Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Dear @tonyb.zhao,
I notice the flashing of DRIVE OS 5.2.6 is successful in the logs. Please confirm which version the board has ? Does it has any issue before flashing?
The board is AGX XAvier DevKit[E3550], and now I want to downgrade it from 5.2.6 to 5.2.0
After flashing the board with OS 5.2.6 sucessfully, I can connect it to the display to the target board, the display can show normally, but after I reboot the target , I cannot connect with display any more. Only way to access the board is using putty by usb line
and I feel it has some bugs on OS 5.2.6, when the display shows well, I tried the nvsipl_camera, it crashed, and I check the code, it is related to initailize the window, the crash log I remeber that it show something wrong with openGL. And if I remove the -d option the camera can capture the frame normally.
But now I think I need to recover the board firstly, thank you very much
We would like to double confirm this was observed with 5.2.6 instead of 5.2.0, right?
If yes, the information in your first post may need to be corrected. Thanks.
Yes, the solution is like below:
1st step: sudo pkill X (after excute this command the error will not show)
2st step: if no error , but the monitor still cannot show the image captured by camera , you can change your monitor, for my side , I changed the monitor as a 4K, then it works
@tonyb.zhao I was asking about flashing stuck at 99% and seeing “Thermal Alert Triggered” messages in aurix console. I presume you have no the issue anymore, right? How did you solve or work around it? Thanks.
