Sudo apt-get update issue
Ok, now I’m having the same problem. New Install of Jetson AGX Xavier. The SDK installer kept failing installing the target tools and eventually I traced it down to this.
$ sudo apt update
Hit:1 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Get:3 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease [2,565 B]
Hit:4 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
Get:7 https://repo.download.nvidia.com/jetson/t194 r32.4/main arm64 Packages [20.5 kB]
Err:7 https://repo.download.nvidia.com/jetson/t194 r32.4/main arm64 Packages
  File has unexpected size (16348 != 20547). Mirror sync in progress? [IP: 23.38.112.80 443]
  Hashes of expected file:
   - Filesize:20547 [weak]
   - SHA256:4d91f844a54139dc1f90943be413599f35f6955eb5ad576a28ee5a865a845ddf
   - SHA1:ca8b7235d5af9a8f62e5d7681690df304a3898aa [weak]
   - MD5Sum:702c20f887d4d08a0293e31e4401db6f [weak]
  Release file created at: Wed, 21 Oct 2020 14:36:39 +0000
Fetched 2,565 B in 3s (984 B/s)
Reading package lists... Done
E: Failed to fetch https://repo.download.nvidia.com/jetson/t194/dists/r32.4/main/binary-arm64/Packages.gz  File has unexpected size (16348 != 20547). Mirror sync in progress? [IP: 23.38.112.80 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
jetson@Xavier:~$
I’ve been having this problem all day. Multiple clean installs and fresh flashes of the Xavier kit. This is clearly a recurring issue. Can someone at NVIDIA please fix this?
Not that I think it matters, but since it’s been asked before, I’ve tried running this repeatedly from maybe 10:00 to now, 1:30, US Eastern time.
Hi john.c.schwartz,
Not sure if issue has been resolved, if not, please help to open a new topic for your issue. Thanks
Still getting the same issue on update File has unexpected size (16348 != 20547). Mirror sync in progress? @WayneWWW
nvidia@nvidia-desktop:~$ cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
deb https://repo.download.nvidia.com/jetson/common r32.4 main
deb https://repo.download.nvidia.com/jetson/t194 r32.4 main
nvidia@nvidia-desktop:~$ sudo apt-get clean
nvidia@nvidia-desktop:~$ sudo apt-get update
Get:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Ign:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Get:2 file:/var/cuda-repo-10-2-local-10.2.89 Release [574 B]
Hit:3 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Hit:4 Index of /ubuntu-ports bionic InRelease
Get:5 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease [2,565 B]
Hit:7 Index of /ubuntu-ports bionic-updates InRelease
Hit:8 Index of /ubuntu-ports bionic-backports InRelease
Hit:9 Index of /ubuntu-ports bionic-security InRelease
Get:10 https://repo.download.nvidia.com/jetson/t194 r32.4/main arm64 Packages [20.5 kB]
Err:10 https://repo.download.nvidia.com/jetson/t194 r32.4/main arm64 Packages
File has unexpected size (16348 != 20547). Mirror sync in progress? [IP: 23.194.190.169 443]
  • Filesize:20547 [weak]
  • SHA256:4d91f844a54139dc1f90943be413599f35f6955eb5ad576a28ee5a865a845ddf
  • SHA1:ca8b7235d5af9a8f62e5d7681690df304a3898aa [weak]
  • MD5Sum:702c20f887d4d08a0293e31e4401db6f [weak]
    Fetched 2,565 B in 2s (1,456 B/s)
    Reading package lists… Done
    E: Failed to fetch https://repo.download.nvidia.com/jetson/t194/dists/r32.4/main/binary-arm64/Packages.gz File has unexpected size (16348 != 20547). Mirror sync in progress? [IP: 23.194.190.169 443]
Same here @kayccc
File has unexpected size (20547 != 16348). Mirror sync in progress? [IP: 2.23.84.222 443]
 - Filesize:16348 [weak]
 - SHA256:8859c6b21ae2b670e4f61c112e14312fc6af680cc972b0810ca1560e3d77ceb2
 - SHA1:75b6c30fbfa9ef08aa42375e48045214b24c786e [weak]
 - MD5Sum:000df3cc102579db84a10ca1430f2744 [weak]
Release file created at: Thu, 08 Oct 2020 08:32:21 +0000
Fetched 2 562 B in 2s (1 311 B/s)
E: Failed to fetch https://repo.download.nvidia.com/jetson/t194/dists/r32.4/main/binary-arm64/Packages.gz  File has unexpected size (20547 != 16348). Mirror sync in progress? [IP: 2.23.84.222 443]
Same here. I ran
sudo apt-get update
on a fresh installation and got the following:
Get:20 https://repo.download.nvidia.com/jetson/t194 r32.4/main arm64 Packages [20.5 kB]
Err:20 https://repo.download.nvidia.com/jetson/t194 r32.4/main arm64 Packages
    Fetched 2,565 B in 3s (778 B/s)
Same issue here, it has been going on since Oct 30th at least. The problematic file is:
https://repo.download.nvidia.com/jetson/common/dists/r32.4/InRelease
There seems to be an outdated version of this file on the CDN. Here it is.
https://pastebin.com/McY1QANL
I have been able to work around the issue by adding an entry for repo.download.nvidia.com to my /etc/hosts file.
95.100.95.160 repo.download.nvidia.com
Just did a fresh install and get
`user@user-desktop:~$ sudo apt-get update
[sudo] password for user:
Hit:1 https://repo.download.nvidia.com/jetson/common r32.5 InRelease
Get:2 https://repo.download.nvidia.com/jetson/t186 r32.5 InRelease [2,561 B]
Hit:3 Index of /ubuntu-ports bionic InRelease
Hit:4 Index of /ubuntu-ports bionic-updates InRelease
Hit:5 Index of /ubuntu-ports bionic-backports InRelease
Hit:6 Index of /ubuntu-ports bionic-security InRelease
Get:7 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 Packages [18.0 kB]
Err:7 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 Packages
File has unexpected size (18512 != 18039). Mirror sync in progress? [IP: 104.93.21.89 443]
  • Filesize:18039 [weak]
  • SHA256:16750924cb0ea9e1c24fe42eb36f8b4deeb46ca37be93b9dfe925860780b1090
  • SHA1:a764566161b3d34ac509e0e725c47a5b5a2a8e36 [weak]
  • MD5Sum:46176352024c08e1d53b5e8f6e6388ba [weak]
    Release file created at: Wed, 26 May 2021 17:02:50 +0000
    Fetched 2,561 B in 1s (1,707 B/s)
    E: Failed to fetch https://repo.download.nvidia.com/jetson/t186/dists/r32.5/main/binary-arm64/Packages.gz File has unexpected size (18512 != 18039). Mirror sy]
    - Filesize:18039 [weak]
    - SHA256:16750924cb0ea9e1c24fe42eb36f8b4deeb46ca37be93b9dfe925860780b1090
    - SHA1:a764566161b3d34ac509e0e725c47a5b5a2a8e36 [weak]
    - MD5Sum:46176352024c08e1d53b5e8f6e6388ba [weak]
    E: Some index files failed to download. They have been ignored, or old ones used instead. `
