YOLOv8 on Foundation Pose pipeline does not return pose
Hello there,
I have been attempting to integrate isaac_ros_yolov8 instead of isaac_ros_rtdetr in the Foundation Pose pipeline. The original quickstart with the original bag and RTDETR algorithm does work. To detect a custom object I have then trained a custom YOLOv8 model and have modified the foundation_pose_core.launch file to shift to YOLOv8 node.
I am currently facing 2 main problems. My first problem seems to be in translating the detected bounding boxes from yolov8 to rt-detr for further segmentation mask. Since my image is not square and YOLOv8 applies letterboxing to the input image to match the 640x640 resolution.
These are the changes I applied to the launch file:
isaac_ros_foundationpose_core.txt (17.2 KB)
ros2 launch isaac_ros_examples isaac_ros_examples.launch.py launch_fragments:=foundationpose interface_specs_file:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_foundationpose/quickstart_interface_specs.json mesh_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_foundationpose/Drill/drill.obj texture_path:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_foundationpose/Mustard/texture_map.png score_engine_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/models/foundationpose/score_trt_engine.plan refine_engine_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/models/foundationpose/refine_trt_engine.plan model_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/models/yolov8/best.onnx engine_file_path:=${ISAAC_ROS_WS}/isaac_ros_assets/models/yolov8/best.plan
Note: I know the object class is not correct but I simply have not updated the class names in the yolov8_visualizer_node and I also used a random texture since my model does not have a texture.
The other problem I am facing is related to the encoding of the depth image message. I have recorded a bag with the the raw image, camera info and aligned depth image, from a Realsense D435 camera but the realsense package stores the depth image in 16UC1 encoding. The foundation packege did not like this encoding, therefore I converted the depth image to 32FC. This bag in tandem with the foundation pose seems to not do anything, since it doesn’t even provide the yolov8 and segmentation images (Maybe with was my conversion method). Which is strange taking into consideration the previous bag with the wrong encoding performed the image segmentation part. I have also tested the isaac_ros_yolov8 on this bag and it works.
I had an additional question regarding the .obj and .mtl on the object: It states that foundation pose works for unseen objects are these files then for visualization purposes only, on rviz? And also if it is capable of handling more than one object in a scene? I have ran a test with multiple objects and the segmentation mask only reports one object.
Sorry for the long post and thanks in advance.
I made some changes to the launch file was able to make it work. In this version I use a bag with the original data from the Realsense camera and perform the conversion in the launch file with convert_metric_node.
WARNING: The conversion of the mask from the YOLOv8 expected size (640x640) to my original image input size(640x480) is not robust to all use cases. Since for my use case I only needed to crop the padding. For others scaling will probably be a factor.
# SPDX-FileCopyrightText: NVIDIA CORPORATION & AFFILIATES
# Copyright (c) 2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# SPDX-License-Identifier: Apache-2.0
import os
from typing import Any, Dict
from ament_index_python.packages import get_package_share_directory
