Hi all,
Thanks for this magnificent work. I came here trying to speed up Foundation Pose. However, I am having hard issues to complete it as I see RT-DETR is not so good for the mask segmentation process and, hence, the output of the pose is not good enough. In that case, I am using my custom segmentation, publishing as a ROS2 topic and trying to get it.
As Foundation pose used a .png format, with no background, I am publishing this way whether rgb8, where the image is black in the background or 8UC4.
More assumptions: As I found no .onnx model for foundation Pose I converted the .etlt to .onnx. I do not know how it works.
I created my custom package with this launch file:
import os
from ament_index_python.packages import get_package_share_directory
import launch
from launch.actions import DeclareLaunchArgument
from launch.conditions import IfCondition
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import ComposableNodeContainer, Node
from launch_ros.descriptions import ComposableNode
REFINE_MODEL_PATH = '/workspaces/isaac_ros-dev/isaac_ros_assets/models/foundationpose/refine_model.onnx'
REFINE_ENGINE_PATH = '/workspaces/isaac_ros-dev/isaac_ros_assets/models/foundationpose/refine_trt_engine.plan'
SCORE_MODEL_PATH = '/workspaces/isaac_ros-dev/isaac_ros_assets/models/foundationpose/score_model.onnx'
SCORE_ENGINE_PATH = '/workspaces/isaac_ros-dev/isaac_ros_assets/models/foundationpose/score_trt_engine.plan'
def generate_launch_description():
"""Generate launch description for testing relevant nodes."""
rviz_config_path = os.path.join(
get_package_share_directory('isaac_ros_foundationpose'),
'rviz', 'foundationpose_realsense.rviz')
launch_args = [
DeclareLaunchArgument(
'mesh_file_path',
default_value='/workspaces/models/textured_mesh.obj',
description='The absolute file path to the mesh file'),
'texture_path',
default_value='/workspaces/models/material_0.png',
description='The absolute file path to the texture map'),
'refine_model_file_path',
default_value=REFINE_MODEL_PATH,
description='The absolute file path to the refine model'),
'refine_engine_file_path',
default_value=REFINE_ENGINE_PATH,
description='The absolute file path to the refine trt engine'),
'score_model_file_path',
default_value=SCORE_MODEL_PATH,
description='The absolute file path to the score model'),
'score_engine_file_path',
default_value=SCORE_ENGINE_PATH,
description='The absolute file path to the score trt engine'),
'container_name',
default_value='foundationpose_container',
description='Name for ComposableNodeContainer'),
input_images_drop_freq = LaunchConfiguration('input_images_drop_freq')
mesh_file_path = LaunchConfiguration('mesh_file_path')
texture_path = LaunchConfiguration('texture_path')
refine_model_file_path = LaunchConfiguration('refine_model_file_path')
refine_engine_file_path = LaunchConfiguration('refine_engine_file_path')
score_model_file_path = LaunchConfiguration('score_model_file_path')
score_engine_file_path = LaunchConfiguration('score_engine_file_path')
container_name = LaunchConfiguration('container_name')
foundationpose_node = ComposableNode(
name='foundationpose_node',
package='isaac_ros_foundationpose',
plugin='nvidia::isaac_ros::foundationpose::FoundationPoseNode',
parameters=[{
'mesh_file_path': mesh_file_path,
'texture_path': texture_path,
'refine_model_file_path': refine_model_file_path,
'refine_engine_file_path': refine_engine_file_path,
'refine_input_tensor_names': ['input_tensor1', 'input_tensor2'],
'refine_input_binding_names': ['input1', 'input2'],
'refine_output_tensor_names': ['output_tensor1', 'output_tensor2'],
'refine_output_binding_names': ['output1', 'output2'],
'score_model_file_path': score_model_file_path,
'score_engine_file_path': score_engine_file_path,
'score_input_tensor_names': ['input_tensor1', 'input_tensor2'],
'score_input_binding_names': ['input1', 'input2'],
'score_output_tensor_names': ['output_tensor'],
'score_output_binding_names': ['output1'],
remappings=[
('pose_estimation/depth_image', '/zed/zed_node/depth/depth_registered'),
('pose_estimation/image', '/zed/zed_node/right/image_rect_color'),
('pose_estimation/camera_info', '/zed2i/zed_node/color/camera_info'),
('pose_estimation/segmentation', 'own_segmentation'),
('pose_estimation/output', 'output')])
rviz_node = Node(
package='rviz2',
executable='rviz2',
name='rviz2',
arguments=['-d', rviz_config_path],
condition=IfCondition(launch_rviz))
foundationpose_container = ComposableNodeContainer(
name=container_name,
namespace='',
package='rclcpp_components',
executable='component_container_mt',
composable_node_descriptions=[
foundationpose_node,
output='screen'
return launch.LaunchDescription(launch_args + [foundationpose_container,
rviz_node])`
Concretely, I am receiving this warning from NITROS:
[component_container_mt-1] [WARN] [1726831788.369381995] [foundationpose_node.NitrosSubscriber]: 40.0s passed while waiting to push a message entity (eid=704) to the receiver rgb_image_receiver
[component_container_mt-1] [WARN] [1726831788.439401150] [foundationpose_node.NitrosSubscriber]: 40.0s passed while waiting to push a message entity (eid=708) to the receiver depth_receiver
[component_container_mt-1] [WARN] [1726831794.110469395] [foundationpose_node.NitrosSubscriber]: 40.0s passed while waiting to push a message entity (eid=764) to the receiver mask_receiver
Can you help me?
Thanks in advance!
