Agx orin gpu无法工作
agx orin 32g
客户自定义板子
软件版本:jp5.1.2
设备运行过程中偶尔出现如下错误,遇到系统很卡,网络也不通,无法正常工作,请问一下,这是什么原因导致的
Jul  9 11:55:38 ubuntu kernel: [251005.240803] nvgpu: 17000000.ga10b            nvgpu_finalize_poweron:1010 [ERR]  Failed initialization for: g->ops.gr.gr_init_support
Jul  9 11:55:38 ubuntu kernel: [251005.275367] nvgpu: 17000000.ga10b nvgpu_gpu_set_deterministic_ch_railgate:1858 [WRN]  cannot busy to restore deterministic ch
Jul  9 11:55:38 ubuntu kernel: [251005.275751] CPU:0, Error: cbb-fabric@0x13a00000, irq=34
Jul  9 11:55:38 ubuntu kernel: [251005.275890] **************************************
Jul  9 11:55:38 ubuntu kernel: [251005.276023] CPU:0, Error:cbb-fabric, Errmon:2
Jul  9 11:55:38 ubuntu kernel: [251005.276136] 	  Error Code		: PWRDOWN_ERR
Jul  9 11:55:38 ubuntu kernel: [251005.278287]
Jul  9 11:55:38 ubuntu kernel: [251005.279856] 	  Error Code		: PWRDOWN_ERR
Jul  9 11:55:38 ubuntu kernel: [251005.284056] 	  MASTER_ID		: CCPLEX
Jul  9 11:55:38 ubuntu kernel: [251005.287729] 	  Address		: 0x17bb0090
Jul  9 11:55:38 ubuntu kernel: [251005.291404] 	  Cache			: 0x0 -- Device Non-Bufferable
Jul  9 11:55:38 ubuntu kernel: [251005.296481] 	  Protection		: 0x2 -- Unprivileged, Non-Secure, Data Access
Jul  9 11:55:38 ubuntu kernel: [251005.303481] 	  Access_Type		: Write
Jul  9 11:55:38 ubuntu kernel: [251005.307155] 	  Access_ID		: 0x7
Jul  9 11:55:38 ubuntu kernel: [251005.307156] 	  Fabric		: cbb-fabric
Jul  9 11:55:38 ubuntu kernel: [251005.314241] 	  Slave_Id		: 0xc
Jul  9 11:55:38 ubuntu kernel: [251005.317392] 	  Burst_length		: 0x0
Jul  9 11:55:38 ubuntu kernel: [251005.321067] 	  Burst_type		: 0x1
Jul  9 11:55:38 ubuntu kernel: [251005.324480] 	  Beat_size		: 0x2
Jul  9 11:55:38 ubuntu kernel: [251005.327806] 	  VQC			: 0x0
Jul  9 11:55:38 ubuntu kernel: [251005.330693] 	  GRPSEC		: 0x7e
Jul  9 11:55:38 ubuntu kernel: [251005.333667] 	  FALCONSEC		: 0x0
Jul  9 11:55:38 ubuntu kernel: [251005.336992] 	**************************************
Jul  9 11:55:38 ubuntu kernel: [251005.341999] ------------[ cut here ]------------
Jul  9 11:55:38 ubuntu kernel: [251005.342010] WARNING: CPU: 0 PID: 224501 at drivers/soc/tegra/cbb/tegra234-cbb.c:577 tegra234_cbb_isr+0x130/0x170
Jul  9 11:55:38 ubuntu kernel: [251005.352130] Modules linked in: fuse(E) veth(E) nf_conntrack_netlink(E) xt_nat(E) iptable_raw(E) xt_conntrack(E) xt_MASQUERADE(E) nfnetlink(E) ip6table_nat(E) ip6table_filter(E) ip6_tables(E) iptable_nat(E) nf_nat(E) nf_conntrack(E) nf_defrag_ipv6(E) nf_defrag_ipv4(E) libcrc32c(E) xt_addrtype(E) nvidia_modeset(OE) mttcan(E) can_dev(E) can_raw(E) can(E) iptable_filter(E) xt_tcpudp(E) lzo_rle(E) lzo_compress(E) zram(E) overlay(E) ramoops(E) reed_solomon(E) loop(E) nvgpu(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) aes_ce_cipher(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_asrc(E) snd_soc_tegra186_dspk(E) ghash_ce(E) snd_soc_tegra186_arad(E) r8168(E) snd_soc_tegra210_iqc(E) snd_soc_tegra210_mvc(E) snd_soc_tegra210_afc(E) snd_hda_codec_hdmi(E) snd_soc_tegra210_dmic(E) sha2_ce(E) ahci(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_amx(E) snd_hda_tegra(E) binfmt_misc(E) snd_soc_tegra210_admaif(E) snd_soc_tegra210_adsp(E) sha256_arm64(E) snd_soc_tegra210_i2s(E) libahci(E) snd_soc_tegra210_mixer(E)
