Sudo is not working when I reflash drive agx
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.3.10426
other
Host Machine Version
native Ubuntu 18.04
other
I tried to reflash the drive AGX just xavier B and the flashing was successful.
After flashing, I tried to use sudo apt update or sudo installation and I am getting the following error:
Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.14.193-rt92-tegra aarch64)
To restore this content, you can run the ‘unminimize’ command.
Last login: Thu Oct 6 18:54:12 2022 from 192.168.100.1
To run a command as administrator (user “root”), use “sudo ”.
See “man sudo_root” for details.
nvidia@tegra-ubuntu:~$ ls
drive-t186ref-linux
nvidia@tegra-ubuntu:~$ sudo apt update
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
I was not able to log in as root as well.
can you please help me with this issue?
Thank you
Hi @user158496
No other developer has ever raised the issue.
Which DRIVE OS version did Xavier A and B have before flashing? Which DRIVE OS version was Xavier B reflashed? Could you try flashing both Xaviers? Thanks.
I am reflashing it everytime and never faced this issue before. Drive OS 5.2.6 is the one I used to flash.
Please try if reflashing both Xaviers helps. Thanks.
