --timeout[50] 0 s 003 436014 ns
130: --timeout[50] 0 s 002 219271 ns
131: --timeout[50] 0 s 004 172954 ns
132: --timeout[50] 0 s 002 034083 ns
133: --timeout[50] 0 s 013 582170 ns
134: --timeout[51] 0 s 014 310884 ns
135: --timeout[52] 0 s 013 662825 ns
136: --timeout[53] 0 s 014 391283 ns
137: --timeout[54] 0 s 013 427772 ns
138: --timeout[55] 0 s 004 733093 ns
139: --timeout[55] 0 s 002 026145 ns
140: --timeout[55] 0 s 013 708338 ns
141: --timeout[56] 0 s 014 179467 ns
142: --timeout[57] 0 s 003 597420 ns
143: --timeout[57] 0 s 002 791795 ns
144: --timeout[57] 0 s 003 548612 ns
145: --timeout[57] 0 s 002 029027 ns
146: --timeout[57] 0 s 003 712227 ns
147: --timeout[57] 0 s 002 221639 ns
148: --timeout[57] 0 s 013 914681 ns
149: --timeout[58] 0 s 013 887027 ns
150: --timeout[59] 0 s 013 848108 ns
151: --timeout[60] 0 s 013 959457 ns
152: --timeout[61] 0 s 003 882691 ns
153: --timeout[61] 0 s 002 055207 ns
154: --timeout[61] 0 s 013 773213 ns
155: --timeout[62] 0 s 013 771293 ns
156: --timeout[63] 0 s 004 594570 ns
157: --timeout[63] 0 s 002 223559 ns
158: --timeout[63] 0 s 004 441613 ns
159: --timeout[63] 0 s 002 278514 ns
160: --timeout[63] 0 s 004 383714 ns
161: --timeout[63] 0 s 002 432047 ns
162: --timeout[63] 0 s 014 215249 ns
163: --timeout[64] 0 s 013 763068 ns
164: --timeout[65] 0 s 014 197359 ns
165: --timeout[66] 0 s 003 535424 ns
166: --timeout[66] 0 s 002 375813 ns
167: --timeout[66] 0 s 003 931597 ns
168: --timeout[66] 0 s 002 018496 ns
169: --timeout[66] 0 s 004 684731 ns
170: --timeout[66] 0 s 002 419373 ns
171: --timeout[66] 0 s 014 181707 ns
172: --timeout[67] 0 s 013 669161 ns
173: --timeout[68] 0 s 005 421864 ns
174: --timeout[68] 0 s 002 320922 ns
175: --timeout[68] 0 s 015 675176 ns
176: --timeout[69] 0 s 003 956849 ns
177: --timeout[69] 0 s 002 089870 ns
178: --timeout[69] 0 s 014 519564 ns
179: --timeout[70] 0 s 013 887508 ns
180: --timeout[71] 0 s 003 819479 ns
181: --timeout[71] 0 s 012 376596 ns
182: --timeout[72] 0 s 002 215942 ns
183: --timeout[72] 0 s 004 431819 ns
184: --timeout[72] 0 s 002 166684 ns
185: --timeout[72] 0 s 004 650773 ns
186: --timeout[72] 0 s 002 123060 ns
187: --timeout[72] 0 s 014 471138 ns
188: --timeout[73] 0 s 003 364064 ns
189: --timeout[73] 0 s 012 573497 ns
190: --timeout[74] 0 s 002 201475 ns
191: --timeout[74] 0 s 004 896996 ns
192: --timeout[74] 0 s 002 618259 ns
193: --timeout[74] 0 s 014 392884 ns
194: --timeout[75] 0 s 013 592860 ns
195: --timeout[76] 0 s 004 608621 ns
196: --timeout[76] 0 s 002 267248 ns
197: --timeout[76] 0 s 014 166441 ns
198: --timeout[77] 0 s 003 802452 ns
199: --timeout[77] 0 s 002 305783 ns
200: --timeout[77] 0 s 013 815045 ns
201: --timeout[78] 0 s 013 987815 ns
202: --timeout[79] 0 s 013 853996 ns
203: --timeout[80] 0 s 014 028558 ns
204: --timeout[81] 0 s 003 600045 ns
205: --timeout[81] 0 s 002 520416 ns
206: --timeout[81] 0 s 003 807349 ns
207: --timeout[81] 0 s 002 006942 ns
208: --timeout[81] 0 s 004 700478 ns
209: --timeout[81] 0 s 002 969301 ns
210: --timeout[81] 0 s 013 710385 ns
211: --timeout[82] 0 s 004 192062 ns
212: --timeout[82] 0 s 002 984280 ns
213: --timeout[82] 0 s 004 177563 ns
214: --timeout[82] 0 s 002 028098 ns
215: --timeout[82] 0 s 013 705648 ns
216: --timeout[83] 0 s 014 493414 ns
217: --timeout[84] 0 s 013 395222 ns
218: --timeout[85] 0 s 013 862671 ns
