Orin GPU crash with Qt QML graphical effects
Orin AGX Dev Kit with factory image running Qt 5.15.2 framework with a custom app built using Qt Quick and QML. Had no issues until introducing features from QtGraphicalEffects 1.12 but now a few times a day at seemingly random times the Ubuntu desktop crashes (goes black) and then shows the user login screen. After logging back in ‘sudo dmesg’ displays the output below. By removing some of the animations of ColorOverlay the issue seems less frequent, but it is very inconsistent and I have not found a way to force the failure to occur.
L4T version of my board:
# R35 (release), REVISION: 1.0, GCID: 31346300, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 25 18:41:45 UTC 2022
[75138.626951] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:92   [ERR]  Error reporting is not supported in this platform
[75138.627380] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(0), offset(0)
[75138.627771] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.628205] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.628614] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(0), offset(0)
[75138.628960] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.629318] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.630998] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(1), offset(2048)
[75138.633093] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.641276] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.653698] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(1), offset(2048)
[75138.666120] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.677317] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.689384] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(2), offset(4096)
[75138.701852] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.712713] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.725006] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(2), offset(4096)
[75138.737299] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.748276] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.760521] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(3), offset(6144)
[75138.773174] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.784048] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.796540] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(0), tpc_id(3), offset(6144)
[75138.808590] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.819450] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.831861] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(0), offset(32768)
[75138.844399] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.855377] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.867576] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(0), offset(32768)
[75138.880372] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.891560] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.904238] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(1), offset(34816)
[75138.916013] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.926965] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.939180] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(1), offset(34816)
[75138.951709] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.962556] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75138.974977] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(2), offset(36864)
[75138.987476] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75138.998483] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75139.010647] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(2), offset(36864)
[75139.023008] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75139.034207] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75139.046325] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(3), offset(38912)
