I have been attempting to integrate isaac_ros_yolov8 instead of isaac_ros_rtdetr in the Foundation Pose pipeline using a Realsense 435i camera on my pc equiped with RTX 4050 6G VRAM.
I tried using a custom RT-DETR model, but i cant get a detection using the isaac_ros_rtdetr package. I’ve tested the model on its .onnx format and it performs well. I’ve trained the rtdetr models using the GitHub - lyuwenyu/RT-DETR: [CVPR 2024] Official RT-DETR (RTDETR paddle pytorch), Real-Time DEtection TRansformer, DETRs Beat YOLOs on Real-time Object Detection. 🔥 🔥 🔥 repository. What could the problem be here?
On the other side, when i use a custom yolov8 model in the isaac_ros_yolov8 package i get pretty good detections. So i tried modifying the isaac_ros_foundationpose_core.launch.py file like this:
# SPDX-FileCopyrightText: NVIDIA CORPORATION & AFFILIATES
# Copyright (c) 2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# SPDX-License-Identifier: Apache-2.0
import os
from typing import Any, Dict
from ament_index_python.packages import get_package_share_directory
from isaac_ros_examples import IsaacROSLaunchFragment
import launch
from launch.actions import DeclareLaunchArgument, IncludeLaunchDescription
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
# Expected number of input messages in 1 second
INPUT_IMAGES_EXPECT_FREQ = 30
# Number of input messages to be dropped in 1 second
INPUT_IMAGES_DROP_FREQ = 28
# YOLOv8 models expect 640x640 encoded image size
YOLOV8_MODEL_INPUT_SIZE = 640
VISUALIZATION_DOWNSCALING_FACTOR = 10
REFINE_MODEL_PATH = '/tmp/refine_model.onnx'
REFINE_ENGINE_PATH = '/tmp/refine_trt_engine.plan'
SCORE_MODEL_PATH = '/tmp/score_model.onnx'
SCORE_ENGINE_PATH = '/tmp/score_trt_engine.plan'
class IsaacROSFoundationPoseLaunchFragment(IsaacROSLaunchFragment):
@staticmethod
def get_composable_nodes(interface_specs: Dict[str, Any]) -> Dict[str, ComposableNode]:
# Drop node parameters
input_images_expect_freq = LaunchConfiguration('input_images_expect_freq')
input_images_drop_freq = LaunchConfiguration('input_images_drop_freq')
# FoundationPose parameters
mesh_file_path = LaunchConfiguration('mesh_file_path')
texture_path = LaunchConfiguration('texture_path')
refine_model_file_path = LaunchConfiguration('refine_model_file_path')
refine_engine_file_path = LaunchConfiguration('refine_engine_file_path')
score_model_file_path = LaunchConfiguration('score_model_file_path')
score_engine_file_path = LaunchConfiguration('score_engine_file_path')
input_width = interface_specs['camera_resolution']['width']
input_height = interface_specs['camera_resolution']['height']
input_to_YOLOv8_ratio = input_width / YOLOV8_MODEL_INPUT_SIZE
# Yolov8 parameters
model_file_path = LaunchConfiguration('model_file_path')
engine_file_path = LaunchConfiguration('engine_file_path')
input_tensor_names = LaunchConfiguration('input_tensor_names')
input_binding_names = LaunchConfiguration('input_binding_names')
output_tensor_names = LaunchConfiguration('output_tensor_names')
output_binding_names = LaunchConfiguration('output_binding_names')
verbose = LaunchConfiguration('verbose')
force_engine_update = LaunchConfiguration('force_engine_update')
# YOLOv8 Decoder parameters
confidence_threshold = LaunchConfiguration('confidence_threshold')
nms_threshold = LaunchConfiguration('nms_threshold')
return {
'drop_node': ComposableNode(
name='drop_node',
package='isaac_ros_nitros_topic_tools',
plugin='nvidia::isaac_ros::nitros::NitrosCameraDropNode',
parameters=[{
'X': input_images_drop_freq,
'Y': input_images_expect_freq,
'mode': 'mono+depth',
'depth_format_string': 'nitros_image_mono16'
remappings=[
('image_1', 'image_rect'),
('camera_info_1', 'camera_info_rect'),
('depth_1', 'depth'),
('image_1_drop', 'rgb/image_rect_color'),
('camera_info_1_drop', 'rgb/camera_info'),
('depth_1_drop', 'depth_image'),
# Yolo objection detection pipeline
'tensor_rt_node': ComposableNode(
name='tensor_rt',
package='isaac_ros_tensor_rt',
plugin='nvidia::isaac_ros::dnn_inference::TensorRTNode',
parameters=[{
'model_file_path': model_file_path,
'engine_file_path': engine_file_path,
'output_binding_names': output_binding_names,
'output_tensor_names': output_tensor_names,
'input_tensor_names': input_tensor_names,
