Gstreamer fails to decode H264 Stream - invalid RTP Payload
Trying to decode a stream from a RTSP camera using gstreamer, and the pipeline is: Camera → PC1 → Communication Device 1 → Communication Device 2 → PC2 → Local Loopback. I was trying to decode and view the stream at the local loopback, and when I tried to decode it using the following command:
gst-launch-1.0 -v udpsrc port=8888 ! 'application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96' ! rtph264depay ! h264parse ! decodebin ! videoconvert ! autovideosink sync=false
It failed and the following info showed:
“WARNING: from element /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0: Could not decode stream.
Additional debug info:
gstrtpbasedepayload.c(466): gst_rtp_base_depayload_handle_buffer (): /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0:
Received invalid RTP payload, dropping
I basically ran a python file to SETUP, and PLAY to receive RTP packets at PC1, and removed the first four bytes (RTSP Interleaved Frame) and forwarded to Communication Device 1 using UDP, and Communication Device 2 can receive the packets I forwarded. I simultaneously ran a python file to receive packets from Device 2 at PC2 and local loopback to a port (8888). I’m not exactly sure which step went wrong. Occasionally I can see very laggy video with low fidelity and high jitter.
Please check if you can run this command:
$ gst-launch-1.0 -v udpsrc port=8888 ! 'application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96' ! rtph264depay ! h264parse ! avdec_h264 ! fakesink
If yes, please try this command and check if there is video preview:
$ gst-launch-1.0 -v udpsrc port=8888 ! 'application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96' ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! xvimagesink
Hi, I tried the first command, same error message came up, except this time, multiple very long codec_data(buffer) also poped up on the screen. The second command produced the same error message as before. I tried with and without removing the first four bytes of the packets. Without removing, there’s no video preview whatsoever; and with removing, occasionally very jittery stream pop up with very low fidelity. The following is what I got from running the first command you provided. The results from the second command is pretty much the same as I got from the original command.
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
WARNING: from element /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0:Could not decode stream.