219: --timeout[86] 0 s 014 945405 ns
220: --timeout[87] 0 s 014 505833 ns
221: --timeout[88] 0 s 002 974870 ns
222: --timeout[88] 0 s 002 431151 ns
223: --timeout[88] 0 s 014 238038 ns
224: --timeout[89] 0 s 004 063013 ns
225: --timeout[89] 0 s 002 221831 ns
226: --timeout[89] 0 s 014 385170 ns
227: --timeout[90] 0 s 013 381491 ns
228: --timeout[91] 0 s 004 781806 ns
229: --timeout[91] 0 s 002 646456 ns
230: --timeout[91] 0 s 014 603195 ns
231: --timeout[92] 0 s 014 039728 ns
232: --timeout[93] 0 s 014 569397 ns
233: --timeout[94] 0 s 014 129090 ns
234: --timeout[95] 0 s 013 213971 ns
235: --timeout[96] 0 s 014 169129 ns
236: --timeout[97] 0 s 013 795618 ns
237: --timeout[98] 0 s 013 598172 ns
238: --timeout[99] 0 s 003 961842 ns
239: --timeout[99] 0 s 002 212870 ns
240: --timeout[99] 0 s 004 008411 ns
241: --timeout[99] 0 s 002 013631 ns
242: --timeout[99] 0 s 003 682525 ns
243: --timeout[99] 0 s 002 172862 ns
244: --timeout[99] 0 s 014 096539 ns
245: --timeout[100] 0 s 013 825416 ns
246: --timeout[101] 0 s 013 779646 ns
247: --timeout[102] 0 s 013 788448 ns
248: --timeout[103] 0 s 013 939869 ns
249: --timeout[104] 0 s 013 710962 ns
250: --timeout[105] 0 s 003 795795 ns
251: --timeout[105] 0 s 002 045766 ns
252: --timeout[105] 0 s 003 681436 ns
253: --timeout[105] 0 s 012 624003 ns
254: --timeout[106] 0 s 002 251244 ns
255: --timeout[106] 0 s 013 900630 ns
256: --timeout[107] 0 s 003 871553 ns
257: --timeout[107] 0 s 002 013344 ns
258: --timeout[107] 0 s 004 264459 ns
259: --timeout[107] 0 s 010 933537 ns
260: --timeout[107] 0 s 002 756557 ns
261: --timeout[107] 0 s 014 240279 ns
262: --timeout[108] 0 s 004 046082 ns
263: --timeout[108] 0 s 002 019040 ns
264: --timeout[108] 0 s 003 656760 ns
265: --timeout[108] 0 s 012 297092 ns
266: --timeout[109] 0 s 002 399369 ns
267: --timeout[109] 0 s 014 234005 ns
268: --timeout[110] 0 s 004 044706 ns
269: --timeout[110] 0 s 001 970935 ns
270: --timeout[110] 0 s 003 353118 ns
271: --timeout[110] 0 s 002 434351 ns
272: --timeout[110] 0 s 014 812772 ns
273: --timeout[111] 0 s 013 850188 ns
274: --timeout[112] 0 s 014 494951 ns
275: --timeout[113] 0 s 013 706480 ns
276: --timeout[114] 0 s 013 980677 ns
277: --timeout[115] 0 s 003 410537 ns
278: --timeout[115] 0 s 002 158106 ns
279: --timeout[115] 0 s 013 796450 ns
280: --timeout[116] 0 s 003 528191 ns
281: --timeout[116] 0 s 002 377925 ns
282: --timeout[116] 0 s 013 858446 ns
283: --timeout[117] 0 s 013 567606 ns
284: --timeout[118] 0 s 014 393140 ns
285: --timeout[119] 0 s 004 624080 ns
286: --timeout[119] 0 s 002 264207 ns
287: --timeout[119] 0 s 004 187741 ns
288: --timeout[119] 0 s 002 231689 ns
289: --timeout[119] 0 s 013 777247 ns
290: --timeout[120] 0 s 004 511579 ns
291: --timeout[120] 0 s 002 329915 ns
292: --timeout[120] 0 s 013 562197 ns
293: --timeout[121] 0 s 013 767581 ns
294: --timeout[122] 0 s 014 784222 ns
295: --timeout[123] 0 s 014 348011 ns
296: --timeout[124] 0 s 014 066870 ns
297: --timeout[125] 0 s 013 823047 ns
298: --timeout[126] 0 s 013 654406 ns
299: --timeout[127] 0 s 013 989831 ns
300: --timeout[128] 0 s 004 080744 ns
301: --timeout[128] 0 s 002 431791 ns
302: --timeout[128] 0 s 003 743240 ns
303: --timeout[128] 0 s 002 242762 ns
304: --timeout[128] 0 s 013 633219 ns
305: --timeout[129] 0 s 014 365390 ns
306: --timeout[130] 0 s 013 698544 ns
