am using jetson agx orin for my robotics development am running 3 parallel algorithms in 3 terminal which will using GPU on the agx orin board , when iam running the algorithm pc or gpu gets freeze sometimes, i checked with kernel logs and found the below fails on the gpu attaching the log below
[ +16.364213] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013384] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012540] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013293] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012596] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012935] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013175] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[Jul 8 13:34] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013412] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012994] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012764] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012586] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012613] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013093] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013288] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +7.458744] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013828] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011838] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011974] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012092] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011806] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011981] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011968] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +2.398575] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012259] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011908] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011880] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +4.922443] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012826] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011906] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012802] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +7.495666] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.015038] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012283] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012567] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013891] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012688] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012712] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013400] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[Jul 8 13:35] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014883] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012393] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011914] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012944] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013232] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012459] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012128] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +3.661255] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013782] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012649] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012112] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013335] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013235] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012154] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012502] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013994] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013371] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011865] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011945] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011951] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012078] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011927] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012059] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011967] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012010] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011957] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012027] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012047] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012017] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011995] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011990] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012012] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012004] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011987] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012006] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012002] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011978] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011986] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012880] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012410] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012387] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012401] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013068] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012667] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012206] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011983] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012046] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011997] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011964] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012066] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011933] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011973] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011988] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012031] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012050] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012023] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011982] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011971] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012019] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012143] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011851] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011994] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012052] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011901] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012038] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012139] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011905] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012063] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012706] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012417] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012215] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012402] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012560] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012727] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012314] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012255] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011953] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012000] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012028] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012365] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012413] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012399] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012436] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013065] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012680] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012261] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012723] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012414] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012492] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012960] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.002968] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.010170] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.007443] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000006] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000007] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000004] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000002] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.000005] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000002] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000003] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.000003] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000002] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000004] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.000006] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000024] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000004] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.012745] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.009427] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.224086] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012794] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012397] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012233] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012373] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014094] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012438] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012456] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013138] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012290] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012185] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011952] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012418] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012408] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012678] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012932] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012991] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012319] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012060] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011938] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012079] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012026] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011985] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012024] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012145] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011892] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012013] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011955] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012835] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012580] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013100] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012897] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012226] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012691] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012530] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012405] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012406] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013089] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012648] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012207] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012317] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012758] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011685] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012407] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012396] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012988] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012793] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012216] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012204] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011879] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012174] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012330] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012289] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012390] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013124] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012415] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012267] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012209] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011910] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011939] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012299] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012412] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012404] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012409] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012838] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012213] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012025] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012021] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012020] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.000563] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.012722] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.007928] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.002499] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.009383] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.007681] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000003] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000009] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000014] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000001] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000008] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000001] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.000010] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000007] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000010] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.015017] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.584065] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012562] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012210] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012347] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012704] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012986] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +31.642042] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012800] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013057] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013393] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013746] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012741] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012528] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +7.511238] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014141] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012719] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011925] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011751] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011891] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013635] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +1.150706] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013898] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012842] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011834] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011963] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012423] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012306] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012901] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +6.100175] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012108] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013079] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012212] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013197] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012036] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[Jul 8 13:36] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013650] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012445] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012473] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013314] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013075] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +12.783244] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013299] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.001103] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.013094] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.006317] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000015] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.011991] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.010387] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.012522] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.055255] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012832] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012498] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013043] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +16.476800] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013875] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012464] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012049] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012525] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012545] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012979] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014288] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +7.300676] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014338] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012496] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012203] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012803] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014296] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013317] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +7.406468] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013356] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012322] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012169] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012748] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011898] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013789] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +7.356898] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013060] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012132] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012094] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012981] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013584] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013874] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[Jul 8 13:37] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013735] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013570] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012675] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012535] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014348] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011829] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012985] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +4.021282] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012271] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011966] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013592] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013058] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012959] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +10.316838] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +33.372797] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013888] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012244] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012332] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012262] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012071] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011745] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014453] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012087] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012998] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012440] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013086] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012294] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012812] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013069] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012732] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013018] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013012] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013020] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012911] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012221] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012044] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012064] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011950] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012015] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011940] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012561] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013015] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012948] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013048] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012222] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012907] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012679] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013333] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013076] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011970] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012077] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012075] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011954] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011977] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012018] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012062] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011948] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012005] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011999] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012008] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012611] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012458] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012416] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013146] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012721] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011878] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011936] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013006] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012425] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013019] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012906] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012304] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011976] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012009] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012086] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012022] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012574] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012421] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012420] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013244] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012627] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012256] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012437] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.000272] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.012142] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.008016] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000011] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000005] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.010444] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.002288] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.005990] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.002414] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.001218] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.000046] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.009921] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.014367] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.008934] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.012146] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.229810] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012849] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.015722] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +6.065906] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012883] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012717] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012225] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012769] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011929] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.016173] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[Jul 8 13:38] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014639] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011768] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012681] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011902] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013222] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014080] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +7.394359] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.014742] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011896] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011909] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013306] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012912] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013092] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +5.431843] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.015018] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012755] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011842] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011729] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012484] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013290] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012427] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013016] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +9.706086] usb 1-4.3: USB disconnect, device number 6
[ +1.788261] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013996] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012761] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012308] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012652] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012432] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +1.136395] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011899] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012804] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013718] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013163] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012578] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012939] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012875] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011943] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012001] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012165] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011866] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012054] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011984] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012029] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011998] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012100] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012505] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012990] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011965] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012166] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011845] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012065] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011869] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012043] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012274] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011819] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011947] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012033] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012115] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011885] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011989] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012363] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011855] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012403] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012899] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012872] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012173] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012109] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012053] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011888] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011960] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012037] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012260] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012549] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012398] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.008931] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.003476] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.008514] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000033] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.000012] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000006] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.012122] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.002284] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.007534] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.090327] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012746] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012547] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012220] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012127] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012790] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013059] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012157] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012016] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012007] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011972] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011996] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012003] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012035] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012055] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012155] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011861] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011961] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011975] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012011] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011915] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011913] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012232] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011774] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.011980] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012039] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012326] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012669] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012606] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012235] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012160] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.001776] nvgpu: 17000000.ga10b nvgpu_pmu_seq_acquire:131 [ERR] no free sequence available
[ +0.010575] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.008215] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.000005] nvgpu: 17000000.ga10b nvgpu_pmu_rpc_execute:713 [ERR] Failed to execute RPC status=0xfffffff5, func=0x4
[ +0.155255] nvgpu: 17000000.ga10b nvgpu_pmu_perfmon_get_samples_rpc:678 [ERR] Failed to execute RPC, status=0xfffffff5
[ +0.000514] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.023822] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012969] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.012953] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013081] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
[ +0.013528] nvgpu: 17000000.ga10b nvgpu_engine_fb_queue_push:401 [ERR] falcon id-0, queue id-1, failed
