I am working with Jetson AGX Orin 32g with JetPack 6.0, and SDK version is 36.3.0.
I find that if I sending large amounts of data to c260000.spi, the spi driver crashed. But if I send just a few bytes, it works fine.
Here is the kernel crash log:
[ 103.606163] slb9670@0 enforce active low on chipselect handle
[ 103.606205] spi@1 enforce active low on chipselect handle
[ 155.935999] ------------[ cut here ]------------
[ 155.936011] WARNING: CPU: 6 PID: 2960 at drivers/spi/spi-tegra114.c:1104 tegra_spi_transfer_one_message+0x514/0x634 [spi_tegra114]
[ 155.936041] Modules linked in: spi_tegra114 nvidia_modeset(OE) lzo_rle lzo_compress snd_soc_tegra210_mvc(O) snd_soc_tegra210_ope(O) snd_soc_tegra210_admaif(O) snd_soc_tegra210_mixer(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_afc(O) snd_soc_tegra_pcm snd_soc_tegra186_asrc(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_dmic(O) zram snd_soc_tegra210_sfc(O) snd_soc_tegra210_i2s(O) zsmalloc snd_soc_tegra210_adx(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_ahub(O) tegra210_adma tpm_tis_spi tpm_tis_core spidev nvvrs_pseq_rtc(O) joydev snd_soc_tegra_machine_driver(O) crct10dif_ce snd_soc_tegra_utils(O) snd_soc_simple_card_utils tegra234_oc_event(O) tegra23x_perf_uncore(O) mttcan(O) can_dev nvpmodel_clk_cap(O) tegra_mce(O) thermal_trip_event(O) tegra_cactmon_mc_all(O) tegra_aconnect tegra234_aon(O) ramoops reed_solomon snd_hda_codec_hdmi pwm_tegra_tachometer(O) at24 snd_hda_tegra snd_hda_codec snd_hda_core mc_hwpm(O) nvethernet(O) tegra_pcie_dma_test(O) nvpps(O) tegra_pcie_edma(O) nvidia(O)
[ 155.936143] host1x_fence(O) lm90 i2c_nvvrs11(O) nvidia_vrs_pseq(O) tegra_dce(O) rfkill nvhost_isp5(O) nvhost_vi5(O) nvhost_nvcsi_t194(O) bridge stp llc usb_f_ncm usb_f_mass_storage tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) usb_f_acm u_serial usb_f_rndis tegra_camera_rtcpu(O) u_ether ivc_bus(O) hsp_mailbox_client(O) libcomposite ivc_ext(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops governor_userspace videobuf2_v4l2 videobuf2_common videodev tegra_drm(O) nvhost_pva(O) nvhost_nvdla(O) tegra_wmark(O) mc tegra_se(O) nvhost_capture(O) crypto_engine nvhwpm(O) cec host1x_nvhost(O) tsecriscv(O) drm_kms_helper nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) fuse drm ip_tables x_tables ipv6 pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E) nvme_core(E) phy_tegra194_p2u(E) pcie_tegra194(E) [last unloaded: spi_tegra114]
[ 155.936256] CPU: 6 PID: 2960 Comm: python3 Tainted: G W OE 5.15.136-tegra #1
[ 155.936262] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36106755 04/25/2024
[ 155.936265] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 155.936270] pc : tegra_spi_transfer_one_message+0x514/0x634 [spi_tegra114]
[ 155.936276] lr : tegra_spi_transfer_one_message+0x1f8/0x634 [spi_tegra114]
[ 155.936281] sp : ffff800018c3bac0
[ 155.936283] x29: ffff800018c3bac0 x28: ffff0000b7fb1e00 x27: 0000000040400007
[ 155.936289] x26: ffff0000b7fb1e00 x25: ffff0000ea55c000 x24: 000000000007a120
[ 155.936293] x23: ffff0000b7fb1e00 x22: 00000000000003e8 x21: ffff0000b7fb1ee8
[ 155.936297] x20: ffff800018c3bd00 x19: ffff0000c15d1000 x18: 0000000000000000
[ 155.936302] x17: 000000040044ffff x16: 005000f5b5503510 x15: 0000000000000000
[ 155.936306] x14: 0000000000000000 x13: 0000000000000020 x12: 0101010101010101
[ 155.936311] x11: 7f7f7f7f7f7f7f7f x10: baf59b6e7fd92d3d x9 : 2e40b47ea6bd06e5
[ 155.936315] x8 : ffff0000ea7d4d58 x7 : 0000000000000006 x6 : 0000000000000000
[ 155.936318] x5 : 00000000410fd420 x4 : 0000000000c0000e x3 : 0000000000000000
[ 155.936322] x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000000
[ 155.936325] Call trace:
[ 155.936327] tegra_spi_transfer_one_message+0x514/0x634 [spi_tegra114]
[ 155.936330] __spi_pump_messages+0x384/0x7f0
[ 155.936343] __spi_sync+0x2d0/0x310
[ 155.936347] spi_sync+0x3c/0x60
[ 155.936350] spidev_message+0x390/0x520 [spidev]
[ 155.936356] spidev_ioctl+0x7b8/0xb30 [spidev]
[ 155.936359] __arm64_sys_ioctl+0xb4/0x100
[ 155.936364] invoke_syscall+0x5c/0x130
[ 155.936371] el0_svc_common.constprop.0+0x64/0x110
[ 155.936374] do_el0_svc+0x74/0xa0
[ 155.936377] el0_svc+0x28/0x80
[ 155.936383] el0t_64_sync_handler+0xa4/0x130
[ 155.936386] el0t_64_sync+0x1a4/0x1a8
[ 155.936390] ---[ end trace 97fc80ace9ab14a4 ]---
[ 156.941510] spi-tegra114 c260000.spi: spi transfer timeout
[ 156.946530] tegra-gpcdma 2600000.dma-controller: DMA pause timed out
[ 156.947346] spi_master spi2: failed to transfer one message from queue
And here is my relative dts code:
spi@c260000 {
status = "okay";
cs-gpios = <&gpio_aon TEGRA234_AON_GPIO(CC, 3) GPIO_ACTIVE_HIGH>;
num-cs = <1>;
spi@1 { /* chips select 1 */
compatible = "tegra-spidev";
reg = <0x1>;
status = "okay";
spi-max-frequency = <10000000>;
My test code is here:
import spidev
import time
# create SPI object
spi = spidev.SpiDev()
# open spi device (bus 2, device 1)
spi.open(2, 1)
# config SPI parameter
spi.max_speed_hz = 500000 # config max speed
spi.mode = 0b00 # config spi mode
# prepare amounts of data
data = [0x01, 0x02, 0x03, 0x04] * 1000
# send data
spi.xfer2(data)
# close SPI
spi.close()
I even measured the waveform of this spi with a logic analyzer. The spi clock speed is about 3.3Mhz. I also tried to make the speed to 300Khz by referring this link. But the problem is still there.
I also tried to test this SPI with JetPack 5 and it works fine.
I tried to check the driver code of spi between JP5 and JP6. There are many changes between them. And the dts compatible label also changed between them(JP5:nvidia,tegra186-spi, JP6:nvidia,tegra210-spi)
I am wondering if you have any idea about this.
Look forward to your reply~
