Strange Kernel Freezes Freezing when the Kernel uses any device memory variable.
In advance, sorry for my English.
I’m having strange problems with a kernel I’m trying to do for a Photon Mapper. Every time I try to access a device variable in the kernel (either static or dynamic), the program simply freezes the system. Unfortunately, I only own a video card to display and the CUDA (a GeForce 9800 GTX) and is hard to debug a program in this way. I’m using a Windows 7 Ultimate and CUDA Toolkit 3.0 and the new SDK (both 32-bit). The driver installed is 195.39.
Now, some code:
[codebox]global void photonmap( const int number_of_triangles,
					  const float4 light_pos,
					  const float4 light_color,
					  HostPhoton * out_data)
unsigned int index = (blockDim.x * blockIdx.x) + threadIdx.x ;
unsigned long seed = index;
int photon_depth = 0;
float4 p_dir;
p_dir.z = 1;
do{
	p_dir.x = 2*random(&seed) - 1;
	p_dir.y = 2*random(&seed) - 1;
	p_dir.z = 2*random(&seed) - 1;
}while((p_dir.x*p_dir.x + p_dir.y*p_dir.y + p_dir.z*p_dir.z) > 1);
 __syncthreads(); // Sincroniza os threads
Photon p(light_pos, p_dir, light_color); // Criar fóton
PhotonHitRecord hit_p;	//Criar estrutura de gerenciamento do loop
float4 v0;
float4 e1;
float4 e2;
for(photon_depth = 0; photon_depth < DEPTH; photon_depth++)
	// search through the triangles and find the nearest hit point
	for(int i = 0; i < number_of_triangles; i++)
		v0 = tex1Dfetch(triangle_texture,i*3);
		e1 = tex1Dfetch(triangle_texture,i*3+1);
		e2 = tex1Dfetch(triangle_texture,i*3+2);
		float t = PhotonTriangleIntersection(p, make_float3(v0.x,v0.y,v0.z),
			make_float3(e1.x,e1.y,e1.z),
			make_float3(e2.x,e2.y,e2.z));
		if(t < hit_p.t && t > 0.001)
			hit_p.t = t;
			hit_p.hit_index = i;
	 __syncthreads();
	if(hit_p.hit_index < 0){
		out_data[index+photon_depth].position = make_float4(0.0f,0.0f,0.0f,0.0f); // This variable freezes the system
		out_data[index+photon_depth].direction = make_float4(0.0f,0.0f,0.0f,0.0f); // This variable freezes the system
		out_data[index+photon_depth].power = make_float4(0.0f,0.0f,0.0f,0.0f);	// This variable freezes the system
		photon_counter++; // This variable freezes the system (static device variable)
		if(index == 1) photon_counter++;
	}else{
		// Cria uma normal
		hit_p.normal = cross(make_float3(e1.x,e1.y,e1.z), make_float3(e2.x,e2.y,e2.z));
		hit_p.normal = normalize(hit_p.normal);
	float4 hitpoint = p.pos + p.dir * hit_p.t;
		float3 L = make_float3(light_pos.x - hitpoint.x,light_pos.y - hitpoint.y, light_pos.z - hitpoint.z);
		float dist_to_light = length(L);
		L = normalize(L);
		float roulette = random(&seed);
		if( roulette <= DIFF){
			out_data[index+photon_depth].position = p.pos; // This variable freezes the system
			out_data[index+photon_depth].direction = p.dir; // This variable freezes the system
			out_data[index+photon_depth].power = p.power; // This variable freezes the system
			float4 reflection = make_float4(0.0f,0.0f,0.0f,0.0f);
			float r1 = random(&seed);
			float r2 = random(&seed);
			reflection.x = __cosf(2.0f*PI*r1)*__fsqrt_rn(1-__powf(r2,(2.0f/EXPO+1.0f)));
			reflection.y = __sinf(2.0f*PI*r1)*__fsqrt_rn(1-__powf(r2,(2.0f/EXPO+1.0f)));
			reflection.z = __fsqrt_rn(__powf(r2,(1.0f/EXPO+1.0f)));
			reflection.w = 0.0f;
			hit_p.resetT();
			p = Photon(hitpoint, reflection, light_color);
		} else if(roulette > DIFF && roulette <= (DIFF + SPEC)){
			hit_p.resetT();
			float3 reflected = reflect(make_float3(p.dir.x,p.dir.y,p.dir.z),hit_p.normal);
                                             make_float4(reflected.x,reflected.y,reflected.z,0.0f),
                                             light_color);
		} else{
}[/codebox]
I discovered the location of this problem by isolating parts of the code and compiling the rest separately until you find what freezes the system. Although I have come to this conclusion, I’m not “the best programmer” and I still a beginner when it comes to programming using CUDA. So, feel free to correct my logic.
I’m really perplexed by this strange behavior of the program.
I’ve been having strange kernel freezes my self that forces me to reboot my system. Sometimes adding a single line of code will cause a crash even if that line couldn’t possibly ever be executed. Shared memory seems extra sensitive.
I just skimmed over your code:
4 suggestions
  1. Try using deviceemu and check your array access bounds…
  2. I see a __syncthreads inside an if loop somewhere in your code… try commenting that out first… and try putting it outside the loop.
  3. Check your shared memory access pattern you may be allocating//accessing it incorrectly…
4)Whats your lmem usage ?