from isaac_ros_examples import IsaacROSLaunchFragment
import launch
from launch.actions import DeclareLaunchArgument, IncludeLaunchDescription
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
# Expected number of input messages in 1 second
INPUT_IMAGES_EXPECT_FREQ = 30
# Number of input messages to be dropped in 1 second
INPUT_IMAGES_DROP_FREQ = 28
YOLOV8_MODEL_INPUT_SIZE = 640
VISUALIZATION_DOWNSCALING_FACTOR = 10
REFINE_MODEL_PATH = '/tmp/refine_model.onnx'
REFINE_ENGINE_PATH = '/tmp/refine_trt_engine.plan'
SCORE_MODEL_PATH = '/tmp/score_model.onnx'
SCORE_ENGINE_PATH = '/tmp/score_trt_engine.plan'
class IsaacROSFoundationPoseLaunchFragment(IsaacROSLaunchFragment):
    @staticmethod
    def get_composable_nodes(interface_specs: Dict[str, Any]) -> Dict[str, ComposableNode]:
        # Drop node parameters
        input_images_expect_freq = LaunchConfiguration('input_images_expect_freq')
        input_images_drop_freq = LaunchConfiguration('input_images_drop_freq')
        # FoundationPose parameters
        mesh_file_path = LaunchConfiguration('mesh_file_path')
        texture_path = LaunchConfiguration('texture_path')
        refine_model_file_path = LaunchConfiguration('refine_model_file_path')
        refine_engine_file_path = LaunchConfiguration('refine_engine_file_path')
        score_model_file_path = LaunchConfiguration('score_model_file_path')
        score_engine_file_path = LaunchConfiguration('score_engine_file_path')
        # YOLOv8 parameters
        input_width = interface_specs['camera_resolution']['width']
        input_height = interface_specs['camera_resolution']['height']
        input_to_YOLOv8_ratio = input_width / YOLOV8_MODEL_INPUT_SIZE
        # Yolov8 parameters
        model_file_path = LaunchConfiguration('model_file_path')
        engine_file_path = LaunchConfiguration('engine_file_path')
        input_tensor_names = LaunchConfiguration('input_tensor_names')
        input_binding_names = LaunchConfiguration('input_binding_names')
        output_tensor_names = LaunchConfiguration('output_tensor_names')
        output_binding_names = LaunchConfiguration('output_binding_names')
        verbose = LaunchConfiguration('verbose')
        force_engine_update = LaunchConfiguration('force_engine_update')
        # YOLOv8 Decoder parameters
        confidence_threshold = LaunchConfiguration('confidence_threshold')
        nms_threshold = LaunchConfiguration('nms_threshold')
        return {
            # Drops input_images_expect_freq out of input_images_drop_freq input messages
            'drop_node':  ComposableNode(
                name='drop_node',
                package='isaac_ros_nitros_topic_tools',
                plugin='nvidia::isaac_ros::nitros::NitrosCameraDropNode',
                parameters=[{
                    'X': input_images_drop_freq,
                    'Y': input_images_expect_freq,
                    'mode': 'mono+depth',
                    'depth_format_string': 'nitros_image_mono16'
                remappings=[
                    ('image_1', 'image_rect'),
                    ('camera_info_1', 'camera_info_rect'),
                    ('depth_1', 'depth'),
                    ('image_1_drop', 'rgb/image_rect_color'),
                    ('camera_info_1_drop', 'rgb/camera_info'),
                    ('depth_1_drop', 'depth_image_drop'),
	    'convert_metric_node': ComposableNode(
		package='isaac_ros_depth_image_proc',
		plugin='nvidia::isaac_ros::depth_image_proc::ConvertMetricNode',
		remappings=[
		    ('image_raw', 'depth_image_drop'),
		    ('image', 'depth_image')