'input_binding_names': input_binding_names,
'verbose': verbose,
'force_engine_update': force_engine_update
'yolov8_decoder_node': ComposableNode(
name='yolov8_decoder_node',
package='isaac_ros_yolov8',
plugin='nvidia::isaac_ros::yolov8::YoloV8DecoderNode',
parameters=[{
'confidence_threshold': confidence_threshold,
'nms_threshold': nms_threshold,
'detection2_d_to_mask_node': ComposableNode(
name='detection2_d_to_mask',
package='isaac_ros_foundationpose',
plugin='nvidia::isaac_ros::foundationpose::Detection2DToMask',
parameters=[{
'mask_width': int(input_width/input_to_YOLOv8_ratio),
'mask_height': int(input_height/input_to_YOLOv8_ratio)}],
remappings=[('detection2_d_array', 'detections_output'),
('segmentation', 'yolov8_segmentation')]),
'resize_mask_node': ComposableNode(
name='resize_mask_node',
package='isaac_ros_image_proc',
plugin='nvidia::isaac_ros::image_proc::ResizeNode',
parameters=[{
'input_width': int(input_width/input_to_YOLOv8_ratio),
'input_height': int(input_height/input_to_YOLOv8_ratio),
'output_width': input_width,
'output_height': input_height,
'keep_aspect_ratio': False,
'disable_padding': False
remappings=[
('image', 'yolov8_segmentation'),
('camera_info', 'rgb/camera_info'),
('resize/image', 'segmentation'),
('resize/camera_info', 'camera_info_segmentation')
'resize_left_viz': ComposableNode(
name='resize_left_viz',
parameters=[{
'input_width': input_width,
'input_height': input_height,
'output_width': int(input_width/VISUALIZATION_DOWNSCALING_FACTOR) * 2,
'output_height': int(input_height/VISUALIZATION_DOWNSCALING_FACTOR) * 2,
'encoding_desired': 'rgb8',
remappings=[
('image', 'rgb/image_rect_color'),
('resize/image', 'rgb/image_rect_color_viz'),
('resize/camera_info', 'rgb/camera_info_viz')
'foundationpose_node': ComposableNode(
name='foundationpose_node',
plugin='nvidia::isaac_ros::foundationpose::FoundationPoseNode',
parameters=[{
'mesh_file_path': mesh_file_path,
'texture_path': texture_path,
'refine_model_file_path': refine_model_file_path,
'refine_engine_file_path': refine_engine_file_path,
'refine_input_tensor_names': ['input_tensor1', 'input_tensor2'],
'refine_input_binding_names': ['input1', 'input2'],
'refine_output_tensor_names': ['output_tensor1', 'output_tensor2'],
'refine_output_binding_names': ['output1', 'output2'],
'score_model_file_path': score_model_file_path,
'score_engine_file_path': score_engine_file_path,
'score_input_tensor_names': ['input_tensor1', 'input_tensor2'],
'score_input_binding_names': ['input1', 'input2'],
'score_output_tensor_names': ['output_tensor'],
'score_output_binding_names': ['output1'],
remappings=[
('pose_estimation/depth_image', 'depth_image'),
('pose_estimation/image', 'rgb/image_rect_color'),
('pose_estimation/camera_info', 'rgb/camera_info'),
('pose_estimation/segmentation', 'segmentation'),
('pose_estimation/output', 'output')]
@staticmethod
def get_launch_actions(interface_specs: Dict[str, Any]) -> \
Dict[str, launch.actions.OpaqueFunction]:
network_image_width = LaunchConfiguration('network_image_width')
network_image_height = LaunchConfiguration('network_image_height')
image_mean = LaunchConfiguration('image_mean')
image_stddev = LaunchConfiguration('image_stddev')
encoder_dir = get_package_share_directory('isaac_ros_dnn_image_encoder')
return {
'input_images_expect_freq': DeclareLaunchArgument(
'input_images_expect_freq',
default_value=str(INPUT_IMAGES_EXPECT_FREQ),
description='Expected number of input messages in 1 second'),
'input_images_drop_freq': DeclareLaunchArgument(
'input_images_drop_freq',
default_value=str(INPUT_IMAGES_DROP_FREQ),
description='Number of input messages to be dropped in 1 second'),
'mesh_file_path': DeclareLaunchArgument(
'mesh_file_path',
default_value='',
description='The absolute file path to the mesh file'),
'texture_path': DeclareLaunchArgument(
'texture_path',
default_value='',
description='The absolute file path to the texture map'),
'refine_model_file_path': DeclareLaunchArgument(
'refine_model_file_path',
default_value=REFINE_MODEL_PATH,
description='The absolute file path to the refine model'),
'refine_engine_file_path': DeclareLaunchArgument(
'refine_engine_file_path',
default_value=REFINE_ENGINE_PATH,
description='The absolute file path to the refine trt engine'),
