20:13:53 SUMMARY: BSP Patch - target: Depends on failed component
20:13:53 SUMMARY: Multimedia API - target: Depends on failed component
20:13:53 SUMMARY: TensorRT on Target - target: Depends on failed component
20:13:53 SUMMARY: VPI on Target - target: Depends on failed component
20:13:53 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
20:13:53 SUMMARY: cuDNN on Target - target: Depends on failed component
20:13:53 SUMMARY: OpenCV - target: Depends on failed component
20:13:53 SUMMARY: DateTime Target Setup - target: Depends on failed component
20:14:09 SUMMARY: CUDA on Host - host: Install completed successfully.
20:14:09 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
20:14:09 SUMMARY: NvSci - host: Install completed successfully.
20:14:09 SUMMARY: VPI on Host - host: Install completed successfully.
20:14:09 SUMMARY: Nsight Systems - host: Install completed successfully.
20:14:09 SUMMARY: Nsight Graphics - host: Install completed successfully.
20:14:09 SUMMARY: Nsight Compute - host: Install completed successfully.
20:14:09 SUMMARY: CUPTI - host: Install completed successfully.
20:14:09 SUMMARY: Compute Sanitizer - host: Install completed successfully.
20:15:09 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
20:19:23 SUMMARY: File System and OS - target_image: Install completed successfully.
20:20:17 SUMMARY: Flash Jetson AGX Orin - flash: First Error: Installation failed.
20:20:17 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
20:20:17 SUMMARY: BSP Patch - target: Depends on failed component
20:20:17 SUMMARY: Multimedia API - target: Depends on failed component
20:20:17 SUMMARY: TensorRT on Target - target: Depends on failed component
20:20:17 SUMMARY: VPI on Target - target: Depends on failed component
20:20:17 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
20:20:17 SUMMARY: cuDNN on Target - target: Depends on failed component
20:20:17 SUMMARY: OpenCV - target: Depends on failed component
20:20:17 SUMMARY: DateTime Target Setup - target: Depends on failed component
20:22:13 SUMMARY: CUDA on Host - host: Install completed successfully.
20:22:13 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
20:22:13 SUMMARY: NvSci - host: Install completed successfully.
20:22:13 SUMMARY: VPI on Host - host: Install completed successfully.
20:22:13 SUMMARY: Nsight Systems - host: Install completed successfully.
20:22:13 SUMMARY: Nsight Graphics - host: Install completed successfully.
20:22:13 SUMMARY: Nsight Compute - host: Install completed successfully.
20:22:13 SUMMARY: CUPTI - host: Install completed successfully.
20:22:13 SUMMARY: Compute Sanitizer - host: Install completed successfully.
20:23:18 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
20:27:33 SUMMARY: File System and OS - target_image: Install completed successfully.
20:32:55 SUMMARY: Flash Jetson AGX Orin - flash: First Error: Installation failed.
20:32:55 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
20:32:55 SUMMARY: BSP Patch - target: Depends on failed component
20:32:55 SUMMARY: Multimedia API - target: Depends on failed component
20:32:55 SUMMARY: TensorRT on Target - target: Depends on failed component
20:32:55 SUMMARY: VPI on Target - target: Depends on failed component
20:32:55 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
20:32:55 SUMMARY: cuDNN on Target - target: Depends on failed component
20:32:55 SUMMARY: OpenCV - target: Depends on failed component
20:32:55 SUMMARY: DateTime Target Setup - target: Depends on failed component
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2022, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