            # YOLOv8 objection detection pipeline
            'tensor_rt_node': ComposableNode(
                name='tensor_rt',
                package='isaac_ros_tensor_rt',
                plugin='nvidia::isaac_ros::dnn_inference::TensorRTNode',
                parameters=[{
                    'model_file_path': model_file_path,
                    'engine_file_path': engine_file_path,
                    'output_binding_names': output_binding_names,
                    'output_tensor_names': output_tensor_names,
                    'input_tensor_names': input_tensor_names,
                    'input_binding_names': input_binding_names,
                    'verbose': verbose,
                    'force_engine_update': force_engine_update
            'yolov8_decoder_node': ComposableNode(
                name='yolov8_decoder_node',
                package='isaac_ros_yolov8',
                plugin='nvidia::isaac_ros::yolov8::YoloV8DecoderNode',
                parameters=[{
                    'confidence_threshold': confidence_threshold,
                    'nms_threshold': nms_threshold,
            # Create a binary segmentation mask from a Detection2DArray published by RT-DETR.
            # The segmentation mask is of size
            # int(IMAGE_WIDTH/input_to_RT_DETR_ratio) x int(IMAGE_HEIGHT/input_to_RT_DETR_ratio)
            'detection2_d_to_mask_node': ComposableNode(
                name='detection2_d_to_mask',
                package='isaac_ros_foundationpose',
                plugin='nvidia::isaac_ros::foundationpose::Detection2DToMask',
                parameters=[{
                    'mask_width': 640,
                    'mask_height': 640}],
                remappings=[('detection2_d_array', 'detections_output'),
                            ('segmentation', 'yolov8_segmentation')]),
             'crop_mask_node': ComposableNode(
	        name='crop_mask_node',
	        package='isaac_ros_image_proc',
	        plugin='nvidia::isaac_ros::image_proc::CropNode',
	        parameters=[{
		'input_width': 640,
		'input_height': 640,
		'crop_width': input_width,   # Add crop width
		'crop_height': input_height, # Add crop height
		'crop_mode': 'CENTER',           # Add crop mode (adjust as needed)
	    remappings=[
		('image', 'yolov8_segmentation'),
		('camera_info', 'rgb/camera_info'),
		('crop/image', 'segmentation'),  # Fix remapping to match output topic
		('crop/camera_info', 'camera_info_segmentation')]),
            'resize_left_viz': ComposableNode(
                name='resize_left_viz',
                plugin='nvidia::isaac_ros::image_proc::ResizeNode',
                parameters=[{
                    'input_width': input_width,
                    'input_height': input_height,
                    'output_width': int(input_width/VISUALIZATION_DOWNSCALING_FACTOR) * 2,
                    'output_height': int(input_height/VISUALIZATION_DOWNSCALING_FACTOR) * 2,
                    'keep_aspect_ratio': False,
                    'encoding_desired': 'rgb8',
                    'disable_padding': False
                remappings=[
                    ('image', 'rgb/image_rect_color'),
                    ('resize/image', 'rgb/image_rect_color_viz'),
                    ('resize/camera_info', 'rgb/camera_info_viz')
            'foundationpose_node': ComposableNode(
                name='foundationpose_node',
                plugin='nvidia::isaac_ros::foundationpose::FoundationPoseNode',
                parameters=[{
                    'mesh_file_path': mesh_file_path,
                    'texture_path': texture_path,
                    'refine_model_file_path': refine_model_file_path,
                    'refine_engine_file_path': refine_engine_file_path,
                    'refine_input_tensor_names': ['input_tensor1', 'input_tensor2'],
                    'refine_input_binding_names': ['input1', 'input2'],
                    'refine_output_tensor_names': ['output_tensor1', 'output_tensor2'],
                    'refine_output_binding_names': ['output1', 'output2'],
                    'score_model_file_path': score_model_file_path,
                    'score_engine_file_path': score_engine_file_path,
                    'score_input_tensor_names': ['input_tensor1', 'input_tensor2'],
                    'score_input_binding_names': ['input1', 'input2'],
                    'score_output_tensor_names': ['output_tensor'],
                    'score_output_binding_names': ['output1'],
                remappings=[
                    ('pose_estimation/depth_image', 'depth_image'),
                    ('pose_estimation/image', 'rgb/image_rect_color'),
                    ('pose_estimation/camera_info', 'rgb/camera_info'),
                    ('pose_estimation/segmentation', 'segmentation'),
                    ('pose_estimation/output', 'output')]
    @staticmethod
    def get_launch_actions(interface_specs: Dict[str, Any]) -> \
            Dict[str, launch.actions.OpaqueFunction]:
        network_image_width = LaunchConfiguration('network_image_width')
        network_image_height = LaunchConfiguration('network_image_height')
        image_mean = LaunchConfiguration('image_mean')
        image_stddev = LaunchConfiguration('image_stddev')
        encoder_dir = get_package_share_directory('isaac_ros_dnn_image_encoder')
        return {
            'input_images_expect_freq': DeclareLaunchArgument(
                'input_images_expect_freq',
                default_value=str(INPUT_IMAGES_EXPECT_FREQ),
                description='Expected number of input messages in 1 second'),
            'input_images_drop_freq': DeclareLaunchArgument(
                'input_images_drop_freq',
                default_value=str(INPUT_IMAGES_DROP_FREQ),
                description='Number of input messages to be dropped in 1 second'),
            'mesh_file_path': DeclareLaunchArgument(
                'mesh_file_path',
                default_value='',
                description='The absolute file path to the mesh file'),
            'texture_path': DeclareLaunchArgument(
                'texture_path',
                default_value='',
                description='The absolute file path to the texture map'),
            'refine_model_file_path': DeclareLaunchArgument(
