Switching from default Jetson version (5.1.2)to 6.0+
So I just got the Jetson AGX Orin 32GB, and I already have a pc that has a flashing system for Jetson Orin Nano 16GB systems. Is there anyway I can set up that pc with the flashing system that the new device needs, without needing to remove the 16GB flashing system that works on it?
Congratulations on your new Jetson AGX Orin 32GB device!
To answer your question, it is possible to set up the existing PC with the flashing system for the new Jetson AGX Orin 32GB device without removing the existing flashing system for the Jetson Orin Nano 16GB. However, you will need to ensure that the PC meets the necessary requirements and make some adjustments to the flashing system.
Here are the steps to follow:
  1. Check the hardware requirements: Verify that the PC meets the hardware requirements for flashing the Jetson AGX Orin 32GB device. This includes having a Linux host system, a high-quality USB-C/micro-USB cable, and the necessary dependencies installed (e.g., libxml2-utils, simg2img, network-manager, abootimg, sshpass, and device-tree-compiler).
  2. Update the flashing system: You will need to update the flashing system on the PC to support the Jetson AGX Orin 32GB device. This may involve updating the nvsdkmanager_flash.sh script and the jetson-agx-orin-devkit.conf file to include the necessary configurations for the new device.
  3. Create a new configuration file: Create a new configuration file for the Jetson AGX Orin 32GB device, similar to the jetson-agx-orin-devkit.conf file. This file should include the necessary settings for the new device, such as the ODMDATA value.
  4. Modify the flashing script: Modify the nvsdkmanager_flash.sh script to support the new device. This may involve adding new options or modifying existing ones to accommodate the Jetson AGX Orin 32GB device.
  5. Test the flashing system: Once you have updated the flashing system and created a new configuration file, test the flashing process to ensure that it works correctly for the Jetson AGX Orin 32GB device.
Comparing the flashing process for the Jetson Orin Nano 16GB and Jetson AGX Orin 32GB devices, you will notice that the main differences lie in the configuration files and the ODMDATA values. The jetson-agx-orin-devkit.conf file for the Jetson AGX Orin 32GB device will have different settings than the one for the Jetson Orin Nano 16GB device.
To summarize, you can set up the existing PC with the flashing system for the new Jetson AGX Orin 32GB device without removing the existing flashing system for the Jetson Orin Nano 16GB. However, you will need to update the flashing system, create a new configuration file, and modify the flashing script to support the new device.
Here is a comparative table highlighting the main differences between the flashing processes for the two devices:
Jetson Orin Nano 16GB Jetson AGX Orin 32GB
Configuration file jetson-orin-nano-devkit.conf jetson-agx-orin-devkit.conf
ODMDATA value gbe-uphy-config-22,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g,hsstp-lane-map-3 gbe-uphy-config-22,nvhs-uphy-config-1,hsio-uphy-config-0,gbe0-enable-10g,hsstp-lane-map-3
Flashing script nvsdkmanager_flash.sh (with modifications) nvsdkmanager_flash.sh (with modifications)
Note that the ODMDATA values are different for the two devices, and the flashing script may need to be modified to accommodate the new device.
Please use the sdk manager to flash your device.