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0164001fffe100106764001fac2c6b814016e9b808080810011f5b68ee31b21b24000021906000cd633f55f36337197b4857000300000200000000000000000006e501848024000585906000ce633f55f36337197b485700030000020000000000000000007c85b800001502c00012bff1025c5bfc0ebd6fe64268a57d0506f10b97b2b76cf192714ee2253d0d219effd9e84ba8bfd4f990806a95cd06a841470d8ef40e2d74106d29a61f9ae010c862f67cda70b1e1242ba036241e95c2efb2aa10c0c3bd6cbe0903717ad08bdc2a42a148baa2ec5533011610019fdf55fdc8ef6f491659222494dac38a8c96ace83510493873387ef9f37d417bbce8d8ebf895fa5c9c9fa38074f7304de91e934306fb5a2666bf1db33a25f3b0b81f3514a94f745e85410235297a6ff5deff46c721bc8f409eb3cf10f826f436955009b3195438e27a9bdec256a6dcbecf571e0e47794d06f786a2416f3430677272408a3a44f1b413e0e3e019dfcba0bc61ba53678cf19aeb68631ebe2cb4123597fd5554a60f12608ea5832671a9e7de05277a46e3e58c5b6e0af013045cea99c46fa33b4f22a61ea7ec57dd76e561f9dc2c23c15663f1e1044dd3f105adbb44d5353419ec58b3fad007245bb2195447a6de52757834698dc522d399b194fdad12b93dc6d80a4400febe047e374f5f79c6a017c600af850930a528a7959a4a49c728bce957103e96b836bcb75d4e6cedb33705afc927cb5d0e76bff7b201ca577a4c841a419c005ca67d67bf17c9118cadb9e47d139b56d2b90c77eb564f58458ae20fa6dbfbb3aaf108ffb52ae3a111678a6807c09937d4ef11c2af26500e5eb70e76890e34254f8497f43ff96851082f9e105e6f52ea056cbd462c6b180061f3f2f674a0f9041bfb9f30faae89017d4ec7e9b55c3f854ac7d0cdb5f0157cc3aabfcbeb06901e93697815871c0923056ac1c56a4ef43218a0cfc759642d18595f8d350919c21fa6fd3f3aef91d5177412efe2a979bb19e8d69e21ca74587cf9fb691d7abbfb43fce1eb61b9770cbb44318964f18805ad3e31c709436e5a61eab3852eb2c063edf8b043cac34273e88214b38d58f8e3acdde38af51646b6fba53d7c4dd992f77682644f14c01fbdafd78bdfb75c3941906490a32c6361e1d9b7e7dee2821c5198930745eb46a93ca77042711c512bf6d027da008b9878be1da811b458bad38fa0659f6b0b566a1a9516bfda08ab275a864f7c62258c2356010180a327e19e2859fc93cc287a47f0e5f828c70c7385689c4b728a0e53106cf543fcca60aa1e6f26a61f2ec014865c57cc35bdd7d872b81bff7c04fed6989037aae7f81414e307f207994b60282f98e547dad53757b8e5c467c4729380b4868e01a922d9b289ea0155a06c526a9d7aa65c7d130e3888e2e9c3c76ceda793fe6a3d5822e254307fc27c73b101c3b315d17e1d810016e5b4373de8cf47276ce983808b85fedd5a8c76300cdb388752a51fd7ac464955b2c4cd5c35dcf483abaf24b062f87e135b71918e63c201fe5d503239d7d7a03e4400f3a0e9a17e6f9302854134e415ec2e25bf140d7412b24b37389dd0179377b3e1ce22954569b9fa0f89f0c8a840f74a29255574277591158e06af34dc4cc4fa98f70b6d248852e8e85f516fedf76ffeedae69c4fb92ac14afcfb94f4e0db308f64862603c0cb36132c03d2babf2bf364d4c4685ab67952a549c7e833b79ccc571a53f0f65fa22fb49eb235d88baaac536ffffd72e873dffacedd130e0e13bb872e98c9e8782b0f59bf6edf30967bcfe9f93f55631dc8921e10b92f9aa062a92bd690ac2608fe36caec52a5c507da911c4de65992734002b589abbf11d2a590015cdff66ef0cf02151fad59043e34aac1b35b2f621ff6bbed0a6cc3a424b7fc8275af22a62078d3190aabda2c7f69a7fc9aec7d78111f54472bf52dfc7f7828e3f6ac046a14a0da38daf6704ad76beb89dcf757803474daf7a253f784fed71dc8eb6710311d6c80c9e632cecdd8d30528424cc8564512951c65ee5ad7de35093534d12e08f52c40afb7a3261e52028bac16cf66df1c234eb28fba26e8b24000586906000cf633f55f36337197b485700