'score_model_file_path': DeclareLaunchArgument(
'score_model_file_path',
default_value=SCORE_MODEL_PATH,
description='The absolute file path to the score model'),
'score_engine_file_path': DeclareLaunchArgument(
'score_engine_file_path',
default_value=SCORE_ENGINE_PATH,
description='The absolute file path to the score trt engine'),
'network_image_width': DeclareLaunchArgument(
'network_image_width',
default_value='640',
description='The input image width that the network expects'
'network_image_height': DeclareLaunchArgument(
'network_image_height',
description='The input image height that the network expects'
'image_mean': DeclareLaunchArgument(
'image_mean',
default_value='[0.0, 0.0, 0.0]',
description='The mean for image normalization'
'image_stddev': DeclareLaunchArgument(
'image_stddev',
default_value='[1.0, 1.0, 1.0]',
description='The standard deviation for image normalization'
'model_file_path': DeclareLaunchArgument(
'model_file_path',
default_value='',
description='The absolute file path to the ONNX file'
'engine_file_path': DeclareLaunchArgument(
'engine_file_path',
default_value='',
description='The absolute file path to the TensorRT engine file'
'input_tensor_names': DeclareLaunchArgument(
'input_tensor_names',
default_value='["input_tensor"]',
description='A list of tensor names to bound to the specified input binding names'
'input_binding_names': DeclareLaunchArgument(
'input_binding_names',
default_value='["images"]',
description='A list of input tensor binding names (specified by model)'
'output_tensor_names': DeclareLaunchArgument(
'output_tensor_names',
default_value='["output_tensor"]',
description='A list of tensor names to bound to the specified output binding names'
'output_binding_names': DeclareLaunchArgument(
'output_binding_names',
default_value='["output0"]',
description='A list of output tensor binding names (specified by model)'
'verbose': DeclareLaunchArgument(
'verbose',
default_value='False',
description='Whether TensorRT should verbosely log or not'
'force_engine_update': DeclareLaunchArgument(
'force_engine_update',
description='Whether TensorRT should update the TensorRT engine file or not'
'confidence_threshold': DeclareLaunchArgument(
'confidence_threshold',
default_value='0.25',
description='Confidence threshold to filter candidate detections during NMS'
'nms_threshold': DeclareLaunchArgument(
'nms_threshold',
default_value='0.45',
description='NMS IOU threshold'
'yolov8_encoder_launch': IncludeLaunchDescription(
PythonLaunchDescriptionSource(
[os.path.join(encoder_dir, 'launch', 'dnn_image_encoder.launch.py')]
launch_arguments={
'input_image_width': str(interface_specs['camera_resolution']['width']),
'input_image_height': str(interface_specs['camera_resolution']['height']),
'network_image_width': network_image_width,
'network_image_height': network_image_height,
'image_mean': image_mean,
'image_stddev': image_stddev,
'attach_to_shared_component_container': 'True',
'component_container_name': '/isaac_ros_examples/container',
'dnn_image_encoder_namespace': 'yolov8_encoder',
'image_input_topic': '/rgb/image_rect_color',
'camera_info_input_topic': '/rgb/camera_info',
'tensor_output_topic': '/tensor_pub',
}.items(),
def generate_launch_description():
foundationpose_container = ComposableNodeContainer(
package='rclcpp_components',
name='foundationpose_container',
namespace='',
executable='component_container_mt',
composable_node_descriptions=IsaacROSFoundationPoseLaunchFragment
.get_composable_nodes().values(),
output='screen'
return launch.LaunchDescription(
[foundationpose_container] +
IsaacROSFoundationPoseLaunchFragment.get_launch_actions().values())
The logs i get are:
[component_container_mt-1] [INFO] [1732207379.519618078] [yolov8_encoder.resize_node]: This type hasn’t been negotiated for, skipping publish
[component_container_mt-1] [INFO] [1732207379.579676286] [foundationpose_node]: [NitrosNode] Wrote the final top level YAML graph to “/tmp/isaac_ros_nitros/graphs/FIZMUBIVWI/FIZMUBIVWI.yaml”
[component_container_mt-1] [INFO] [1732207379.579721110] [foundationpose_node]: [NitrosNode] Loading application
[component_container_mt-1] 2024-11-21 18:42:59.587 WARN gxf/std/yaml_file_loader.cpp@1077: Using unregistered parameter ‘dummy_rx’ in component ‘’.
