This is what I’m trying to achieve:
1.) AGX output PPS
2.) AGX synched with PTP from external device
3.) PPS output synched with PTP
I have got 1 and 2, but not 3. The PPS is not disciplined with PTP.
Is there a setup of the product that supports the configuration I’m looking for?
I have been through quite a few forums attempting to solve this issue. The closest we come on AGX is PPS input to drive NTP here (unresolved):
NTP with PPS Support on Xavier AGX - Jetson & Embedded Systems / Jetson AGX Xavier - NVIDIA Developer Forums
And PTP to drive PPS output here (original question unresolved, solved by modifying driver code in software, but modified code not provided)
PTP synchronization and PPS output from Nvidia NX - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