030000020000000000000000007c05a27f6d30d9bfc33ed8fea42b0aff703ceab3daffaadfa88dc1d8c39c4f96edb03e3b3420bfb79748cb7ebb89db9225d290bfe1fc559dbb802680a514a3324c36d08ad8349c9fab5788c8ba46ace6bfd110d3a2eb33f566aa1c180a4a24e9148d780bf9d0687f8ac372462b68ef000664e7dd19d0bbe4683e0ae2d63816af0105554b401eec38b86530b8725778fe60503c518f6c152079c4487eaee1e7cf6e4e4ec8e65dd37e05e099e13114b73d281c3dadb333eb67cf1bb2fbe38217d091c5c7bdaf3605ca92888acf294d13a60ca6b688a92da8c7284ee12408347d364cd173dc50ed8863a1e7108c8d4f28b4b6fb69e1c9252388d5d092f55d4817cb636cacf7e758e31a751fd7a2e89c182afd6884bc325a06a28cffbfec46cdfac1747c0bfc27b773d412fe2e1d08b607156f40c86918e672c067362cc9330f93eef766cb5fd8907fbcf70e53f2a7dfbe63417095fbe5f1b91dbf4c7af6d10a0cac1582c4ef7978ead58d217a3b5934de039360f641cd641785062ea4bacfaceaff6946b1681bf586b05efc4ad559ea0654671777fb25e5c772c198744f79bd55fddd84aca0996a81c2bf93081461b42e91de915f22c58807728c034483b8354a8677908d0d91b24c8c355b0f8a97ac192408c663bb5bc57ad2dea8739c4bc08102905f3e4e69ca0d0f1cde276970f665a48e2036bd054887a1ba4916a43a2158a8d06e7e0a209d361e8e4d2dd4a1ff3d82c26e84e78ae66dcb870ca6aa2346bc238ad4d61fd6bac98e558d8714f3701e1baea641a80cec948be87c38d3585f930ebbb659eaccbd41679b3150e5926e2e6557335626efcdd980b9e739db997f8e89e91d49734e9b8dfd1a147d60d25b8900b292655b79ce9238172a4dc9cec2a641b8fcffd02759c9380fd29b5d14fc8957ef832e369c505e23a48d1a713b92c3a2a039654e8f1af7d7fff450029c407ac9ef22d2508ee67074a39673cfcd1941a525df4a4b41193480fe72b8ce1050b5be0ae0cb86c6981eacf5ed040a36ab325d209e16b324d7527173beab35df6cf40e6319f5ae8a2c61a90250997d07b674024c2ffffffffd1475477f083037b39debd40bd2c54c35f31713b1739897393fc671764175f119f08abd75ec8d88fb958cdf90e2cdfc70fd501cf8627b8776bf56ce6fad5493bf942eab459ad30ab8c580237fcc802305ffaf7257fc36b151a4f50b8b50368b61a829c15e92d2ef5c300becc85e1d60351577151915857bbd7033a9104ba8ab92d8eaca1889c56747df1f9c23b87a654ca602d3df50542b4551792894ad007c15edf2a40d7c37d622fdcd7fea1068058d778d4c77fd703c0ffba6612ec2b72dec745d0c0d2ebd071c72c96bfe20eb3bc7dc0ba06ad396dcc496b8634048382fce27630cd4bf8078689afd78519e27076567ecd0a8c2d1142a81e87981d2a34dbccc73541f4546f40274c7c484d4e34aa928d2b38bed0a30440574f65d058e910a0d38cbe4661161158d49ad6996a9569666e07ce5d1dd2ea3a57aa40fedba4cb91a12471f37a3fb15d36ff19618fe69a688ebe973b044ce67ea5d7b6bacc4ff8656ba9fc0bacba77ce6f495bfc8e2f2149099d22bbc35d8beae2143a40f02242cffe6482eb3b058b790f9afc4702bbb5ac37a42e7cf9e4cc6726827206d0a1d6161dab70bade34b44e419c3328aee4d8e0e11c05fd288a74a0167c0b4fd9297b01a4d63e92cc96ace9d290a5c5bca015c030ef7593579c5ffc9dc4ee79254b674085eae96cb81ee739c0f7e336abf33c660d35709acb91fbe6a967deaab267f41b92cc315f63069faa2a430ed3c5995aa5a4fdf7f933db0341834b0c240b7c5d4be89abdd174fc53a28f173b19e3dee416b2e6de0dca58fec637d708be25bf31f2220e6b5c1dce8ad6e741d6bf267524b230df51e0a5d5885131615c686ca08da120f6ab124000