Jul  9 11:55:38 ubuntu kernel: [251005.352198]  snd_soc_tegra_machine_driver(E) sha1_ce(E) ucsi_ccg(E) snd_soc_tegra_pcm(E) snd_hda_codec(E) snd_soc_tegra210_sfc(E) libata(E) snd_soc_tegra_utils(E) nvadsp(E) typec_ucsi(E) snd_hda_core(E) snd_soc_simple_card_utils(E) pwm_fan(E) snd_soc_spdif_tx(E) snd_soc_tegra210_ahub(E) typec(E) snd_soc_cs42l42(E) tegra_bpmp_thermal(E) ina3221(E) nct1008(E) tegra210_adma(E) userspace_alert(E) spi_tegra114(E) nvidia(OE) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
Jul  9 11:55:38 ubuntu kernel: [251005.352234] CPU: 0 PID: 224501 Comm: DA5742631_R Tainted: G           OE     5.10.104-tegra #6
Jul  9 11:55:38 ubuntu kernel: [251005.352235] Hardware name: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 3.1-32827747 03/19/2023
Jul  9 11:55:38 ubuntu kernel: [251005.352238] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
Jul  9 11:55:38 ubuntu kernel: [251005.352240] pc : tegra234_cbb_isr+0x130/0x170
Jul  9 11:55:38 ubuntu kernel: [251005.352241] lr : tegra234_cbb_isr+0x10c/0x170
Jul  9 11:55:38 ubuntu kernel: [251005.352242] sp : ffff800010003e10
Jul  9 11:55:38 ubuntu kernel: [251005.352243] x29: ffff800010003e10 x28: ffff39c89d208e80
Jul  9 11:55:38 ubuntu kernel: [251005.352245] x27: 0000000000000001 x26: 0000000000000080
Jul  9 11:55:38 ubuntu kernel: [251005.352247] x25: ffffd6d7077d5900 x24: ffffd6d70812ce40
Jul  9 11:55:38 ubuntu kernel: [251005.352249] x23: ffffd6d707ab7000 x22: 0000000000000022
Jul  9 11:55:38 ubuntu kernel: [251005.352251] x21: ffffd6d707f4f1a0 x20: 0000000000000002
Jul  9 11:55:38 ubuntu kernel: [251005.352253] x19: ffffd6d707f4f190 x18: 0000000000000010
Jul  9 11:55:38 ubuntu kernel: [251005.352255] x17: 0000000000000000 x16: ffffd6d7060b3210
Jul  9 11:55:38 ubuntu kernel: [251005.352257] x15: ffff39c89d2093f0 x14: ffffffffffffffff
Jul  9 11:55:38 ubuntu kernel: [251005.352259] x13: ffff800090003917 x12: ffff800010003920
Jul  9 11:55:38 ubuntu kernel: [251005.352261] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
Jul  9 11:55:38 ubuntu kernel: [251005.352263] x9 : ffff800010003c30 x8 : 2a2a2a2a2a2a2a2a
Jul  9 11:55:38 ubuntu kernel: [251005.352265] x7 : 2a2a2a2a2a2a2a09 x6 : c0000000ffffefff
Jul  9 11:55:38 ubuntu kernel: [251005.352267] x5 : ffff39ceaeb1f958 x4 : ffffd6d707dd7be8
Jul  9 11:55:38 ubuntu kernel: [251005.352268] x3 : 0000000000000000 x2 : ffffd6d70624e170
Jul  9 11:55:38 ubuntu kernel: [251005.352270] x1 : ffff39c89d208e80 x0 : 0000000100010000
Jul  9 11:55:38 ubuntu kernel: [251005.352273] Call trace:
Jul  9 11:55:38 ubuntu kernel: [251005.352275]  tegra234_cbb_isr+0x130/0x170
Jul  9 11:55:38 ubuntu kernel: [251005.352280]  __handle_irq_event_percpu+0x68/0x2a0
Jul  9 11:55:38 ubuntu kernel: [251005.352282]  handle_irq_event_percpu+0x40/0xa0
Jul  9 11:55:38 ubuntu kernel: [251005.352284]  handle_irq_event+0x50/0xf0
Jul  9 11:55:38 ubuntu kernel: [251005.352286]  handle_fasteoi_irq+0xc0/0x170
Jul  9 11:55:38 ubuntu kernel: [251005.352288]  generic_handle_irq+0x40/0x60
