Hey everyone,
I’ve run into a consistent issue on Linux when connecting a fourth monitor to my RTX 4090 using the proprietary NVIDIA driver.
As soon as I connect a 4th monitor (in my case a valve index) to the GPU while the system is running, the system freezes.
I also can’t boot with 4 monitors connected to the GPU. Then it crashes while booting as soon as the Nvidia driver is loaded.
- No mouse movement
- No keyboard input
- No TTY switch possible
- The system is completely unresponsive and requires a hard reboot.
Hardware:
- GPU: NVIDIA RTX 4090
- CPU: AMD Ryzen 9 7950X3D
- Motherboard: Gigabyte B650 Aorus Elite V2
- Monitors:
- 1x LG 32GS95UE 3840x2160 240Hz
- 1x VG278 1920x1080 60Hz
- 1x SAMSUNG RU7099 2560x1440 60Hz (here i also cant go to 4k 60hz, on windows i can)
- 1x Valve index (i will try tomorrow with a normal 4th monitor)
Software/Environment:
Distributions tested: Bazitte (Wayland) & Manjaro (X11) – same issue on both
Desktop environment: KDE Plasma
NVIDIA Driver version:** 570.133.07
Kernel: 6.13.9-103.bazzite.fc42.x86_64 (64-bit)
- Almost everything is fine with 3 monitors connected to the RTX 4090. (except for the Samsung TV which I can’t set to 4k with 60hz)
- If I connect the 4th monitor to the mainboard, the system runs fine – even though the CPU has no iGPU (which is strange, since it shouldn’t display anything).
- On Windows, everything works perfectly with all 4 monitors connected to the RTX 4090.
- Linux with the default graphics driver works fine as well, without the screen freezing – the issue only occurs with the NVIDIA driver.
Please note: I tried Linux for the first time 2 days ago. It took me 2 days to realize that the 4th monitor + the Nvidia driver is the cause of the crashes.
I have attached some logs from the Bazitte Wayland system, but if you need more information, I am willing to provide it. I used ChatGPT to help me here.
I’m also not sure if the logs contain the problem, because I can’t create any logs as soon as all 4 graphics card slots are occupied and therefore the system crashes.
nvidia-bug-report.log.gz (464.8 KB)
nvidiawayland_log.txt (684.0 KB)
wayland_log.txt (56.0 MB)
Xorg.0.log (46.6 KB)
