Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Hello.
I’m having some problems after flashing my board. When I boot my Xavier, it triggers a Thermal Alert. I cannot flash it while having this alert, so I just reboot my board, and before it begins having this problem, i open Sudo Putty and issue the following commands
tegrarecovery x2 on
tegrareset x2
And the Thermal Alert stops. It flashes Ok after that, but when it finishes flashing, it looks like the board is rebooted and the same alert is triggered, as shown in the image below:
I type the same inputs, and the problem goes away, but the main problem is that the screen of my dev is completely blacked out. I can’t even download a GUI because it doesn’t recognize SUDO as a valid command, and I don’t know how to solve the issue without having the same problem all over again. Here are the log files after flashing the device:
SDKM_logs_DRIVE_Software_10.0_(rev.2)_Linux_for_DRIVE_AGX_Developer_Kit_2022-03-29_10-23-06.zip (836.4 KB)
Is there anything I can do to solve the problem and flash correctly?
Thank you.