                'refine_model_file_path',
                default_value=REFINE_MODEL_PATH,
                description='The absolute file path to the refine model'),
            'refine_engine_file_path': DeclareLaunchArgument(
                'refine_engine_file_path',
                default_value=REFINE_ENGINE_PATH,
                description='The absolute file path to the refine trt engine'),
            'score_model_file_path': DeclareLaunchArgument(
                'score_model_file_path',
                default_value=SCORE_MODEL_PATH,
                description='The absolute file path to the score model'),
            'score_engine_file_path': DeclareLaunchArgument(
                'score_engine_file_path',
                default_value=SCORE_ENGINE_PATH,
                description='The absolute file path to the score trt engine'),
	    'network_image_width': DeclareLaunchArgument(
               'network_image_width',
                default_value='640',
                description='The input image width that the network expects'),
            'network_image_height': DeclareLaunchArgument(
                'network_image_height',
                description='The input image height that the network expects'),
            'image_mean': DeclareLaunchArgument(
                'image_mean',
                default_value='[0.0, 0.0, 0.0]',
                description='The mean for image normalization'),
            'image_stddev': DeclareLaunchArgument(
                'image_stddev',
                default_value='[1.0, 1.0, 1.0]',
                description='The standard deviation for image normalization'),
            'model_file_path': DeclareLaunchArgument(
                'model_file_path',
                description='The absolute file path to the ONNX file'),
            'engine_file_path': DeclareLaunchArgument(
                'engine_file_path',
                default_value='',
                description='The absolute file path to the TensorRT engine file'),
            'input_tensor_names': DeclareLaunchArgument(
                'input_tensor_names',
                default_value='["input_tensor"]',
                description='A list of tensor names to bound to the specified input binding names'),
            'input_binding_names': DeclareLaunchArgument(
                'input_binding_names',
                default_value='["images"]',
                description='A list of input tensor binding names (specified by model)'),
            'output_tensor_names': DeclareLaunchArgument(
                'output_tensor_names',
                default_value='["output_tensor"]',
                description='A list of tensor names to bound to the specified output binding names'),
            'output_binding_names': DeclareLaunchArgument(
                'output_binding_names',
                default_value='["output0"]',
                description='A list of output tensor binding names (specified by model)'),
            'verbose': DeclareLaunchArgument(
                'verbose',
                default_value='False',
                description='Whether TensorRT should verbosely log or not'),
            'force_engine_update': DeclareLaunchArgument(
                'force_engine_update',
                description='Whether TensorRT should update the TensorRT engine file or not'),
            'confidence_threshold': DeclareLaunchArgument(
                'confidence_threshold',
                default_value='0.25',
                description='Confidence threshold to filter candidate detections during NMS'),
            'nms_threshold': DeclareLaunchArgument(
                'nms_threshold',
                default_value='0.45',
                description='NMS IOU threshold'),
            'yolov8_encoder_launch': IncludeLaunchDescription(
                PythonLaunchDescriptionSource(
                    [os.path.join(encoder_dir, 'launch', 'dnn_image_encoder.launch.py')]
                launch_arguments={
                    'input_image_width': str(interface_specs['camera_resolution']['width']),
                    'input_image_height': str(interface_specs['camera_resolution']['height']),
                    'network_image_width': network_image_width,
                    'network_image_height': network_image_height,
                    'image_mean': image_mean,
                    'image_stddev': image_stddev,
                    'attach_to_shared_component_container': 'True',
                    'component_container_name': '/isaac_ros_examples/container',
                    'dnn_image_encoder_namespace': 'yolov8_encoder',
                    'image_input_topic': '/rgb/image_rect_color',
                    'camera_info_input_topic': '/rgb/camera_info',
                    'tensor_output_topic': '/tensor_pub',
                }.items(),
def generate_launch_description():
    foundationpose_container = ComposableNodeContainer(
        package='rclcpp_components',
        name='foundationpose_container',
        namespace='',
        executable='component_container_mt',
        composable_node_descriptions=IsaacROSFoundationPoseLaunchFragment
        .get_composable_nodes().values(),
        output='screen'
    return launch.LaunchDescription(
        [foundationpose_container] +
        IsaacROSFoundationPoseLaunchFragment.get_launch_actions().values())
The additional questions from the other post still stand. About having to feed the .obj and image texture and the presence of multiple objects. Any input would be great.
Hi @pedrosilva7320
Thank you for keeping us updated on the modified setup’s success.
The demo model works at 640x640 and the ROS 2 launch file is configurable from here isaac_ros_object_detection/isaac_ros_yolov8/launch/isaac_ros_yolov8_core.launch.py at ce43e59688d723e7367e2b849d751bf0f73c3e8c · NVIDIA-ISAAC-ROS/isaac_ros_object_detection · GitHub
The .obj file at this time is not available, but I’ll keep the engineers informed of a future release.
Raffaello
Hi @Raffaello,
Does Foundation Pose work on multiple objects present in the same scene?
Hi @pedrosilva7320
Right now, the only way to work with multiple objects is to run multiple foundation pose nodes, but this is extremely CPU/GPU-consuming.
I tracked your request for a future release.
Best,
Raffaello
