CSPdarknet19 classifier was trained with the latest TAO version, there is an error during export. Please find the command and its output below.
tao classification export -m /workspace/tlt-experiments/trainings/results_cspdarknet19/cspdarknet_150.tlt -o /workspace/tlt-experiments/trainings/results_cspdarknet19/cspdarknet_150_fp16_new.etlt --data_type fp16 --gen_ds_config --engine_file /workspace/tlt-experiments/trainings/results_cspdarknet19/cspdarknet_150_fp16_new.engine --verbose
2022-02-14 04:46:59,459 [INFO] root: Registry: ['nvcr.io']
2022-02-14 04:46:59,639 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.5-py3
2022-02-14 04:46:59,673 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/ubuntu/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2022-02-14 04:47:27,016 [INFO] root: Building exporter object.
2022-02-14 04:47:32,291 [INFO] root: Exporting the model.
2022-02-14 04:47:32,291 [INFO] root: Using input nodes: ['input_1']
2022-02-14 04:47:32,292 [INFO] root: Using output nodes: ['predictions/Softmax']
2022-02-14 04:47:32,292 [INFO] iva.common.export.keras_exporter: Using input nodes: ['input_1']
2022-02-14 04:47:32,292 [INFO] iva.common.export.keras_exporter: Using output nodes: ['predictions/Softmax']
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
Warning: keepdims is ignored by the UFF Parser and defaults to True
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking ['predictions/Softmax'] as outputs
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/makenet/scripts/export.py", line 36, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/makenet/scripts/export.py", line 32, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py", line 247, in run_export
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/keras_exporter.py", line 394, in export
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/makenet/export/classification_exporter.py", line 71, in get_class_labels
File "/usr/lib/python3.6/genericpath.py", line 19, in exists
os.stat(path)
TypeError: stat: path should be string, bytes, os.PathLike or integer, not NoneType
2022-02-14 04:47:55,824 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
• Classification CSPdarknet19
• TAO Version nvidia/tao/tao-toolkit-tf: v3.21.11-tf1.15.5-py3
