Strange mapping of float shader color values to uchar values in a read buffer
I knew that a range of float color value in a shader [0…1] is mapped into range of [0…255] in UCHAR buffer.
According to this, I was expecting for steps of size of 1/255 in shader color values for each change in UCHAR buffer.
But the results were surprisingly different. Here is for the first two steps:
Red float value in Shader → UCHAR value in a read Buffer
0.000000 → 0
0.002197 → 0
0.002198 → 1
0.006102 → 1
0.006105 → 2
The first two steps are around 0.002197 and 0.006102 which are different than the expected steps: 0.00392 and 0.00784.
So what is the mapping formula ?