[75139.058736] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75139.069815] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75139.082576] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365  [ERR]  sm machine check err. gpc_id(1), tpc_id(3), offset(38912)
[75139.094621] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:377  [ERR]  sm hww global 0x00000004 warp 0x0b000020
[75139.105501] nvgpu: 17000000.ga10b gr_intr_handle_exception_interrupts:759  [ERR]  set gr exception notifier
[75139.115301] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 13 for ch 503
[75139.125739] __ga10b__ Channel Status - chip ga10b
[75139.125741] __ga10b__ ---------------------------
[75139.130392] __ga10b__ 503-ga10b, TSG: 4, pid 834084, refs: 5, deterministic: no, domain name: (default)
[75139.135042] __ga10b__ channel status:  in use on_eng, pending, eng_busy busy
[75139.144419] __ga10b__ RAMFC: TOP: 8000001ffdd42c50 PUT: 001ffdd42c9c GET: 001ffdd42c50 FETCH: 000000000000 HEADER: 20060028 COUNT: 11110004 SEMAPHORE: addr 001ffd17eba0 payload 0000000000000a72 execute 02000001
[75139.151504] __ga10b__
[75139.170340] __ga10b__ 504-ga10b, TSG: 5, pid 834084, refs: 2, deterministic: no, domain name: (default)
[75139.173039] __ga10b__ channel status:  in use idle not busy
[75139.182650] __ga10b__ RAMFC: TOP: 8000002004300050 PUT: 002004300050 GET: 002004300050 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004030000 payload 0000000000000000 execute 00100001
[75139.187849] __ga10b__
[75139.206959] __ga10b__ 505-ga10b, TSG: 6, pid 834161, refs: 2, deterministic: no, domain name: (default)
[75139.209555] __ga10b__ channel status:  in use idle not busy
[75139.218761] __ga10b__ RAMFC: TOP: 8000002004318050 PUT: 002004318050 GET: 002004318050 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004360000 payload 0000000000000000 execute 00100001
[75139.224541] __ga10b__
[75139.243297] __ga10b__ 508-ga10b, TSG: 3, pid 4204, refs: 2, deterministic: no, domain name: (default)
[75139.245817] __ga10b__ channel status:  in use idle not busy
[75139.255142] __ga10b__ RAMFC: TOP: 80000020040080a0 PUT: 0020040080a0 GET: 0020040080a0 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[75139.260886] __ga10b__
[75139.279621] __ga10b__ 509-ga10b, TSG: 2, pid 3684, refs: 2, deterministic: no, domain name: (default)
[75139.282184] __ga10b__ channel status:  in use idle not busy
[75139.291571] __ga10b__ RAMFC: TOP: 8000002004008c30 PUT: 002004008c30 GET: 002004008c30 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[75139.297365] __ga10b__
[75139.316074] __ga10b__ 510-ga10b, TSG: 1, pid 3226, refs: 2, deterministic: no, domain name: (default)
[75139.318480] __ga10b__ channel status:  in use idle not busy
[75139.327507] __ga10b__ RAMFC: TOP: 8000002004033f50 PUT: 002004033f50 GET: 002004033f50 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[75139.333452] __ga10b__
[75139.352104] __ga10b__ 511-ga10b, TSG: 0, pid 3226, refs: 3, deterministic: no, domain name: (default)
[75139.354722] __ga10b__ channel status:  in use on_pbdma, on_eng, pbdma_busy, eng_busy busy
[75139.363724] __ga10b__ RAMFC: TOP: 800000200404d548 PUT: 00200404d548 GET: 00200404d548 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[75139.372182] __ga10b__
[75139.391034] __ga10b__ PBDMA Status - chip ga10b
[75139.393413] __ga10b__ -------------------------
[75139.397873] __ga10b__ pbdma 0:
[75139.402397] __ga10b__   id: 0 - [tsg]     next_id: - -1 [channel] | status: valid
[75139.405544] __ga10b__   PBDMA_PUT 0000001ffc195f10 PBDMA_GET 0000001ffc195ef8
[75139.413221] __ga10b__   GP_PUT    00001be2  GP_GET  00001be1  FETCH   00001be2 HEADER 20001b0c
[75139.420309] __ga10b__   HDR       200406c0  SHADOW0 fc195ef8  SHADOW1 0000181f
[75139.429002] __ga10b__ pbdma 1:
[75139.436117] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75139.439063] __ga10b__   PBDMA_PUT 00000034ba19e754 PBDMA_GET 000000cb30397cc8
[75139.446968] __ga10b__   GP_PUT    00000000  GP_GET  2278716a  FETCH   00000000 HEADER 81432440
