Hi.
According to the documentation and select the first option for ingesting training data, we do not need to include **--cal_image_dir** and **--cal_data_file**.
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/export.py", line 12, in <module>
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py", line 219, in launch_export
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py", line 201, in run_export
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/keras_exporter.py", line 360, in export
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py", line 184, in get_calibrator
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py", line 284, in generate_tensor_file
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py", line 327, in generate_random_tensorfile
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/tensorfile.py", line 54, in __init__
File "/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py", line 312, in __init__
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File "/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py", line 148, in make_fid
fid = h5f.create(name, h5f.ACC_TRUNC, fapl=fapl, fcpl=fcpl)
File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
File "h5py/h5f.pyx", line 98, in h5py.h5f.create
ValueError: Invalid file name (invalid file name)
Using TensorFlow backend.
write export results to /workspace/tlt/local_dir/tlt_yolov3_pv_resnet18/unpruned_model/export
Thanks for help.
I use tlt version3 inside the docker and I wrote all task commands in the same way (train, evaluate, inference, prune) Also there is no problem when I set --cal_image_dir and --cal_data_file. But I think these are not needed.
But since it is also mentioned that we can use option 1 and using the training data loader, I thought the export is the same for all object detection models.
I am new to TLT. Excuse me if my questions are confusing.
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/faster_rcnn/scripts/export.py", line 12, in <module>
TypeError: get_calibrator() got an unexpected keyword argument 'image_mean'
But the cal.bin is not generated successfully due to above error. It is a regression issue in tlt 3.0-py3.
For workaround, please login 3.0-dp-py3 docker and run the same command to generate cal.bin.
Sorry for inconvenience.
