I think I know, what caused the problem. I havenât set the date and time correctly for my region.
But still, I have the problem, that the time is not updated automatically. And each time, I reboot, I have to set it again. Same discussion as here, but I couldnât find a solution.
To those who are wondering why this causes a failure, see section under âreplay attacksâ here:
Apt does require your local time be accurate, or itâll fail in order to to protect you from replay attacks.
Edit: this may or may not be the root cause in your case. The error is not the usual one for the above mentioned case, so it could be a connection/server hickup, and simply the retry that fixed it.
