System Throttled due to Overcurrent
During finetuning an LLM using GRPO for my research project, i received this warning multiple times. I am not sure how to solve this. Should I follow the process that was suggested for Orin in this post: System throttled due to Over-current on Orin NX - #6 by sorry.shao
I am sharing my power GUI screenshot here. I am using the device in 120W model
- events = [oc.OcEvent(), thermal.ThermalThrottleAlert(THROTTLE_ALERT), thermal.ThermalThrottleAlert(HOT_SURFACE_ALERT)]
+ events = [thermal.ThermalThrottleAlert(THROTTLE_ALERT), thermal.ThermalThrottleAlert(HOT_SURFACE_ALERT)]
Hi SomeRandomGuy314,
I would suggest you create the custom power mode configuration(rather than default 120W power mode) according to your use case.
e.g. It seems the high loading for cpu9 but not for other cores, maybe you can reduce the max CPU frequency.
If you just want to disable the warning messages, you can refer to what sorry.shao suggested.