[75139.454301] __ga10b__   HDR       85e7bf38  SHADOW0 77c2b500  SHADOW1 2503381b
[75139.462748] __ga10b__ pbdma 2:
[75139.469714] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75139.472842] __ga10b__   PBDMA_PUT 00000039c1f4e9c8 PBDMA_GET 00000054f6236db8
[75139.480701] __ga10b__   GP_PUT    00000000  GP_GET  58f60b88  FETCH   00000000 HEADER e051047c
[75139.487898] __ga10b__   HDR       4e350290  SHADOW0 d5a8c5a7  SHADOW1 039c1814
[75139.496487] __ga10b__ pbdma 3:
[75139.503649] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75139.506776] __ga10b__   PBDMA_PUT 00000073e4f772f8 PBDMA_GET 000000b2acc4d244
[75139.514482] __ga10b__   GP_PUT    00000000  GP_GET  1f570db0  FETCH   00000000 HEADER e1962014
[75139.521699] __ga10b__   HDR       75233d82  SHADOW0 ed6a4e80  SHADOW1 e1981800
[75139.530293] __ga10b__ pbdma 4:
[75139.537630] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75139.540615] __ga10b__   PBDMA_PUT 00000066825b0294 PBDMA_GET 000000e580343fd4
[75139.548437] __ga10b__   GP_PUT    00000000  GP_GET  888f129b  FETCH   00000000 HEADER 01c7c874
[75139.555577] __ga10b__   HDR       aa025c13  SHADOW0 1ca4298e  SHADOW1 8e1060a0
[75139.564362] __ga10b__ pbdma 5:
[75139.571570] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75139.574640] __ga10b__   PBDMA_PUT 00000082f602b398 PBDMA_GET 00000016d46d231c
[75139.582461] __ga10b__   GP_PUT    00000000  GP_GET  02c12618  FETCH   00000000 HEADER 20110218
[75139.589683] __ga10b__   HDR       f156d4f6  SHADOW0 84a46301  SHADOW1 4210a006
[75139.598236] __ga10b__
[75139.605451] __ga10b__ ga10b eng 0:
[75139.607976] __ga10b__ id: 4 (tsg), next_id: 0 (tsg), ctx status: switch
[75139.611658] __ga10b__ busy
[75139.618496] __ga10b__
[75139.621291] __ga10b__ ga10b eng 1:
[75139.623726] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75139.627409] __ga10b__
[75139.635391] __ga10b__ ga10b eng 2:
[75139.637825] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75139.641463] __ga10b__
[75139.649250] __ga10b__ ga10b eng 3:
[75139.651817] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75139.655498] __ga10b__
[75139.663319] __ga10b__ ga10b eng 4:
[75139.665841] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75139.669498] __ga10b__
[75139.677186] __ga10b__ ga10b eng 5:
[75139.679625] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75139.683325] __ga10b__
[75139.690955] __ga10b__
[75139.713589] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75139.713979] nvgpu: 17000000.ga10b gv11b_mm_mmu_fault_handle_buf_valid_entry:525  [ERR]  page fault error: err_type = 0x8, fault_status = 0x200
[75139.720254] nvgpu: 17000000.ga10b      gv11b_fb_mmu_fault_info_dump:294  [ERR]  [MMU FAULT] mmu engine id:  64, ch id:  503, fault addr: 0x1ff4000000, fault addr aperture: 0, fault type: invalid pte, access type: virt read,
[75139.739830] nvgpu: 17000000.ga10b      gv11b_fb_mmu_fault_info_dump:307  [ERR]  [MMU FAULT] protected mode: 0, client type: gpc, client id:  t1_1, gpc id if client type is gpc: 0,
[75139.755361] nvgpu: 17000000.ga10b gv11b_mm_mmu_fault_handle_mmu_fault_refch:388  [ERR]  chid: 503 is referenceable but not bound to tsg
[75139.767349] nvgpu: 17000000.ga10b                nvgpu_rc_mmu_fault:352  [ERR]  mmu fault id=503 id_type=0 act_eng_bitmask=00000001
[75139.780495] __ga10b__ Channel Status - chip ga10b
[75139.780497] __ga10b__ ---------------------------
[75139.784134] __ga10b__ 503-ga10b, TSG: 4294967295, pid 834084, refs: 2, deterministic: no, domain name: (no tsg)
[75139.788831] __ga10b__ channel status: not in use idle not busy
[75139.799075] __ga10b__ RAMFC: TOP: 8000001ffdd42c50 PUT: 001ffdd42c9c GET: 001ffdd42c50 FETCH: 000000000000 HEADER: 20060028 COUNT: 11110004 SEMAPHORE: addr 001ffd17eba0 payload 0000000000000a72 execute 02000001
[75139.805059] __ga10b__
[75139.824130] __ga10b__ 504-ga10b, TSG: 5, pid 834084, refs: 2, deterministic: no, domain name: (default)
