Problem with sudo apt-get update
I believe it maybe the same issue as here Sudo apt-get update issue - #27 by joseph.l.rogers
I am trying to restall jetpack and SDK. Jetpack 5.01 installs fine but then SDKmanger isn’t able to install SDKs due to APT probelm. I did try with Jetpack 4.6.1 and it installed but jetpack 5.0.1 has problems.
I am located in Australia
sudo apt-get update gives me hash errors on the Jetson
shane@robot:~$ sudo apt-get update
[sudo] password for shane:
Get:1 https://repo.download.nvidia.com/jetson/common r34.1 InRelease [2,555 B]
Hit:2 https://repo.download.nvidia.com/jetson/t194 r34.1 InRelease
Hit:3 Index of /ubuntu-ports focal InRelease
Get:4 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 Packages [16.6 kB]
Err:4 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 Packages
File has unexpected size (17070 != 16554). Mirror sync in progress? [IP: 23.200.140.56 443]
Hashes of expected file:
  • Filesize:16554 [weak]
  • SHA256:f2331696ed395f3381b2b9343b9ec80449956d887ac91c314a618a7a184fb9e6
  • SHA1:115b6b57641ed921f39be5a3256c824bb54d3e2f [weak]
  • MD5Sum:1082b95c354b22fe6bf6e3702f88d991 [weak]
    Release file created at: Wed, 22 Jun 2022 06:18:55 +0000
    Hit:5 Index of /ubuntu-ports focal-updates InRelease
    Hit:6 Index of /ubuntu-ports focal-backports InRelease
    Hit:7 Index of /ubuntu-ports focal-security InRelease
    Fetched 2,555 B in 3s (891 B/s)
    Reading package lists… Done
    E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r34.1/main/binary-arm64/Packages.gz File has unexpected size (17070 != 16554). Mirror sync in progress? [IP: 23.200.140.56 443]
    - Filesize:16554 [weak]
    - SHA256:f2331696ed395f3381b2b9343b9ec80449956d887ac91c314a618a7a184fb9e6
    - SHA1:115b6b57641ed921f39be5a3256c824bb54d3e2f [weak]
    - MD5Sum:1082b95c354b22fe6bf6e3702f88d991 [weak]
    E: Some index files failed to download. They have been ignored, or old ones used instead.
Not sure if that’s related with the mirror server, will check with relevant team.
Seems the server is responding again and now everything is working again.
Great! The server is back now. Thanks for the confirmation.
