I tried to set the pkey on the 8700 switch, I have two clusters, connected by a switch, I want to achieve the effect that the two clusters can communicate with each other, but the two clusters are not connected, I try to modify the pkey file, but it seems that my new partition does not work, or the default partition, but if I delete the default partition, the new partition still does not work.
I tried to configure the pkey file on the server, and found that the host can achieve the effect I expected, the main difference is that I do smpquery PkeyTable -D 0 I can clearly see that after the host is modified, the host modified pkey is placed first, but the pkey modified on the switch is placed after the 0x7fff.
I don’t quite understand where I have a problem configuring?
Hi Mengfei,
I think we already talked this issue offline, please UFM for best support
Thanks,
Suo
