Hello Jachen,
PFB the TegraSystemProfiler.log after running the command cp nvlog.config.template nvlog.config
12651 CrashReporter Server 9 client 8 for process
12651 CrashReporter Starting pipeServer.
12655 AppLib_Script Loading QuadDPlugin
12655 AppLib_Script Loading CorePlugin
12655 Adb_Forwarding AdbForwardingPool[0x7ac050]: was created: starting port=15555 size=5
12659 Interface Status: AdbExeNotFound
Props {
Items {
Type: ErrorText
Value: "/home/android/buildAgent/work/host-x64-linux/Rel/QuadD_Juliet/sw/devtools/Agora/Rel/QuadD_Juliet/QuadD/Host/Analysis/AdbClient.cpp(112): Throw in function static void QuadDAnalysis::AdbServerManager::Start()\nDynamic exception type: N5boost16exception_detail10clone_implIN13QuadDAnalysis23AdbExeNotFoundExceptionEEE\nstd::exception::what: AdbExeNotFoundException\n[PN5boost25errinfo_nested_exception_E] = \n
12655 Project Explorer Restored projects: 1, going to read from file immediately: 1.
12655 Interface Version: 2.6.20651219 Linux
12655 Qt QStateMachine::addState: state has already been added to this machine
12655 Qt MainState::onEntry()
12655 Qt [ProjectExplorer] Saved 1 projects.
12674 Interface Project saved to file: /home/test/.tegraprofiler/Projects/Project 1/Project 1.qdproj
12655 SshDevice SshDevice[0xdb1700]: constructed
12655 DeviceValidator SshDeviceValidator[0xcb01c0]: constructed, device=SSH-0x0x7b2cf0
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: DeviceValidationStarted
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndConnect
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: ConnectingDevice
12655 Interface Status: DeviceValidationStarted (40), SSH-0x0x7b2cf0.
12655 Interface Status: ConnectingDevice (30), SSH-0x0x7b2cf0.
13022 Interface Project saved to file: /home/test/.tegraprofiler/Projects/Project 1/Project 1.qdproj
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckSudoAskPasswordProgram
12660 SshDevice SshDevice[0xdb1700]: command= which nc
12660 SshDevice SshDevice[0xdb1700]: output = /bin/nc
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckHasRoot
12660 SshDevice SshDevice[0xdb1700]: command= cat /proc/quadd/version 2>/dev/null || echo ERROR
12660 SshDevice SshDevice[0xdb1700]: output = version: 1.104
branch: Dev
samples version: 34
io version: 18
12660 SshDevice SshDevice[0xdb1700]: command= cat /proc/meminfo
12660 SshDevice SshDevice[0xdb1700]: output = MemTotal: 3946224 kB
MemFree: 2912952 kB
MemAvailable: 3361348 kB
Buffers: 35184 kB
Cached: 389456 kB
SwapCached: 0 kB
Active: 334800 kB
Inactive: 266772 kB
Active(anon): 177648 kB
Inactive(anon): 14808 kB
Active(file): 157152 kB
Inactive(file): 251964 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirt
12660 SshDevice SshDevice[0xdb1700]: command= cat /proc/cpuinfo
12660 SshDevice SshDevice[0xdb1700]: output = Processor : Cortex A57 Processor rev 1 (aarch64)
processor : 0
processor : 1
processor : 2
processor : 3
Features : fp asimd aes pmull sha1 sha2 crc32 wp half thumb fastmult vfp edsp neon vfpv3 tlsi vfpv4 idiva idivt
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 1
Hardware : jetson_tx1
Revision : 0000
Serial : 088403e800000000
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/cpu.emc/min
12660 SshDevice SshDevice[0xdb1700]: output = 0
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/cpu.emc/max
12660 SshDevice SshDevice[0xdb1700]: output = 1600000000
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/3d/min
12660 SshDevice SshDevice[0xdb1700]: exit code = 1 output = error output=sudo: timestamp too far in the future: Jul 18 17:47:14 2016
cat: /sys/kernel/debug/clock/3d/min: No such file or directory
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/gk20a.gbus/min
12660 SshDevice SshDevice[0xdb1700]: exit code = 1 output = error output=cat: /sys/kernel/debug/clock/gk20a.gbus/min: No such file or directory
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/gm20b.gbus/min
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/3d/max
12660 SshDevice SshDevice[0xdb1700]: exit code = 1 output = error output=cat: /sys/kernel/debug/clock/3d/max: No such file or directory
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/gk20a.gbus/max
12660 SshDevice SshDevice[0xdb1700]: exit code = 1 output = error output=cat: /sys/kernel/debug/clock/gk20a.gbus/max: No such file or directory
12660 SshDevice SshDevice[0xdb1700]: command=cat /sys/kernel/debug/clock/gm20b.gbus/max
12660 SshDevice SshDevice[0xdb1700]: output = 998400000
12660 SshDevice SshDevice[0xdb1700]: command= cat /proc/version
12660 SshDevice SshDevice[0xdb1700]: output = Linux version 3.10.67-g458d45c (buildbrain@mobile-u64-630) (gcc version 4.9 20140514 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Feb 8 17:44:18 PST 2016
