Hi
Is it possible to enable GPUdirect RDMA on Jetson AGX Orin Development kit?
I’m using R35.3.1 version of software and compiled https://github.com/NVIDIA/gds-nvidia-fs for Jetson AGX Orin and insmod this kernel driver. However, it looks not supporting GPUdirect RDMA…
If Jetson AGX Orin is not supporting GPUdirect then Is there any plan to support this?
or Isn’t it possible to support it due to hardware limitation?
Here is the log…
@ubuntu:/usr/local/cuda-11.8$ sudo python /usr/local/cuda-11.8/gds/tools/gdscheck.py -p
GDS release version: 1.4.0.31
nvidia_fs version: 2.15 libcufile version: 2.12
Platform: aarch64
ENVIRONMENT:
DRIVER CONFIGURATION:
NVMe : Supported
NVMeOF : Unsupported
SCSI : Unsupported
ScaleFlux CSD : Unsupported
NVMesh : Unsupported
DDN EXAScaler : Unsupported
IBM Spectrum Scale : Unsupported
NFS : Unsupported
BeeGFS : Unsupported
WekaFS : Unsupported
Userspace RDMA : Unsupported
–Mellanox PeerDirect : Disabled
–rdma library : Not Loaded (libcufile_rdma.so)
–rdma devices : Not configured
–rdma_device_status : Up: 0 Down: 0
CUFILE CONFIGURATION:
properties.use_compat_mode : true
properties.force_compat_mode : false
properties.gds_rdma_write_support : true
properties.use_poll_mode : false
properties.poll_mode_max_size_kb : 4
properties.max_batch_io_size : 128
properties.max_batch_io_timeout_msecs : 5
properties.max_direct_io_size_kb : 16384
properties.max_device_cache_size_kb : 131072
properties.max_device_pinned_mem_size_kb : 33554432
properties.posix_pool_slab_size_kb : 4 1024 16384
properties.posix_pool_slab_count : 128 64 32
properties.rdma_peer_affinity_policy : RoundRobin
properties.rdma_dynamic_routing : 0
fs.generic.posix_unaligned_writes : false
fs.lustre.posix_gds_min_kb: 0
fs.beegfs.posix_gds_min_kb: 0
fs.weka.rdma_write_support: false
fs.gpfs.gds_write_support: false
profile.nvtx : false
profile.cufile_stats : 0
miscellaneous.api_check_aggressive : false
GPU INFO:
GPU index 0 Orin: Model Not Supported
PLATFORM INFO:
IOMMU: disabled
Platform verification succeeded