586906000d0633f55f36337197b485700030000020000000000000000007c053dd55dd327ebb66024932ec6c1f2eafff95ead7f44910b35f28425f28d4c01067f5aa8092a2c327a08acf72f380ddc29960d80a61efa7eedb7e1a19704f239bcf913adf5b98c75508b31312f4448df3c5e16941cfeff6230f563499036b1fe72ee27ad186a670778200dd3d714c20f271a9734ae6d92b3789df3d17cb05bff63dd79ee818aa147afd5ca426f7cc706fd5e2791003fcf1c63c0e7d258b3f09dd291372cc315ebf745cad2935d2a7f088309e15565a6b51bf07ffea0eb8104fd2720794fee4ad9ccab3f742e9a4114085e232cd12ceda9ec0a11874030f9fb4bba75034a27d9bb3495e93ade729ff4073641d07011fd77c07217504f56c1a952cab1bedba52ac5fb74e9d0b68e5e619a70158484150fcb3fd0b532f548c3efa3f30a93a9d891fe4f335c7ce9fe0b7ff1bcd8805cef7ea640336209d563423fbacad611131913831ca436f2c3f53d3de4f2f07bdd04bc8af35426e09c1e3465f4a3c946b5ff4f2414aa10d808ea84e8e87f73b2f17ae198f367ebc58ef7758d807f6ffeeaa1517c0fd5a54537080eded0f030d4e867667895d5e0ef54c349575700cf8af60245bd56557e0bff547434b9b1b88cc0758d8a3d480607a74c736b5c495a9cdb25a27b3138139aaa622abe7ca4d08f413c0f5de5d4374684f29f547fff405d6c0d57d9116ab3ebc5b8467353c2b60b9ad0345c56939c5c199abd7c933f5d525b47115764849a118810a95f17293c770eda4bfe36c83d41a39e0f12522e1b3cf2a5593b051c3ab615293ff5cdfdd8a6a31d3a23834cd8b41a336481b9f29df0858e6e756bf618855b736e5a9b2d3fa3000000016500c8b800001502c00012bff1026356ff03af5b4831603a8d14f7fd3fea2fc500f03fad22f97fd5554b3f74898424662fbcb0d193c5a4bceb39c2f1ad39adb5df1690bdda9b359435681266fe0a6d62b3d2bd2de75f6cefdbddab2b715d42f7a97680628851a6bda897462c75f3b95eb9e7272f4e2efcf18ce3bba6d5e25763f29a0ca63f81e3b33bde76269a77a19fc64e2a38edede1bfa1e57a7cb2d56de9e0e42910b212fb0c496ecb76bae2b61d5454c9964a29746258f2f8fcd466c104cf8f6ccb0d421720859a60ad0b8f9af653cd20834c1d7701b7c7a53b0d3c9fa2dc2afbe5cf627779ab31d77d962f2e2c70201fded9bf7cb3d753cf1b33185391ede908e8b97bb7113520c6ade0f1a93a97ec2ab5b22c7c1840d7927e881fc56b4b7cabca20a5d0906c861172da3097822cbf132fe49cc7f7d611ab795dfa511a91f154bfda77a7704e0c93b5a8a8933bbae5a594ed8ecb692f1e2d14137a580a236b6d9467cddffa081dfeb7b61b33f030cc3b9633f02bcc7c049efd8963334527015fe9d7907df4e0fd22a639a71212be285d4cf1fba92ddda27b7c8a8e3397338588292c7830d699831a77b9063a8313740caecbe7a7eac4ede0ec55c3f23fb453bc2503fd7a58e1594033bf27fb21e264007991ce008172e748fc80d88d7e65a2cccd9adb36c0aa9387099439e8c2f4782dcdb72ae2e600b7f9996d4e052abef2881346af893507503d4b41af444ac7462b2c35b17153af0f92c81f6ca83d65dc932ac84293d8f4ec232d394386161747650b82f8053555b31e404c3132cbf83f6805f6fca28d349a8552c33d42b34b2005f5dcd0aa903c14ddc06f90582aba2806b81cfc632f45f6f87433698744fd056c5a096af991f4b1c84e327794f78bcecdbe3d485c69ff2517c72ff47c42f8a0f9f596af169d39253e5afd07b675ff92617ffffffffbfd9ac86ad395b0b01f7749bbd5ef54b1f0fda69dff26d9d7dff5cec7301588ebd885feef349a1167b1af235f6d578b2ca480f7fe6d513a8e206a5f5f9f9f5b9a2f442577312cbdec15217cade0734c00b37913289d5862d725891059251c6fe9b6506edb5e8f7cf3a07624000586906000d1633f55f36337197b485700030000020000000000000000007c05288164cba467546217df86e7784df4c7324a8f6fb2fed27ee918c50941dec371378bab67fc8e38ce279c4cd880df54019036bd7f4fe8007ae9d635e3488b00bfd69b2fb0311d2c123919f78ebe04ce98563287df5a7ba92af41f738cb61ee380ef0c040beb17356d4bc7e6e1bd1b8c0f817c7e953a98071cc733fc8be077bde42b73c8d38c421a3c071e91a04037364e41490ce546d34e0ebbbca9f9264724abf182a07a7d2cbb14e5feccaebc284b5e50e8cbdb0792cbac2d7a03017b8780130837edaac9ff8e9c5c3785ea0eb86569f231914ac92cbae13867d7af947152d745f3ff9a3cbc3f884484e5ae02a166094f888e108ad331df0651bb293a1b16eef3e71d4ba79bde38aa4a31aa63a458dab06097240f348585f1c455928043a9b1253e4d25fb81a2ad63a700de437852c087c0ac207de4cb31b1a21f10c565f10971169661776f3984fa9e01f72f5a866f5a6f20590386643f953b9e2f9b8037bac47c8dff55708bf03003431fc60af481e5ab1e6fff91d03c4e65d9128787bff2a5587a3b154dc99985c8c9c2cec9c2fb189396e45e461c9a3141c9a9ea36678df76d9367e051e75d46281e63259a8e7f557ee107822a854b5a3f603ad842a36aff5cc16d850ad1bbd239156303936b2e045e13fff1882b26359101facc13752d3578a98f3fbbe4854429a5e2e1ad5ad7e80dcc4246b9c1f43a8360d3ec61d8bbfb97871a8a8e4a890dbcfd56f542cd07f004a4fd45704be7425dbf832b92b073f1fb956ae05d1e5674624ef4c533f52d264be59657f55da8ed560ed225d20c0a67bad4e92872a97784b22afa1e13b6516545d8dbbd5e83a9e6ef62d02599fb011412fdd15e904a600cc440bff69692bb484251f3b31d4de2458e255901afa1c055675fed89016730839285172222977f5b4b214e6e86dfb433f88577daacab985b989cc41ece5205c29be20a08343f116c6c21b89f246b148e3501f3c3836208f292cfa660e36fe18d116bbe2ae9d2d8e2fbea1a52ab523a5a8694503af8e93fd573f785a51fceffbf2d4680f3d6c3f1ca39b9bfa7a4387f500fb35ca4836b154eee703410a24d5c396f69a2c458bac2d91f54ce341d99de15b354fb3585cf564081bfd9104292ebc3e2b81563c4d8921645deaa6abc7f8558500250d9bcd26d81eb3321e7bedbf012e8609aeee99523fcb468f7c66246832d282c074e9e3a89a93b46d24a69d4648077bf38ab6df0684b254b9b4089197471767a16709b23b743312a4dd7f84f813527fbee1e26840999e1e251407e5553003d4476c03d94ba3b855a40bd218507bb5b701b953fb5428f81e227f0b456645f4497c55f92e1eba7436d5f1f53157a41dac50e2857696920abd75e5ccaa0cdd9c7bdd3c24473803f429782e99569a9c3db149ae7571f36f0a5352f36d2a6a20a2c850ad72ae7ff802e48071fec44f3b4250f8755d4626453ae28cf1a82430e1c58c2bdc40e8625f5c7604553dfc900d8d2be6cc46de40fc22e24f81478dbce5193bf5517cc646be8f95eb20caeb3014ba9e26182063d7c10ed09fbd9c00531415592ef39ff03dd2c1e05c76a9a8ba9e401d155e7e020d15d04b6f4581fb796a499d081a76abd0d6f113091ed72164b60e615e18d730b0a13aa3852700049e2c91263c33f256fcc887c88e253b378c1aa9127c5d919ccf0834698765927316127e4d192b507ae379c4ff873d7919f9a678c6dd8dedaae0c7b66a03f9cd7d66524ec328fc71c32dd000000016500642e00000540b00004aff1026356ff03af5b4831260dc68c81c11bd7b35b6cc9101b76540fbdff3bfb1fe802fe35ab658637d886ae992358b3a01f3d95884cd5c70d1bc8772d0734104060cf4c8684a66bc80977ab70c7659fa5306b4cf9f0edb384066