I test my python code in jetson device, and I find that I can’t run my code when I use sudo command, just like sudo python -c "import cv2", error happend.
It is not Illegal instruction (core dumped) error, as I have set .bashrc with export OPENBLAS_CORETYPE=ARMV8.
I check it in my TX2, Nano and xavier agx, and same error happend,whether jetpack 4.6(l4t 332.6.1) and jetpack 4.5.1(l4t 32.5.1).
Do you have customization to the system image? We try it on Jetpacl 4.6/Jetson Nano developer kit, and don’t observe the issue. The commands are executed without error:
