I have already deployed isaac_ros_foundationpose using Docker on Jetson NX 16G. I have tested two launch. py files, which are:
isaac_ros_foundationpose_orbbec.launch.py ----(from isaac_ros_foundationpose_realsense.launch.py)
import os
from ament_index_python.packages import get_package_share_directory
import launch
from launch.actions import DeclareLaunchArgument
from launch.conditions import IfCondition
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import ComposableNodeContainer, Node
from launch_ros.descriptions import ComposableNode
# Number of Realsense messages to be dropped in 1 second
HAWK_EXPECT_FREQ = 10 #28
# Expected number of Realsense messages in 1 second
INPUT_IMAGES_DROP_FREQ = 30
RT_DETR_MODEL_INPUT_SIZE = 640 # RT-DETR models expect 640x640 encoded image size
RT_DETR_MODEL_NUM_CHANNELS = 3 # RT-DETR models expect 3 image channels
REALSENSE_IMAGE_WIDTH = 640
REALSENSE_IMAGE_HEIGHT = 480
VISUALIZATION_DOWNSCALING_FACTOR = 10
REALSENSE_TO_RT_DETR_RATIO = REALSENSE_IMAGE_WIDTH / RT_DETR_MODEL_INPUT_SIZE
REFINE_MODEL_PATH = '/tmp/refine_model.onnx'
SCORE_MODEL_PATH = '/tmp/score_model.onnx'
MESH_FILE_PATH = '/data/AR-Code-Object-Capture-app-1730803003.obj'
TEXTURE_MAP_PATH = '/data/baked_mesh_34b42ceb_tex0.png'
REFINE_ENGINE_PATH = '/data/isaac_ros-dev/isaac_ros_assets/models/foundationpose/refine_trt_engine.plan'
SCORE_ENGINE_PATH = '/data/isaac_ros-dev/isaac_ros_assets/models/foundationpose/score_trt_engine.plan'
def generate_launch_description():
"""Generate launch description for testing relevant nodes."""
rviz_config_path = os.path.join(
get_package_share_directory('isaac_ros_foundationpose'),
'rviz', 'foundationpose_realsense.rviz')
launch_args = [
DeclareLaunchArgument(
'hawk_expect_freq',
default_value=str(HAWK_EXPECT_FREQ),
description='Number of Realsense messages to be dropped in 1 second'),
'input_images_drop_freq',
default_value=str(INPUT_IMAGES_DROP_FREQ),
description='Expected number of Realsense messages in 1 second'),
'mesh_file_path',
default_value=MESH_FILE_PATH,
description='The absolute file path to the mesh file'),
'texture_path',
default_value=TEXTURE_MAP_PATH,
description='The absolute file path to the texture map'),
'refine_model_file_path',
default_value=REFINE_MODEL_PATH,
description='The absolute file path to the refine model'),
'refine_engine_file_path',
default_value=REFINE_ENGINE_PATH,
description='The absolute file path to the refine trt engine'),
'score_model_file_path',
default_value=SCORE_MODEL_PATH,
description='The absolute file path to the score model'),
'score_engine_file_path',
default_value=SCORE_ENGINE_PATH,
description='The absolute file path to the score trt engine'),
'rt_detr_model_file_path',
default_value='',
description='The absolute file path to the RT-DETR ONNX file'),
'rt_detr_engine_file_path',
default_value='',
description='The absolute file path to the RT-DETR TensorRT engine file'),
'launch_rviz',
default_value='False',
description='Flag to enable Rviz2 launch'),
'container_name',
default_value='foundationpose_container',
description='Name for ComposableNodeContainer'),
hawk_expect_freq = LaunchConfiguration('hawk_expect_freq')
input_images_drop_freq = LaunchConfiguration('input_images_drop_freq')
mesh_file_path = LaunchConfiguration('mesh_file_path')
texture_path = LaunchConfiguration('texture_path')
refine_model_file_path = LaunchConfiguration('refine_model_file_path')
refine_engine_file_path = LaunchConfiguration('refine_engine_file_path')
score_model_file_path = LaunchConfiguration('score_model_file_path')
score_engine_file_path = LaunchConfiguration('score_engine_file_path')
rt_detr_model_file_path = LaunchConfiguration('rt_detr_model_file_path')
rt_detr_engine_file_path = LaunchConfiguration('rt_detr_engine_file_path')
launch_rviz = LaunchConfiguration('launch_rviz')
container_name = LaunchConfiguration('container_name')
# Drops hawk_expect_freq out of input_images_drop_freq RealSense messages
drop_node = ComposableNode(
name='drop_node',
package='isaac_ros_nitros_topic_tools',
plugin='nvidia::isaac_ros::nitros::NitrosCameraDropNode',
parameters=[{
'X': hawk_expect_freq,
'Y': input_images_drop_freq,
'mode': 'mono+depth',
'depth_format_string': 'nitros_image_mono16'
remappings=[
('image_1', '/weng_camera/color/image_raw'),
('camera_info_1', '/weng_camera/color/camera_info'),
('depth_1', '/weng_camera/depth/image_raw'),
('image_1_drop', 'rgb/image_rect_color'),
('camera_info_1_drop', 'rgb/camera_info'),
('depth_1_drop', 'depth_uint16'),
# Realsense depth is in uint16 and millimeters. Convert to float32 and meters
convert_metric_node = ComposableNode(
package='isaac_ros_depth_image_proc',
plugin='nvidia::isaac_ros::depth_image_proc::ConvertMetricNode',
remappings=[
('image_raw', 'depth_uint16'),
('image', 'depth_image')
foundationpose_node = ComposableNode(
name='foundationpose_node',
package='isaac_ros_foundationpose',
plugin='nvidia::isaac_ros::foundationpose::FoundationPoseNode',
parameters=[{
'mesh_file_path': mesh_file_path,
'texture_path': texture_path,
'refine_model_file_path': refine_model_file_path,
'refine_engine_file_path': refine_engine_file_path,
'refine_input_tensor_names': ['input_tensor1', 'input_tensor2'],
'refine_input_binding_names': ['input1', 'input2'],
'refine_output_tensor_names': ['output_tensor1', 'output_tensor2'],
'refine_output_binding_names': ['output1', 'output2'],
'score_model_file_path': score_model_file_path,
'score_engine_file_path': score_engine_file_path,
'score_input_tensor_names': ['input_tensor1', 'input_tensor2'],
'score_input_binding_names': ['input1', 'input2'],
'score_output_tensor_names': ['output_tensor'],
'score_output_binding_names': ['output1'],
remappings=[
('pose_estimation/depth_image', 'depth_image'),
('pose_estimation/image', 'rgb/image_rect_color'),
('pose_estimation/camera_info', 'rgb/camera_info'),
('pose_estimation/segmentation', 'weng_mask'),
('pose_estimation/output', 'output')])
rviz_node = Node(
package='rviz2',
executable='rviz2',
name='rviz2',
arguments=['-d', rviz_config_path],
condition=IfCondition(launch_rviz))
foundationpose_container = ComposableNodeContainer(
name=container_name,
namespace='',
package='rclcpp_components',
executable='component_container_mt',
composable_node_descriptions=[
# realsense_node,
drop_node,
convert_metric_node,
foundationpose_node,
# resize_left_viz
output='screen'
return launch.LaunchDescription(launch_args + [foundationpose_container,
rviz_node])
isaac_ros_foundationpose_orbbec_tracking.launch.py ---- (from isaac_ros_foundationpose_realsense_tracking.launch.py)
import os
import launch
HAWK_EXPECT_FREQ = 6
launch_args = [
'hawk_expect_freq',
'mesh_file_path',
'texture_path',
default_value='',
default_value='',
'launch_rviz',
'container_name',
name='drop_node',
parameters=[{
remappings=[
remappings=[
# Launch isaac_ros_foundationpose
selector_node = ComposableNode(
name='selector_node',
plugin='nvidia::isaac_ros::foundationpose::Selector',
parameters=[{
'reset_period': 20000
remappings=[
('depth_image', 'depth_image'),
('image', 'rgb/image_rect_color'),
('camera_info', 'rgb/camera_info'),
('segmentation', 'weng_mask')
parameters=[{
foundationpose_tracking_node = ComposableNode(
name='foundationpose_tracking_node',
plugin='nvidia::isaac_ros::foundationpose::FoundationPoseTrackingNode',
parameters=[{
namespace='',
# realsense_node,
drop_node,
selector_node,
foundationpose_tracking_node,
output='screen'
return launch.LaunchDescription(launch_args + [foundationpose_container])
Jetson NX 16G:
when running isaac_ros_foundationpose_orbbec.launch.py
ros2 topic hz /output
average rate: 0.369
min: 0.001s max: 5.962s std dev: 0.35987s window: 890
average rate: 0.369
min: 0.001s max: 5.962s std dev: 0.35967s window: 891
average rate: 0.369
min: 0.001s max: 5.962s std dev: 0.35947s window: 892
average rate: 0.369
min: 0.001s max: 5.962s std dev: 0.35937s window: 893
average rate: 0.369
min: 0.001s max: 5.962s std dev: 0.35929s window: 894
ros2 topic hz /tracking/output
average rate: 2.758
min: 0.001s max: 2606.389s std dev: 26.06432s window: 10000
average rate: 2.758
average rate: 2.759
min: 0.001s max: 2606.389s std dev: 26.06431s window: 10000
average rate: 2.758
average rate: 2.759
No matter which launch file is used to start, there is a huge delay in max time. I would like to know which parameters need to be adjusted to avoid delay, and I hope to achieve a stable 5FPS.