f028e697ce3ad4fef765b9236dab3d48b9a6bfdfd36f0a477b3519a0c2bf424000586906000d2633f55f36337197b485700030000020000000000000000007c051fe71b1e57c21738b227bea8f415b3fb2ba8597a22ea7a4144c1893956707021e1292b2eecb1ba83b4d79ea9e85161fe52a6e29411f44b74e73f33041f67b863945ebade22270a37f9c2b82ebed253f45f431f8084283b21a96c6f30d2a1fcd1609ab5b22175c749596de9b1621c501d13f5098af2902b1c6099f6fda9fa8d558260561de5e19101e30ed5e4cf611b2e397e40cd7bf0cf11902c349feafe6380a6816246ddbfecbc8776c6a64e92425ab84c58907c7938bbd734287af6e8c01264c40cbf017a79294c24b310000000016500258b800001502c00012bfff1026356ff03af5b4831260dbc5fcd78d85578574ab178d98a450be48ce1527579aaadb038ef3208aba4d2460eda60d53778af2bb9037d40e44498b331703c65d43a5456aecfdd9ca35f6a5a30ab67482d850fda3e47a41c5f3d03003185ca5186b9b7f370a9c3a31f83a0e9bcac90ee63573ea22c99c5db715a8bbbc74def13af9681a5baee22a9e604bbcc7133e1ff98471f4ab83c0f05d51fbc5fe696808cfa7fa48262a7f101794223d0659722a1cc2e05bb72479994d3b00d7ee8c7731df2d00933bb08ed1151dd0232fb2f16381983c39c0d1940ae2122b5d4361ba287e0a447cfe513ccd71ba03479c643d6659fb82424d3e2ac27bb45389cceb58accf89615143c4a94529ef7903a926cf17443e30d4e4e82071dabd84216d4e45f0ceeb8f29bb69253eb6ff7bed83b3c4489a2399bb37ec4e0000000016500320b800001502c00012bfff1026356ff03af5b489d9faa2050e3cd793d565d4e3a40260b3b1c28f1842e34d815f85a6d8c59a6165ad16ebdc708358a799352d48e25ce1fa87e77f5a50a4899dc930b2176ec2fd038e3325f2c17e83e38782a4481d2367aa5bc6b0ac0e54aed79f2ac3d589177e1e639a179aeaed698f6bfd37944dbd26539f368a5eaf7b1d381af49bc62ffa62f69809c7a7bfc0c88724371ccd922897ca9d18824ea519484844bb651229778bd270001e54d6d85823a8bb954f5c088c136fbe1d71fe2769f43e5d4bbf12a5db629a4137e0072c4fa5063b38cbe268206ee89ac0d4b7ccd0bcab4363a411846918c9a06e8c6eb44de9b6d75eaa5b731fcf410bd919899312ce06dd7807982dff1097ac2a2a8886ae004bb579386dc80cf056757cc61e476380000000165003e8b800001502c00012bfff1026356ff03af4ca07f59faa238da86958f2685a416d805e6e6075c4b126bfff83cd450e8d3a8c9cc89865a36d8939a393ae1749ca8c681b62212bec39de3470fd33f5f85dd01944c72e9100b949b3577032bca65a5b400c32e85ad086b55e5149e614c507b1898d82c6bce49b6aa2e9ce8d7100bc2c492ab7407bf3d3db63712edb25c4dcc57c8aa1bff58ba9fcead35513544d295e10ae6911473ba6c6e799a428c177a66ab278cfcf0076406166aec15f9f29f456aaad07ce6af9235d7a0b1ff0865e059ce81ce08d7403f12490ff34a0540fde2af70527ad486461762c6837525fe60baba78c452017ad86b44233b4391ccb03f6f95e97bbe9c805a36ba06128011bdcef89cce7b1f3061e0a31cb363d29211560e1c61eb0b3c0c3de8c4d1f4c3333f6ecbb7af8cd391311800000001650012c2e00000540b00004afff10273917fc0ebd6f7c3de6f96d3e4af2eaff2f47b46da240bc7dfd6e721bc2ff165b06377797f0f2c2bea381148281fe2f905bb5a7da01ed4f3d1a22b8e83a4c2d780c2ced110ad124744f5fd47e4fd09888e849227d7b772336418c0d7923a0fc1e679e3916b670bcf621768fa579128fc4297ebaec2420dac851e8ea50b6761a4af84524440515b1b8bf876049471b609b84b0ea2540ef02895a3ce19eb8b4163c