Hello, guys!
My question is about syncing two cameras (but is one device in hardware - IMX-219-83). I did perform this task with threading lib in my Python app, but I haven’t reach same result using deepstream, so, please, I need help to do this.
Here is my config I’m using for test:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=4
[tiled-display]
enable=1
rows=2
columns=1
width=1280
height=1440
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=5
camera-width=1280
camera-height=720
camera-fps-n=60
camera-fps-d=1
camera-csi-sensor-id=0
num-sources=1
gpu-id=0
[source1]
enable=1
type=5
camera-width=1280
camera-height=720
camera-fps-n=60
camera-fps-d=1
camera-csi-sensor-id=1
num-sources=1
gpu-id=0
[streammux]
gpu-id=0
batch-size=2
batched-push-timeout=40000
#Set muxer output width and height
width=1280
height=1440
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
[sink1]
enable=1
type=2
sync=1
source-id=1
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
The result is not almost synced. I need exactly match to obtain disparity map and use stereo-algorithms.