[75139.826487] __ga10b__ channel status:  in use idle not busy
[75139.835732] __ga10b__ RAMFC: TOP: 8000002004300050 PUT: 002004300050 GET: 002004300050 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004030000 payload 0000000000000000 execute 00100001
[75139.841566] __ga10b__
[75139.860314] __ga10b__ 505-ga10b, TSG: 6, pid 834161, refs: 2, deterministic: no, domain name: (default)
[75139.862939] __ga10b__ channel status:  in use idle not busy
[75139.872157] __ga10b__ RAMFC: TOP: 8000002004318050 PUT: 002004318050 GET: 002004318050 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004360000 payload 0000000000000000 execute 00100001
[75139.877899] __ga10b__
[75139.896579] __ga10b__ 508-ga10b, TSG: 3, pid 4204, refs: 2, deterministic: no, domain name: (default)
[75139.899207] __ga10b__ channel status:  in use idle not busy
[75139.908352] __ga10b__ RAMFC: TOP: 80000020040080a0 PUT: 0020040080a0 GET: 0020040080a0 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[75139.914085] __ga10b__
[75139.932946] __ga10b__ 509-ga10b, TSG: 2, pid 3684, refs: 2, deterministic: no, domain name: (default)
[75139.935474] __ga10b__ channel status:  in use idle not busy
[75139.944692] __ga10b__ RAMFC: TOP: 8000002004008c30 PUT: 002004008c30 GET: 002004008c30 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004010000 payload 0000000000000000 execute 00100001
[75139.950461] __ga10b__
[75139.969472] __ga10b__ 510-ga10b, TSG: 1, pid 3226, refs: 2, deterministic: no, domain name: (default)
[75139.971965] __ga10b__ channel status:  in use idle not busy
[75139.980958] __ga10b__ RAMFC: TOP: 8000002004033f50 PUT: 002004033f50 GET: 002004033f50 FETCH: 000000000000 HEADER: 2140006c COUNT: 00000000 SEMAPHORE: addr 002004320000 payload 0000000000000000 execute 00000001
[75139.986739] __ga10b__
[75140.005420] __ga10b__ 511-ga10b, TSG: 0, pid 3226, refs: 3, deterministic: no, domain name: (default)
[75140.007885] __ga10b__ channel status:  in use on_pbdma, on_eng, pbdma_busy, eng_busy busy
[75140.017010] __ga10b__ RAMFC: TOP: 8000001ffc195ef8 PUT: 001ffc195f10 GET: 001ffc195ef8 FETCH: 000000000000 HEADER: 20001b0c COUNT: 00090001 SEMAPHORE: addr 002004020000 payload 0000000000000000 execute 00100001
[75140.025448] __ga10b__
[75140.044179] __ga10b__ PBDMA Status - chip ga10b
[75140.046606] __ga10b__ -------------------------
[75140.051172] __ga10b__ pbdma 0:
[75140.055677] __ga10b__   id: 0 - [tsg]     next_id: - -1 [channel] | status: valid
[75140.058793] __ga10b__   PBDMA_PUT 000000200404d570 PBDMA_GET 000000200404d570
[75140.066457] __ga10b__   GP_PUT    00001be2  GP_GET  00001be2  FETCH   00001be2 HEADER 2140006c
[75140.073619] __ga10b__   HDR       2001001b  SHADOW0 0404d548  SHADOW1 00002820
[75140.082277] __ga10b__ pbdma 1:
[75140.089493] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75140.092356] __ga10b__   PBDMA_PUT 00000034ba19e754 PBDMA_GET 000000cb30397cc8
[75140.100244] __ga10b__   GP_PUT    00000000  GP_GET  2278716a  FETCH   00000000 HEADER 81432440
[75140.107595] __ga10b__   HDR       85e7bf38  SHADOW0 77c2b500  SHADOW1 2503381b
[75140.116161] __ga10b__ pbdma 2:
[75140.123049] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75140.126069] __ga10b__   PBDMA_PUT 00000039c1f4e9c8 PBDMA_GET 00000054f6236db8
[75140.133880] __ga10b__   GP_PUT    00000000  GP_GET  58f60b88  FETCH   00000000 HEADER e051047c
[75140.141063] __ga10b__   HDR       4e350290  SHADOW0 d5a8c5a7  SHADOW1 039c1814
[75140.149684] __ga10b__ pbdma 3:
[75140.156967] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75140.159963] __ga10b__   PBDMA_PUT 00000073e4f772f8 PBDMA_GET 000000b2acc4d244
[75140.167810] __ga10b__   GP_PUT    00000000  GP_GET  1f570db0  FETCH   00000000 HEADER e1962014
[75140.175149] __ga10b__   HDR       75233d82  SHADOW0 ed6a4e80  SHADOW1 e1981800
[75140.183748] __ga10b__ pbdma 4:
[75140.190958] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75140.193961] __ga10b__   PBDMA_PUT 00000066825b0294 PBDMA_GET 000000e580343fd4