[component_container_mt-1] 2024-11-21 18:42:59.588 WARN gxf/std/yaml_file_loader.cpp@1077: Using unregistered parameter ‘dev_id’ in component ‘stream’.
[component_container_mt-1] [INFO] [1732207379.589208365] [foundationpose_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] 2024-11-21 18:42:59.593 WARN gxf/std/scheduling_terms.cpp@333: ‘min_size’ parameter in MultiMessageAvailableSchedulingTerm is deprecated. Use ‘min_sum’ with SumOfAll sampling mode instead
[component_container_mt-1] 2024-11-21 18:42:59.594 WARN gxf/std/scheduling_terms.cpp@333: ‘min_size’ parameter in MultiMessageAvailableSchedulingTerm is deprecated. Use ‘min_sum’ with SumOfAll sampling mode instead
[component_container_mt-1] [INFO] [1732207379.595665659] [foundationpose_node]: [NitrosNode] Node was started
[component_container_mt-1] [INFO] [1732207380.020560574] [yolov8_encoder.resize_node]: This type hasn’t been negotiated for, skipping publish
[component_container_mt-1] [INFO] [1732207380.520752667] [yolov8_encoder.resize_node]: This type hasn’t been negotiated for, skipping publish
[component_container_mt-1] [INFO] [1732207381.021909298] [yolov8_encoder.resize_node]: This type hasn’t been negotiated for, skipping publish
BUT from time to time i get this:
[component_container_mt-1] [INFO] [1732207445.776702231] [detection2_d_to_mask]: No detection found with non-zero confidence
[component_container_mt-1] [INFO] [1732207446.160482413] [foundationpose_node]: [NitrosNode] Wrote the final top level YAML graph to “/tmp/isaac_ros_nitros/graphs/PNTDLSAZMX/PNTDLSAZMX.yaml”
[component_container_mt-1] [INFO] [1732207446.160524472] [foundationpose_node]: [NitrosNode] Loading application
[component_container_mt-1] 2024-11-21 18:44:06.168 WARN gxf/std/yaml_file_loader.cpp@1077: Using unregistered parameter ‘dummy_rx’ in component ‘’.
[component_container_mt-1] 2024-11-21 18:44:06.169 WARN gxf/std/yaml_file_loader.cpp@1077: Using unregistered parameter ‘dev_id’ in component ‘stream’.
[component_container_mt-1] [INFO] [1732207446.170425265] [foundationpose_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] 2024-11-21 18:44:06.174 WARN gxf/std/scheduling_terms.cpp@333: ‘min_size’ parameter in MultiMessageAvailableSchedulingTerm is deprecated. Use ‘min_sum’ with SumOfAll sampling mode instead
[component_container_mt-1] 2024-11-21 18:44:06.175 WARN gxf/std/scheduling_terms.cpp@333: ‘min_size’ parameter in MultiMessageAvailableSchedulingTerm is deprecated. Use ‘min_sum’ with SumOfAll sampling mode instead
[component_container_mt-1] [INFO] [1732207446.179437120] [foundationpose_node]: [NitrosNode] Node was started
[component_container_mt-1] [INFO] [1732207446.278246506] [detection2_d_to_mask]: No detection found with non-zero confidence
[component_container_mt-1] [INFO] [1732207446.779933329] [detection2_d_to_mask]: No detection found with non-zero confidence
[component_container_mt-1] [INFO] [1732207447.275687375] [detection2_d_to_mask]: No detection found with non-zero confidence
[component_container_mt-1] [INFO] [1732207447.780770200] [detection2_d_to_mask]: No detection found with non-zero confidence
[component_container_mt-1] [INFO] [1732207448.284945894] [detection2_d_to_mask]: No detection found with non-zero confidence
[component_container_mt-1] [INFO] [1732207448.787524050] [detection2_d_to_mask]: No detection found with non-zero confidence
[component_container_mt-1] [INFO] [1732207449.285241209] [detection2_d_to_mask]: No detection found with non-zero confidence
[ERROR] [component_container_mt-1]: process has died [pid 24111, exit code -6, cmd ‘/opt/ros/humble/lib/rclcpp_components/component_container_mt --ros-args -r __node:=container -r __ns:=/isaac_ros_examples’].
From some debugging i’ve done the process gets stuck because the topic yolov8_encoder/resize/image/intros/nitros_image_rgb8 does not get published by the yolov8_encoder/resize_node.
