diff --git a/drivers/platform/tegra/ptp-notifier.c b/drivers/platform/tegra/ptp-notifier.c
index 9da644b..7fbdabc 100644
--- a/drivers/platform/tegra/ptp-notifier.c
+++ b/drivers/platform/tegra/ptp-notifier.c
@@ -1,7 +1,7 @@
* drivers/platform/tegra/ptp-notifier.c
- * Copyright (c) 2018-2022, NVIDIA CORPORATION. All rights reserved.
+ * Copyright (c) 2018-2023, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify it
* under the terms and conditions of the GNU General Public License,
@@ -104,30 +104,44 @@
raw_spin_lock_irqsave(&ptp_notifier_lock, flags);
if (!intf_name || !ts) {
pr_err("passed Interface_name or time-stamp ptr is NULL");
- raw_spin_unlock_irqrestore(&ptp_notifier_lock, flags);
- return -1;
+ ret = -1;
+ goto err_put;
+ /* dev_get_by_name increments the dev reference and requires dev_put */
dev = dev_get_by_name(&init_net, intf_name);
- if (!dev || !(dev->flags & IFF_UP)) {
- pr_debug("dev is NULL or intf is not up for %s\n", intf_name);
- return -EINVAL;
+ if (!dev) {
+ pr_debug("No device found for %s\n", intf_name);
+ ret = -EINVAL;
+ goto err_put;
+ if (!(dev->flags & IFF_UP)) {
+ pr_debug("interface is not up for %s\n", intf_name);
+ ret = -EINVAL;
+ goto err_put;
for (index = 0; index < MAX_MAC_INSTANCES; index++) {
if (dev == registered_ndev[index])
break;
if (index == MAX_MAC_INSTANCES) {
pr_debug("Interface: %s is not registered to get HW time", intf_name);
- return -EINVAL;
+ ret = -EINVAL;
+ goto err_put;
if (get_systime[index])
ret = (get_systime[index])(dev, ts, ts_type);
else
ret = -EINVAL;
+err_put:
+ if (dev)
+ dev_put(dev);
return ret;