5dc31d6dd8c82df0d19b6252e990f50ee9a81e4d480c076e0458c23cd23e4f4319c8347ab8ae4ee455ff353f835013e2400037c90e000d3633f55f36337197b485700030000020000000000000000007c455424b2e9f94ed75e9d2839abb748f1ce0ee1664ef900284fe8c7828b5f6466b6467c1d3b236339b26a4f1cd4af41fcfa622e74d34acb2b0e1d9a8e957ed5680bd33450a876fb6e2d6168bd3ed32419ba5edd669adc8ed4da37d405b3d71474b8df84a2966326e514a45efc7d29d25d1928ec04cba0f5f83e051ebfa9cd64bc00000001650015e2e00000540b00004afff10271c6ff03af5bce66c056cdbf7fc7e7f05b501ab343caa4162528e708b991f6d7101c48005fd652a579f02494edc4fbed23b6f2c87183391ae4fe5f50990af71c255dbc07e66e9360519c4a293d5f657a297185e50c0367b6815cceabf0eef1dbbfe6a69a50d4fcfacce7e71cb8cc43e6b70ada98af4b3230d2e157a3ac3e2f66df13e39b8e99770fd02e74f0b898a102740e6af7dd7bde92ec34ac62cbacc20e17b75d67d81148510533d709d4b017abefbab0965c1e4751f4412114832e1e7a6e50520d630254e39bbb35b4b72b06fb054c04443629bd6f5034ba1b2cd65f1de1527d5935c6e78790a8f2d8cdbed54fe2f1dfdc43c9b5ee8512e2f7c464f084d7162f7c46e0403a2e0a14d7491777aabcddce2084dc89341f8422ac340f67ebe9f9b3881eb7b3dd901f5176d9ad256a5394a9319b3d1128faf4acb20929841879ef09c7826ec0ef6b3134d0d94ebf04f0affb3d7c39f1fa8ef9aa2da08a334750a7200000000165001902e00000540b00004afff10273917fc0ebd32a110ab7f65795b42bdf972c22e41f7993ab6c10047f71449e048e671a134ae7bca777dc838cd953b185e28fb627e49029ea900051e42877ebbdca3f3fd3ebb448ae81dacca85eca13f17e9d2288c1430bdd050e71497b3215e60727102f7bfeaf43722d67bf494b9b4181f2c11682d752b01d4471694bbc6386acd2b29f8b478fe41a4c4df741bc2be5b5a28f70641327b32d0dba5cf21c3555c717970f2d2454c6d87c86868525b3b2dd7114342877cb7bedae7cc586ff13686070e9906dd24b4358a287631671b67d377fd84194eb0f14d200358a79d8c5c212a8c5d66152949b050da561848359b4a284c030bd104be76d56520f5d6f85df5cc942e7ca410bb6874c6f4b7c2916faab5e99a8ad3b8d95deee6c1e79eb8e03a3642f7769f33af6176513fe9b6712ba18abfca8fc7dfe383aa20ca317e7fd33fbf56b89874b4e8272716990a3a5ab5843f6eaa6b037, level=(string)3.1, profile=(string)high
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)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, level=(string)3.1, profile=(string)high, width=(int)1280, height=(int)720, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)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, level=(string)3.1, profile=(string)high, width=(int)1280, height=(int)720, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)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, level=(string)3.1, profile=(string)high
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:3:5:1, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:3:5:1, framerate=(fraction)0/1
It looks like the UDP source is not in H264. You may try H265 or JPEG decoding.
Here is a reference setup:
Gstreamer TCPserversink 2-3 seconds latency - #5 by DaneLLL
May try and see if you can run it successfully
