I am getting super slow inference and also wrong ones in isaac_ros_foundationpose following the example.
Here is the log:
isaac_ros_foundationpose_test.txt (136.8 KB)
here is rviz2 log
admin@DOS:/workspaces/isaac_ros-dev/isaac_ros_assets/models/synthetica_detr$ rviz2 -d $(ros2 pkg prefix isaac_ros_foundationpose --share)/rviz/foundationpose_realsense.rviz
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-admin'
[INFO] [1739389371.321226750] [rviz2]: Stereo is NOT SUPPORTED
[INFO] [1739389371.321312486] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
[INFO] [1739389371.348097414] [rviz2]: Stereo is NOT SUPPORTED
[INFO] [1739389371.491140505] [rviz2]: Stereo is NOT SUPPORTED
I am in this part of training (finished synthetica DETR part and attached screencast of it).
https://nvidia-isaac-ros.github.io/repositories_and_packages/isaac_ros_pose_estimation/isaac_ros_foundationpose/index.html
here is the screencast of the inference visualization:
sys info:
2025-02-12 14:40:35 [mona@DOS ~]$ uname -a
Linux DOS 6.8.0-52-generic #53~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Wed Jan 15 19:18:46 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
2025-02-12 14:40:37 [mona@DOS ~]$ lsb_release -a
LSB Version: core-11.1.0ubuntu4-noarch:security-11.1.0ubuntu4-noarch
Distributor ID: Ubuntu
Description: Ubuntu 22.04.5 LTS
Release: 22.04
Codename: jammy
2025-02-12 14:40:43 [mona@DOS ~]$ nvidia-smi
Wed Feb 12 14:40:51 2025
| NVIDIA-SMI 570.86.15 Driver Version: 570.86.15 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3080 ... Off | 00000000:01:00.0 On | N/A |
| N/A 77C P0 46W / 90W | 12676MiB / 16384MiB | 98% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 5988 G /usr/lib/xorg/Xorg 133MiB |
| 0 N/A N/A 25117 C ...onents/component_container_mt 12514MiB |
2025-02-12 14:49:06 [mona@DOS ~]$ nvcc --version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Thu_Nov_18_09:45:30_PST_2021
Cuda compilation tools, release 11.5, V11.5.119
Build cuda_11.5.r11.5/compiler.30672275_0
I also notice that fps for depth is 15 while intel realsense depth fps is 60.
[component_container_mt-1] [INFO] [1739389332.951787581] [realsense2_camera]: Open profile: stream_type: Depth(0), Format: Z16, Width: 640, Height: 480, FPS: 15
