How can I step into my OpenACC code region with cuda-gdb. Setting a breakpoint at the line number does not seem to work. E.g.,
[Launch of CUDA Kernel 6 (calc_force_des_150_gpu<<<(18471,1,1),(256,1,1)>>>) on Device 0]
[Launch of CUDA Kernel 7 (calc_force_des_180_gpu_red<<<(1,1,1),(256,1,1)>>>) on Device 0]
[Termination of CUDA Kernel 6 (calc_force_des_150_gpu<<<(18471,1,1),(256,1,1)>>>) on Device 0]
Breakpoint 1, calc_force_des () at calc_force_des.f:408
408 !$acc data copy(tmp_ax(dimn))
(cuda-gdb)
(cuda-gdb) n
[Launch of CUDA Kernel 8 (calc_force_des_408_gpu<<<(18471,1,1),(1,1,1)>>>) on Device 0]
[Launch of CUDA Kernel 9 (calc_force_des_444_gpu_red<<<(4,1,1),(256,1,1)>>>) on Device 0]
[Termination of CUDA Kernel 8 (calc_force_des_408_gpu<<<(18471,1,1),(1,1,1)>>>) on Device 0]
667
(cuda-gdb) n
0x00000000007a9e40 in pgf90io_src_info03 ()
(cuda-gdb) n
Single stepping until exit from function pgf90io_src_info03,
which has no line number information.
0x00000000007a8130 in pgf90io_encode_fmt ()
(cuda-gdb) n
Single stepping until exit from function pgf90io_encode_fmt,
0x00000000007afa40 in pgf90io_fmtw_init ()
(cuda-gdb) n
Single stepping until exit from function pgf90io_fmtw_init,
0x00000000007b2c20 in pgf90io_sc_i_fmt_write ()
Seems like above I have already exited from the kernel I want to examine, which is calc_force_des_408_gpu.
I also tried setting a breakpoint at the start of cuda kernels, but then I get messages like
(cuda-gdb) break calc_force_des_408_gpu
Function "calc_force_des_408_gpu" not defined.
Make breakpoint pending on future shared library load? (y or [n])
I went throught the cuda-gdb manual from Legacy PGI Compilers - NVIDIA Developer Forums, but it does not have very detailed instructions.
Anirban
