Apt-get update
I just flash the Jetson Xavier but now when i do sudo apt-get update i have this problem :
Get:8 https://repo.download.nvidia.com/jetson/ffmpeg r35.5/main arm64 Packages [2937 B]
Err:8 https://repo.download.nvidia.com/jetson/ffmpeg r35.5/main arm64 Packages
  File has unexpected size (2985 != 2937). Mirror sync in progress? [IP: 88.221.92.25 443]
  Hashes of expected file:
   - Filesize:2937 [weak]
   - SHA256:1a76e1231d6dcb6d7505ce92b1bed86f9463448a41c1163d6d829d1d0fcd5815
   - SHA1:513794598918030a8c4019150f4b86fb9666ed0a [weak]
   - MD5Sum:ee244ea061452c67151a76ab42430756 [weak]
  Release file created at: Fri, 12 Apr 2024 14:19:44 +0000
Fetched 2464 B in 3s (958 B/s)
Reading package lists... Done
E: Failed to fetch https://repo.download.nvidia.com/jetson/ffmpeg/dists/r35.5/main/binary-arm64/Packages.gz  File has unexpected size (2985 != 2937). Mirror sync in progress? [IP: 88.221.92.25 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
It looks to be some issues in the servers. We will check further. And please try to use SDKManager to install SDK Components.
We have tried and do not observe the issue:
$ head -1 /etc/nv_tegra_release
# R35 (release), REVISION: 5.0, GCID: 35550185, BOARD: t186ref, EABI: aarch64, DATE: Tue Feb 20 04:46:31 UTC 2024
$ sudo apt update
Hit:1 https://repo.download.nvidia.com/jetson/common r35.5 InRelease
Hit:2 https://repo.download.nvidia.com/jetson/t234 r35.5 InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:4 https://repo.download.nvidia.com/jetson/ffmpeg r35.5 InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:7 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Building dependency tree
Reading state information... Done
127 packages can be upgraded. Run 'apt list --upgradable' to see them.
You may re-flash the system and try again.
hello
thank i just re-flash and everything seems to be ok for now.
