I had updated a Drive PX2 Autochauffeuer to the last OS 5.0.10.3 and after the flashing the Tegra A cannot boot the linux and keep rebooting the Tegra B. I also tried to flash just the Tegra A and during the final instalations and setup in Tegra A after the flashing is possible to normally use Tegra B. Before I finishing the accept of terms, definition of the date… the Drive PX reboot and before it the monitor connected to the Tegra A keeps black and the Tegra B starts, and when finish to open the web browser all the Drive PX reboot.
I was using ethernet cable and the devide was working before the update.
Dear Reway,
From the sdkm.log it is clear that Tegra A flashing is skipped.
Could you delete ~/.nvsdkm folder and remove the DRIVE 5.0.10.3 installation and attempt a fresh installation once again. Please check [url]Flashing issues on DRIVE PX2 & Drive AGX Xavier - FAQ - NVIDIA Developer Forums for some known errors and work around. If it still fails, Please upload ~/.nvsdkm/logs and ~/.nvsdkm/sdkm.log in the thread.
Dear Reway,
Could you share the following thing to get more insights.
What is your Host kernel version and Aurix version?
Is the board used on Desk or inside car?
Did you connect both Host and board to internet while flashing?
What happens when you flash the Tegras one after another?
I already downgraded the kernel to 4.13.0-41-generic, deleted ~/.nvsdkm folder, removed the DRIVE 5.0.10.3 installation and I did a fresh new installation again and the problem persist.
Yes, When flashed from the second Host, the board present the same “Rebooting” problem. In both Hosts the characteristic is the same:
After the sucessfull flashing presented in the Host both TEGRAS show a window with:
Introduction;
Time definition;
License agreement.
If I proceed with this setup just in TEGRA B, I can use TEGRA B normally. However, If I finish it in TEGRA A, it starts the rebooting of the complete board.
Dear Reway,
We suspect Aurix is not flashed correctly. Turn off your board and connect your host PC and board via usb-usb cable. Open minicom connection to Aurix and both Tegras. Once you turn on board, you can see booting outputs for these. Please share those logs.
