I get the following error when trying to connect to my jetson tx2 dev kit
matt@xps:~$ ssh nvidia@10.5.48.1
ssh: connect to host 10.5.48.1 port 22: Connection refused
On the jetson:
nvidia@jetson-dev:~$ arp -a | grep -Eo '([0-9]*\.){3}[0-9]*'
10.5.48.1
nvidia@jetson-dev:~$ ifconfig
docker0 Link encap:Ethernet HWaddr 02:42:16:1d:01:39
inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr 00:04:4b:e0:00:0e
collisions:0 txqueuelen:1000
Interrupt:42
l4tbr0 Link encap:Ethernet HWaddr 4e:7f:01:e3:e3:f2
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::bcf3:7dff:fe0a:890e/64 Scope:Link
inet6 addr: fe80::1/128 Scope:Link
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:842 (842.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:332 errors:0 dropped:0 overruns:0 frame:0
TX packets:332 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:24701 (24.7 KB) TX bytes:24701 (24.7 KB)
usb0 Link encap:Ethernet HWaddr e6:fa:b6:66:e7:6e
usb1 Link encap:Ethernet HWaddr 4e:7f:01:e3:e3:f2
wlan0 Link encap:Ethernet HWaddr 00:04:4b:e0:00:0c
inet addr:10.5.55.63 Bcast:10.5.63.255 Mask:255.255.240.0
inet6 addr: 2001:67c:10ec:5745:8000::5a1/128 Scope:Global
inet6 addr: fe80::6483:baa4:422a:8ab9/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1699 errors:0 dropped:0 overruns:0 frame:0
TX packets:475 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:929679 (929.6 KB) TX bytes:44857 (44.8 KB)
nvidia@jetson-dev:~$ sudo service ssh status
● ssh.service - OpenBSD Secure Shell server
Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2020-02-21 17:52:33 CET; 12min ago
Process: 4324 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=0/SUCCESS)
Main PID: 4329 (sshd)
Tasks: 1
Memory: 868.0K
CPU: 28ms
CGroup: /system.slice/ssh.service
└─4329 /usr/sbin/sshd -D
Feb 21 17:52:33 jetson-dev systemd[1]: Starting OpenBSD Secure Shell server...
Feb 21 17:52:33 jetson-dev sshd[4329]: Server listening on 0.0.0.0 port 22.
Feb 21 17:52:33 jetson-dev sshd[4329]: Server listening on :: port 22.
Feb 21 17:52:33 jetson-dev systemd[1]: Started OpenBSD Secure Shell server.
nvidia@jetson-dev:~$ sudo netstat -anp | grep sshd
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 4329/sshd
tcp6 0 0 :::22 :::* LISTEN 4329/sshd
unix 3 [ ] STREAM CONNECTED 48293 4329/sshd
On the laptop:
matt@xps:~$ ping 10.5.48.1
PING 10.5.48.1 (10.5.48.1) 56(84) bytes of data.
64 bytes from 10.5.48.1: icmp_seq=1 ttl=255 time=3.64 ms
64 bytes from 10.5.48.1: icmp_seq=2 ttl=255 time=3.25 ms
64 bytes from 10.5.48.1: icmp_seq=3 ttl=255 time=5.35 ms
I tried to reinstall openssh-server as some people suggested on behlaf of this issue but no success.
Help is much appreciated.
