Config file :-
spec.txt (2.0 KB)
Tao version :- docker_tag: v3.21.08-py3
Network type → yolo_v4
I am unable to export tlt file to .etlt format as in the terminal facing the issue shown below:-
google.protobuf.text_format.ParseError: 1:1 : Message type “Experiment” has no field named “model_config”.
2022-02-02 13:42:21,641 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I am using below command to export the model file from .tlt to .etlt :-
command :- tao yolo_v4 export -m /workspace/tao-experiments/results/weights/resnet_100.tlt -e /workspace/tao-experiments/specs/spec.txt -k KEY
I have also attached the configuration file for your reference.
Looking forward for help from your side.
