Here I have tried to execute stress-ng test ON ORIN SOC but it get failed with segmentation fault. Following commands executed
root@Pikachu-NV-ORIN-1:~# ./stress-ng --cpu 0 --timeout 20s --log-file /root/devlib-target/stress_ng_output.txt --yaml /root/devlib-target/stress_ng_results.yaml --metrics-brief --verbose
stress-ng: debug: [3420] 12 processors online, 12 processors configured
stress-ng: info: [3420] dispatching hogs: 12 cpu
stress-ng: info: [3420] cache allocate: default cache size: 2048K
stress-ng: debug: [3420] starting stressors
stress-ng: debug: [3421] stress-ng-cpu: started [3421] (instance 0)
stress-ng: debug: [3423] stress-ng-cpu: started [3423] (instance 2)
stress-ng: debug: [3422] stress-ng-cpu: started [3422] (instance 1)
stress-ng: debug: [3425] stress-ng-cpu: started [3425] (instance 4)
stress-ng: debug: [3424] stress-ng-cpu: started [3424] (instance 3)
stress-ng: debug: [3426] stress-ng-cpu: started [3426] (instance 5)
stress-ng: debug: [3427] stress-ng-cpu: started [3427] (instance 6)
stress-ng: debug: [3429] stress-ng-cpu: started [3429] (instance 8)
stress-ng: debug: [3428] stress-ng-cpu: started [3428] (instance 7)
stress-ng: debug: [3420] 12 stressors spawned
stress-ng: debug: [3430] stress-ng-cpu: started [3430] (instance 9)
stress-ng: debug: [3431] stress-ng-cpu: started [3431] (instance 10)
stress-ng: debug: [3432] stress-ng-cpu: started [3432] (instance 11)
stress-ng: debug: [3423] stress-ng-cpu: exited [3423] (instance 2)
stress-ng: debug: [3426] stress-ng-cpu: exited [3426] (instance 5)
stress-ng: debug: [3429] stress-ng-cpu: exited [3429] (instance 8)
stress-ng: debug: [3432] stress-ng-cpu: exited [3432] (instance 11)
stress-ng: debug: [3430] stress-ng-cpu: exited [3430] (instance 9)
stress-ng: debug: [3425] stress-ng-cpu: exited [3425] (instance 4)
stress-ng: debug: [3428] stress-ng-cpu: exited [3428] (instance 7)
stress-ng: debug: [3421] stress-ng-cpu: exited [3421] (instance 0)
stress-ng: debug: [3420] process [3421] terminated
stress-ng: debug: [3424] stress-ng-cpu: exited [3424] (instance 3)
stress-ng: debug: [3427] stress-ng-cpu: exited [3427] (instance 6)
stress-ng: debug: [3431] stress-ng-cpu: exited [3431] (instance 10)
stress-ng: debug: [3422] stress-ng-cpu: exited [3422] (instance 1)
stress-ng: debug: [3420] process [3422] terminated
stress-ng: debug: [3420] process [3423] terminated
stress-ng: debug: [3420] process [3424] terminated
stress-ng: debug: [3420] process [3425] terminated
stress-ng: debug: [3420] process [3426] terminated
stress-ng: debug: [3420] process [3427] terminated
stress-ng: debug: [3420] process [3428] terminated
stress-ng: debug: [3420] process [3429] terminated
stress-ng: debug: [3420] process [3430] terminated
stress-ng: debug: [3420] process [3431] terminated
stress-ng: debug: [3420] process [3432] terminated
stress-ng: info: [3420] successful run completed in 20.01s
Segmentation fault
If anyone has faced this issue, then let me know
