Hi guys,
I’m currently using the JetsonTX2 (Jetpack3.3) and I have a weird issue when I want to connect to the Jetson via ssh from a Linux computer.
Here is what I tried to check on the port 22 ssh connection status (xxx.130 is linux computer and xxx.137 is the Jetson) :
vdufour@vdufour-Ampere303R036:~$ sudo nmap -sS -p- 134.214.197.130
Starting Nmap 6.40 ( http://nmap.org ) at 2019-11-14 10:44 CET
Nmap scan report for ampere303-r036.insa-lyon.fr (134.214.197.130)
Host is up (0.0000090s latency).
Not shown: 65534 closed ports
PORT STATE SERVICE
22/tcp open ssh
Nmap done: 1 IP address (1 host up) scanned in 5.64 seconds
vdufour@vdufour-Ampere303R036:~$ sudo nmap -sS -p- 134.214.197.137
Starting Nmap 6.40 ( http://nmap.org ) at 2019-11-14 10:45 CET
Nmap scan report for ampere303-r043.insa-lyon.fr (134.214.197.137)
Host is up (0.00057s latency).
PORT STATE SERVICE
22/tcp open ssh
MAC Address: 00:04:4B:A5:57:A5 (Nvidia)
Nmap done: 1 IP address (1 host up) scanned in 5.69 seconds
vdufour@vdufour-Ampere303R036:~$ sudo ssh nvidia@134.197.214.137 -p 22
ssh: connect to host 134.197.214.137 port 22: Connection timed out
vdufour@vdufour-Ampere303R036:~$ ssh nvidia@134.197.214.137
The port seems open and the ssh connection up but it timed out or it tells me there is no route to this address.
The weirder part is when I tried to ssh to the linux computer from the Jetson…and it worked !
How is it possible that it works in one way but not the other when the 2 ports are open ?
Thank you for your help
[EDIT]:
it’s mysteriously solved… I just tried the connection with ubuntu instead of nvidia and it worked, so I retry with nvidia and it worked also…still don’t know why but it does.
