I have compiled the samples/AppDecode/AppDec in video codec sdk.
Everything is fine when compiling.
but when running the program,
./AppDec -i ~/facenet-tensorRT/video_first_1_960.h264
GPU in use: GeForce GTX 1080
Decode with demuxing.
[INFO ][17:34:17] Media format: raw H.264 video (h264)
Session Initialization Time: 26 ms
./AppDec: symbol lookup error: ./AppDec: undefined symbol: cuvidGetDecodeStatus
there is a symbol lookup error.
And I tried ldd to find the shared libraries linked to.
linux-vdso.so.1 => (0x00007ffd691fb000)
libcuda.so.1 => /usr/lib/x86_64-linux-gnu/libcuda.so.1 (0x00007fa81717d000)
libnvcuvid.so.1 => /usr/lib/nvidia-384/libnvcuvid.so.1 (0x00007fa816d2e000)
libavcodec.so.58 => /home/tumh/ffmpeg_build/lib/libavcodec.so.58 (0x00007fa81567e000)
libavutil.so.56 => /home/tumh/ffmpeg_build/lib/libavutil.so.56 (0x00007fa815406000)
libavformat.so.58 => /home/tumh/ffmpeg_build/lib/libavformat.so.58 (0x00007fa814fb7000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fa814c35000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fa814a1f000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fa814654000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fa81434b000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fa814147000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fa813f29000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fa813d21000)
libnvidia-fatbinaryloader.so.384.103 => /usr/lib/nvidia-384/libnvidia-fatbinaryloader.so.384.103 (0x00007fa813acf000)
libGL.so.1 => /usr/lib/nvidia-384/libGL.so.1 (0x00007fa81382a000)
libswresample.so.3 => /home/tumh/ffmpeg_build/lib/libswresample.so.3 (0x00007fa81360d000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007fa8133eb000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fa8131d0000)
libbz2.so.1.0 => /lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007fa812fc0000)
/lib64/ld-linux-x86-64.so.2 (0x000055c109d52000)
libGLX.so.0 => /usr/lib/nvidia-384/libGLX.so.0 (0x00007fa812d8f000)
libGLdispatch.so.0 => /usr/lib/nvidia-384/libGLdispatch.so.0 (0x00007fa812ac1000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007fa812787000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007fa812574000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fa812352000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007fa81214e000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fa811f47000)
you can see that the executable links to /usr/lib/nvidia-384/libnvcuvid.so.1, but there is one located in NvCodec/Lib/linux/stubs/x86_64/libnvcuvid.so.
What is the difference between these two libnvcuvid.so?
it seems that the possible solution is to link NvCodec/Lib/linux/stubs/x86_64/libnvcuvid.so, not the driver’s one.
However, I tried to add the path to LD_LIBRARY_PATH, but it does not work. it still link to the driver lib.
Any advice?
Environment: cuda-8.0
