Streaming to gstreamer from home made app
I copied the following code from ChatGPT which packs H265 frames in RTP packets and sends them to a receiver computer that is supposed to decode them with any app, but when i run gstreamer on the receiving desktop, it gives an “invalid RTP payload” message and does not open the video
if i stream from gstreamer it works fine
any ideas on why this happens?
#include <iostream>
#include <fstream>
#include <vector>
#include <cstring>
#include <chrono>
#include <thread>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
using namespace std;
// RTP header structure
struct RTPHeader {
    uint8_t version;
    uint8_t padding;
    uint8_t extension;
    uint8_t csrcCount;
    uint8_t marker;
    uint8_t payloadType;
    uint16_t sequenceNumber;
    uint32_t timestamp;
    uint32_t ssrc;
// Function to send RTP packets
void sendRtpPackets(const vector<uint8_t>& encodedData, int socket, const sockaddr_in& destAddress, uint16_t destPort) {
    constexpr size_t RTP_HEADER_SIZE = 12;
    constexpr size_t MAX_PAYLOAD_SIZE = 1400;
    size_t dataSize = encodedData.size();
    size_t numPackets = (dataSize + MAX_PAYLOAD_SIZE - 1) / MAX_PAYLOAD_SIZE;
    RTPHeader rtpHeader;
    memset(&rtpHeader, 0, sizeof(RTPHeader));
    rtpHeader.version = 2;
    rtpHeader.sequenceNumber = htons(0);
    rtpHeader.ssrc = htonl(12345);  // Set your own SSRC value
    for (size_t i = 0; i < numPackets; ++i) {
        size_t payloadSize = min(MAX_PAYLOAD_SIZE, dataSize - i * MAX_PAYLOAD_SIZE);
        size_t packetSize = RTP_HEADER_SIZE + payloadSize;
        vector<uint8_t> rtpPacket(packetSize);
        rtpHeader.sequenceNumber = htons(i);
        memcpy(&rtpPacket[0], &rtpHeader, sizeof(RTPHeader));
        memcpy(&rtpPacket[RTP_HEADER_SIZE], &encodedData[i * MAX_PAYLOAD_SIZE], payloadSize);
        ssize_t bytesSent = sendto(socket, rtpPacket.data(), packetSize, 0,
                                   (struct sockaddr*)&destAddress, sizeof(destAddress));
        if (bytesSent < 0) {
            cerr << "Failed to send RTP packet." << endl;
            return;
        // Delay between packets to control the sending rate
        this_thread::sleep_for(chrono::milliseconds(10));
int main() {
    // Load encoded H.265 data from file
    ifstream file("encoded_data.h265", ios::binary | ios::ate);
    if (!file) {
        cerr << "Failed to open encoded data file." << endl;
        return 1;
    streamsize fileSize = file.tellg();
    file.seekg(0, ios::beg);
    vector<uint8_t> encodedData(fileSize);
    if (!file.read(reinterpret_cast<char*>(encodedData.data()), fileSize)) {
        cerr << "Failed to read encoded data from file." << endl;
        return 1;
    // Initialize UDP socket
    int socketDescriptor = socket(AF_INET, SOCK_DGRAM, 0);
    if (socketDescriptor < 0) {
        cerr << "Failed to create UDP socket." << endl;
        return 1;
    // Set destination address and port
    sockaddr_in destAddress{};
    destAddress.sin_family = AF_INET;
    destAddress.sin_port = htons(12345);  // Set destination port
    if (inet_aton("192.168.0.100", &destAddress.sin_addr) == 0) {
        cerr << "Invalid destination address." << endl;
        return 1;
    // Send RTP packets
    sendRtpPackets(encodedData, socketDescriptor, destAddress, 12345);
    // Close the socket
    close(socketDescriptor);
    return 0;
This would need other users to check and share experience.
For running RTSP through gstreamer, you can refer to Jetson Nano FAQ
