System throttld due to over-current
Module:orin nx 16G ;
Version:35.4.1
power: MAXN
In the process of running software, current alarm。
This has affected the use of customer experience, please help to see what is the solution?
Orin NX has power limitation. Using MAXN mode will exceed that power limitation and cause this throttling.
You need to use power estimator to create a mode that matches your usecase.
https://jetson-tools.nvidia.com/powerestimator/