Jul  9 11:55:38 ubuntu kernel: [251005.352290]  __handle_domain_irq+0x70/0xd0
Jul  9 11:55:38 ubuntu kernel: [251005.352293]  gic_handle_irq+0x68/0x134
Jul  9 11:55:38 ubuntu kernel: [251005.352294]  el1_irq+0xd0/0x180
Jul  9 11:55:38 ubuntu kernel: [251005.352297]  el0_svc_common.constprop.0+0x48/0x1d0
Jul  9 11:55:38 ubuntu kernel: [251005.352299]  do_el0_svc+0x38/0xb0
Jul  9 11:55:38 ubuntu kernel: [251005.352303]  el0_svc+0x1c/0x30
Jul  9 11:55:38 ubuntu kernel: [251005.352305]  el0_sync_handler+0xa8/0xb0
Jul  9 11:55:38 ubuntu kernel: [251005.352306]  el0_sync+0x16c/0x180
Jul  9 11:55:38 ubuntu kernel: [251005.352307] ---[ end trace ffaa7128db814e10 ]---
Jul  9 11:55:38 ubuntu kernel: [251005.419293] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:38 ubuntu kernel: [251005.421617] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.423435] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.425745] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.427158] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.429452] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.431155] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.433290] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.439169] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.449602] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.459150] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.469083] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.479139] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.490224] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.500891] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.510396] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.520019] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.531147] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.541676] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.551137] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.561925] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.572370] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.582370] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.592610] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.602858] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.612779] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.623144] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.633539] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.643142] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.655137] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
Jul  9 11:55:39 ubuntu kernel: [251005.664574] nvgpu: 17000000.ga10b        nvgpu_engine_fb_queue_push:401  [ERR]  falcon id-0, queue id-1, failed
syslog.7.10.log (66.8 MB)
kernel_error_11_55.txt (130.2 KB)
Any specific repro steps? Failure rate?
Can you try with newer JetPack SW?
复现概率比较低,10台设备左右,半年就出现2次。
主要复现概率很低,我问问客户愿不愿意用jp6.2的版本试试
Recommend upgrading to JP6.2, as some GPU fixes that are not merged in 5.1.2.
jp5.1.5的版本有解决此问题吗
或者jp5.X的有解决此问题的吗
Please try JP 5.1.6 instead from Jetson Linux | NVIDIA Developer
收到,我们在jp5.1.6上试试
~0812
Wait for update.
