I am developing a personal Blender-to-Iray Server integration on Windows, using GPU rendering and MDL 1.8 materials. I can serialize closed meshes, surface BSDFs and homogeneous volume coefficients, but the current material translation does not reproduce the source subsurface transport.
Blender build d13f752e3b9c uses a dedicated random-walk path state. Its refractive entry samples GGX directions while intentionally omitting the usual GGX BSDF/pdf throughput adjustment; the skin variant also samples a diffuse entry for half of the paths. At exit, the integrator replaces the evaluated surface closures with unit diffuse scattering. A reciprocal generic material boundary evaluated at both crossings does not establish this behavior.
MDL state::direction is documented as zero in the material context, and a direct Iray GPU surface diagnostic confirmed it. Solid-object backface material selection and thin-walled volume suppression do not provide the required distinction. The public Iray manual customization chapter describes database classes and importer/exporter plugins; I have not found a documented subsurface path callback there.
Does Iray Photoreal expose a supported renderer-side BSSRDF, subsurface-path or boundary-entry/exit extension mechanism? If so, which SDK interface, matching SDK version and example should be used? If only built-in MDL transport is supported, is there an endorsed material model for this entry/exit behavior, and what limitations should be communicated?
I am requesting documented integration guidance, not assuming that every renderer extension is unavailable. This draft contains no credentials, private runtime binaries or personal scenes.