307: --timeout[131] 0 s 013 931739 ns
308: --timeout[132] 0 s 003 378947 ns
309: --timeout[132] 0 s 002 155066 ns
310: --timeout[132] 0 s 004 178844 ns
311: --timeout[132] 0 s 002 029059 ns
312: --timeout[132] 0 s 003 646486 ns
313: --timeout[132] 0 s 002 197922 ns
314: --timeout[132] 0 s 015 128192 ns
315: --timeout[133] 0 s 003 072393 ns
316: --timeout[133] 0 s 002 231401 ns
317: --timeout[133] 0 s 003 930796 ns
318: --timeout[133] 0 s 002 025698 ns
319: --timeout[133] 0 s 013 465443 ns
320: --timeout[134] 0 s 003 848540 ns
321: --timeout[134] 0 s 002 093422 ns
322: --timeout[134] 0 s 003 730566 ns
323: --timeout[134] 0 s 002 172317 ns
324: --timeout[134] 0 s 003 896870 ns
325: --timeout[134] 0 s 002 024321 ns
326: --timeout[134] 0 s 013 590363 ns
327: --timeout[135] 0 s 013 599132 ns
328: --timeout[136] 0 s 014 183659 ns
329: --timeout[137] 0 s 014 160807 ns
330: --timeout[138] 0 s 014 045810 ns
331: --timeout[139] 0 s 014 069750 ns
332: --timeout[140] 0 s 004 323191 ns
333: --timeout[140] 0 s 002 184000 ns
334: --timeout[140] 0 s 003 967891 ns
335: --timeout[140] 0 s 002 020993 ns
336: --timeout[140] 0 s 003 456498 ns
337: --timeout[140] 0 s 002 187520 ns
338: --timeout[140] 0 s 004 013596 ns
339: --timeout[140] 0 s 002 015072 ns
340: --timeout[140] 0 s 013 606846 ns
341: --timeout[141] 0 s 013 987174 ns
342: --timeout[142] 0 s 004 580520 ns
343: --timeout[142] 0 s 002 182208 ns
344: --timeout[142] 0 s 004 175035 ns
345: --timeout[142] 0 s 002 035812 ns
346: --timeout[142] 0 s 003 792114 ns
347: --timeout[142] 0 s 002 192513 ns
348: --timeout[142] 0 s 004 123345 ns
349: --timeout[142] 0 s 001 986554 ns
350: --timeout[142] 0 s 004 709057 ns
351: --timeout[142] 0 s 002 422893 ns
352: --timeout[142] 0 s 003 807221 ns
353: --timeout[142] 0 s 002 010143 ns
354: --timeout[142] 0 s 003 692223 ns
355: --timeout[142] 0 s 002 184800 ns
356: --timeout[142] 0 s 004 020734 ns
357: --timeout[142] 0 s 002 031459 ns
358: --timeout[142] 0 s 013 713042 ns
359: --timeout[143] 0 s 003 966899 ns
360: --timeout[143] 0 s 002 073931 ns
361: --timeout[143] 0 s 004 000249 ns
362: --timeout[143] 0 s 002 187681 ns
363: --timeout[143] 0 s 013 641349 ns
364: --timeout[144] 0 s 014 685868 ns
365: --timeout[145] 0 s 003 778671 ns
366: --timeout[145] 0 s 002 195266 ns
367: --timeout[145] 0 s 004 454480 ns
368: --timeout[145] 0 s 002 010462 ns
369: --timeout[145] 0 s 003 554660 ns
370: --timeout[145] 0 s 002 164028 ns
371: --timeout[145] 0 s 014 158055 ns
I wanto ask why every transfer is not stable and have some gaps?
Do yo use Jetpack 5.1? If you use 5.0.2, please upgrade and try again.
hi DaneLLL:
we use Jetpack 5.1.
cs low time is 1.7ms, is the actual time. the next transfer no delay in my code , but every time is not conformity.
Do yo hit the issue in SPI1?
hi DaneLLL
what issue?
Would like to know if you use SPI1 and observe the issue that every transfer is not stable.
hi daneLLL:
yes. use orin devkit.
On Orin developer kit, it is SPI1 in the 40-pin expansion header and it should be /dev/spidev0.0. Looks like you are testing /dev/spidev2.0. Could you check if there is anything wrong in the setup? You can enable SPI1 through jetson-io.py for testing.
Hi DaneLLL:
sorry for later reply, the picture is err.I use /dev/spidev0.0,and take a test.when connect a monitor through pd line,the time out much less.