[75140.201768] __ga10b__   GP_PUT    00000000  GP_GET  888f129b  FETCH   00000000 HEADER 01c7c874
[75140.208855] __ga10b__   HDR       aa025c13  SHADOW0 1ca4298e  SHADOW1 8e1060a0
[75140.217617] __ga10b__ pbdma 5:
[75140.224869] __ga10b__   id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[75140.227839] __ga10b__   PBDMA_PUT 00000082f602b398 PBDMA_GET 00000016d46d231c
[75140.235752] __ga10b__   GP_PUT    00000000  GP_GET  02c12618  FETCH   00000000 HEADER 20110218
[75140.243045] __ga10b__   HDR       f156d4f6  SHADOW0 84a46301  SHADOW1 4210a006
[75140.251504] __ga10b__
[75140.258889] __ga10b__ ga10b eng 0:
[75140.261324] __ga10b__ id: 0 (tsg), next_id: -1 (channel), ctx status: valid
[75140.264981] __ga10b__ busy
[75140.272048] __ga10b__
[75140.275021] __ga10b__ ga10b eng 1:
[75140.277428] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75140.281066] __ga10b__
[75140.289101] __ga10b__ ga10b eng 2:
[75140.291536] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75140.295025] __ga10b__
[75140.302738] __ga10b__ ga10b eng 3:
[75140.305417] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75140.308891] __ga10b__
[75140.316831] __ga10b__ ga10b eng 4:
[75140.319389] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75140.323045] __ga10b__
[75140.330760] __ga10b__ ga10b eng 5:
[75140.333171] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[75140.336811] __ga10b__
[75140.344480] __ga10b__
[75140.360856] nvgpu: 17000000.ga10b gv11b_fifo_locked_abort_runlist_active_tsgs:67   [ERR]  abort active tsgs of runlists set in runlists_mask: 0x00000001
[75140.362886] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 0 generated a mmu fault
[75140.372530] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 511
[75140.382954] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 1 generated a mmu fault
[75140.392496] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 510
[75140.402649] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 2 generated a mmu fault
[75140.411984] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 509
[75140.422331] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 3 generated a mmu fault
[75140.432203] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 508
[75140.442486] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 5 generated a mmu fault
[75140.452365] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 504
[75140.462710] nvgpu: 17000000.ga10b       nvgpu_tsg_set_ctx_mmu_error:648  [ERR]  TSG 6 generated a mmu fault
[75140.472743] nvgpu: 17000000.ga10b     nvgpu_set_err_notifier_locked:149  [ERR]  error notifier set to 31 for ch 505
[75140.483764] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55   [ERR]  Error reporting is not supported in this platform
[75140.495540] nvgpu: 17000000.ga10b      ga10b_fifo_ctxsw_timeout_isr:277  [ERR]  Host pfifo ctxsw timeout error
[75151.055436] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[75151.055440] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[75151.777379] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
[75151.778079] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
[75151.780585] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[75151.849066] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[75151.849367] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
[75152.221490] dce: dce_ipc_read_message:678  Error getting next free buf to read
[75152.221502] dce: dce_client_process_event_ipc:319  Error in reading DCE msg for ch_type [3]
[75152.221509] dce: dce_ipc_read_message:678  Error getting next free buf to read
[75152.221515] dce: dce_client_process_event_ipc:319  Error in reading DCE msg for ch_type [3]
[75161.910477] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD data byte 1
The latest release is Jetpack 5.1.1(r35.3.1). Please upgrade to the release and try. See if it is still present on latest release or has been fixed.
