- Is it possible to Install Ubuntu on SSD and boot from SSD ?
- What is the maximum size of SSD supported by Jetson-Nano platfrom ?
You can try below method to boot rootfs from ssd.
Is it possible to boot Kernel and dtb from SSD in Uboot ?
Which interface is that ssd using?
Hi @WayneWWW,
It uses USB 3.0.
Then it has to wait for next release. Currently, uboot is not able to run usb enumeration.
Hey @WayneWWW,
Will it work if SSD is connected with NVMe interface via PCI express bus ?
Unfortunately, uboot does not support nvme either…
It is kind of out of date so we are trying to upgrade it.
HI @WayneWWW,
Thanks for your quick response ! Much appreciated.
What all are the boot media supported by cboot currently other than mmc interface ?
Cboot should work with nvme device. But since uboot is the bootloader for TX1/TX2/Nano, I believe our internal test does not verify it.
Thank you so much for the responses @WayneWWW !
