I have decided to revisit a long-standing issue with launching anything from apache or nginx trying to access nvarguscamerasrc.
My test case is to just grab a screenshot:
“gst-launch-1.0 nvarguscamerasrc num-buffers=1 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12’ ! nvjpegenc ! filesink location=/var/www/html/test.jpg -e”
When I launch this as my normal user, root or even as www-data it runs fine from a SSH shell and grabs the screenshot. If, however, I launch it from PHP using exec function all I get is this:
“Error: Can’t initialize nvrm channel
Couldn’t create ddkvic Session: Cannot allocate memory
nvbuf_utils: Could not create Default NvBufferSession
WARNING: erroneous pipeline: no element “nvarguscamerasrc””
I have tried apache and nginx and both do the same thing. I have ran nginx as root, www-data and even my normal user called robot1. If this process launches from the webserver it will not work.
Earlier work seemed to indicate this was a systemd issue as anything launched from that would give this same error. However, I recently updated to the newest L4T and now I cannot use my old workaround. I used to be able to stop the webserver process and launch it from a command prompt and it would work. Now it seems to be broken permenantly.
There has got to be a reason why I cannot launch any camera commands from a webserver. This has me stopped dead in my tracks now. I have done considerable troubleshooting with permissions and things and cannot make heads or tails out of it.
Ideas???