12660 SshDevice SshDevice[0xdb1700]: command=xxd -p /proc/device-tree/mc/channels | tr -d 0
12660 SshDevice SshDevice[0xdb1700]: output = 2
12660 SshDevice SshDevice[0xdb1700]: command=echo OK
12660 SshDevice SshDevice[0xdb1700]: output = OK
12660 SshDevice SshDevice[0xdb1700]: command= lsb_release --description --short
12660 SshDevice SshDevice[0xdb1700]: output = Ubuntu 14.04.1 LTS
12660 SshDevice SshDevice[0xdb1700]: command= uname -m || echo ERROR
12660 SshDevice SshDevice[0xdb1700]: output = aarch64
12660 SshDevice SshDevice[0xdb1700]: command= [ -x /lib/ld-linux-aarch64.so.1 ] && echo $?
12660 SshDevice SshDevice[0xdb1700]: exit code=1 output=
12660 SshDevice SshDevice[0xdb1700]: command= [ -x /lib/ld-linux-armhf.so.3 ] && echo $?
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndForceUninstallDaemon
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndUninstallOutdatedDaemon
12660 SshDevice SshDevice[0xdb1700]: command=/opt/nvidia/tegra_system_profiler/quadd_d --build_id
12660 SshDevice SshDevice[0xdb1700]: output = 20651219
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: Host build id=20651219 daemon build id=20651219
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndInstallDaemon
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: CheckingDaemonExecutable
12660 SshDevice SshDevice[0xdb1700]: command= test -x /opt/nvidia/tegra_system_profiler/quadd_d
12655 Interface Status: CheckingDaemonExecutable (33), SSH-0x0x7b2cf0.
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/quadd_d
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndStartDaemon
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: StartingDaemon
12655 Interface Status: StartingDaemon (24), SSH-0x0x7b2cf0.
12660 SshDevice SshDevice[0xdb1700]: output = Welcome to Tegra System Profiler!
uid=0, pid=2478
branch=Charlie
version=2.6.20651219
build_id=20651219
build_date=Apr 16 2016 at 03:16:41
samples_version=35
io_version=19
bitness: 32-bit
release configuration: yes
Parent process exits, child pid=2479.
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndOccupyDevice
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: CheckingDeviceOccupancy
12655 Interface Status: CheckingDeviceOccupancy (90), SSH-0x0x7b2cf0.
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndInitKernelModule
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: CheckingKernelModule
12655 Interface Status: CheckingKernelModule (26), SSH-0x0x7b2cf0.
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: KernelModuleInitialization
12655 Interface Status: KernelModuleInitialization (29), SSH-0x0x7b2cf0.
12660 LinuxDevice Number of present CPU=4
12660 LinuxDevice CPU id=0 max frequency=1734.00Mhz; pmu arch=Cortex A57
12660 LinuxDevice CPU id=1 max frequency=1734.00Mhz; pmu arch=Cortex A57
12660 LinuxDevice CPU id=2 max frequency=1734.00Mhz; pmu arch=Cortex A57
12660 LinuxDevice CPU id=3 max frequency=1734.00Mhz; pmu arch=Cortex A57
12660 SshDevice SshDevice[0xdb1700]: exit code = 1 output = error output=cat: /sys/kernel/debug/clock/3d/min: No such file or directory
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndInstallToolLibraries
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: InstallingToolLibraries
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libToolsInjection32.so
12655 Interface Status: InstallingToolLibraries (60), SSH-0x0x7b2cf0.
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libToolsInjection32.so: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libToolsInjectionProxy32.so
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libToolsInjectionProxy32.so: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libToolsInjectionCudaInt32_6_5.so
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libToolsInjectionCudaInt32_6_5.so: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libToolsInjectionCudaInt32_7_0.so
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libToolsInjectionCudaInt32_7_0.so: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libToolsInjectionCudaInt32_7_5.so
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libToolsInjectionCudaInt32_7_5.so: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libToolsInjectionCudaInt32_8_0.so
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libToolsInjectionCudaInt32_8_0.so: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libLauncher32.so
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libLauncher32.so: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/launcher
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: launcher: present
12660 SshDevice SshDevice[0xdb1700]: command= test -s /opt/nvidia/tegra_system_profiler/libBw32.so
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: libBw32.so: present
12660 DeviceValidator SshDeviceValidator[0xcb01c0]: device=SSH-0x0x7b2cf0 step=CheckAndFinish
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: DeviceOk
12660 DeviceValidator IDeviceValidatorImpl[0xcb01c0]: status=Status: DeviceValidationFinished
12655 Interface Status: DeviceOk (1), SSH-0x0x7b2cf0.
12655 Interface Device went online: SSH-0x0x7b2cf0.
12655 Interface Status: DeviceValidationFinished (41), SSH-0x0x7b2cf0.
12655 Qt MainState::onExit()
12655 Qt ProfilingState::onEntry()
13028 DeviceValidator SshDeviceValidator[0x7f44d40008e0]: constructed, device=SSH-0x0x7b2cf0
13028 DeviceValidator SshDeviceValidator[0x7f44d40008e0]: device=SSH-0x0x7b2cf0 step=CheckAndStartDaemonShort
13028 DeviceValidator SshDeviceValidator[0x7f44d40008e0]: device=SSH-0x0x7b2cf0 step=CheckAndStartKernelModuleShort
13028 SshDevice SshDevice[0xdb1700]: command= cat /proc/quadd/status 2>/dev/null || echo ERROR
13028 SshDevice SshDevice[0xdb1700]: output = status: waiting
auth: no
all samples: 0
skipped samples: 0
13028 QuadDAnalysis AnalysisSession[0xf4b5e0]: Application was started: pid=2720 process=./HOG package= commargs=–video video.avi
13029 QuadDAnalysis AnalysisSession[0xf4b5e0]: Analysis was started.
12663 PerfModule Downloaded bytes=524471, total downloaded bytes=524471
12664 PerfModule Downloaded events=2, downloaded events total=2
12664 SymbolAnalyzer SymbolAnalyzer[0x7f4504000ec0]: Symbol analyzer created
12662 PerfModule Downloaded events=13, downloaded events total=15
12662 PerfModule Downloaded events=12720, downloaded events total=12735
12664 PerfModule Downloaded bytes=524192, total downloaded bytes=1048663
12666 PerfModule Downloaded events=9582, downloaded events total=22317
12666 PerfModule Downloaded bytes=524204, total downloaded bytes=1572867
12665 PerfModule Downloaded events=9359, downloaded events total=31676
12665 PerfModule Downloaded bytes=524232, total downloaded bytes=2097099
12663 PerfModule Downloaded events=9273, downloaded events total=40949
12663 PerfModule Downloaded bytes=524223, total downloaded bytes=2621322
12664 PerfModule Downloaded events=9385, downloaded events total=50334
12666 PerfModule Downloaded bytes=524197, total downloaded bytes=3145519
12663 PerfModule Downloaded events=9323, downloaded events total=59657
12663 PerfModule Downloaded bytes=524269, total downloaded bytes=3669788
12666 PerfModule Downloaded events=9340, downloaded events total=68997
12664 PerfModule Downloaded bytes=524239, total downloaded bytes=4194027
12665 PerfModule Downloaded events=9236, downloaded events total=78233
12664 PerfModule Downloaded bytes=524185, total downloaded bytes=4718212
12666 PerfModule Downloaded events=9124, downloaded events total=87357
12663 PerfModule Downloaded bytes=524226, total downloaded bytes=5242438
12666 PerfModule Downloaded events=9335, downloaded events total=96692
12666 SymbolAnalyzer Processing kernel symbols: ffffffc000080000-ffffffc001385b10(19946256 bytes)
12662 PerfModule Downloaded bytes=524226, total downloaded bytes=5766664
12663 PerfModule Downloaded events=9407, downloaded events total=106099
12662 PerfModule Downloaded bytes=524277, total downloaded bytes=6290941
12663 PerfModule Downloaded events=9307, downloaded events total=115406
12665 PerfModule Downloaded bytes=524248, total downloaded bytes=6815189
12663 PerfModule Downloaded events=9310, downloaded events total=124716
12663 PerfModule Downloaded bytes=524281, total downloaded bytes=7339470
12665 PerfModule Downloaded events=9414, downloaded events total=134130
12663 PerfModule Downloaded bytes=524234, total downloaded bytes=7863704
12664 PerfModule Downloaded events=9286, downloaded events total=143416
12662 PerfModule Downloaded bytes=524279, total downloaded bytes=8387983
12663 PerfModule Downloaded events=9299, downloaded events total=152715
12664 PerfModule Downloaded bytes=524172, total downloaded bytes=8912155
12663 PerfModule Downloaded events=9449, downloaded events total=162164
12664 PerfModule Downloaded bytes=524208, total downloaded bytes=9436363
12663 PerfModule Downloaded events=9383, downloaded events total=171547
12662 PerfModule Downloaded bytes=524236, total downloaded bytes=9960599
12665 PerfModule Downloaded events=9375, downloaded events total=180922
12666 SymbolAnalyzer Kernel symbol data received.
12666 SymbolAnalyzer Kernel build id : 7D816EE8B0DD51B078987D13B4F5E2EEB616D574
12666 SymbolAnalyzer Loading module: ffffffc000080000-ffffffc001385b10(19946256 bytes) pgoff=0 targetFileName=[kernel.kallsyms] hostFileName= isKernel=yes elfObject=no
12666 SymbolAnalyzer Loading module: ffff0000-ffff1000(4096 bytes) pgoff=4294901760 targetFileName=[vectors] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer SymbolAnalyzer[0x7f4504000ec0]:
ELF file info:filename=/home/ubuntu/simple-apps/opencv_hog/HOG size=360809
debuglink: filename= crc=0
buildId=D48D2D01A5AAE4A318BAB10785C7548C5BD3D832
dynsectcrc=
sepfile: filename= size=0
12666 SymbolAnalyzer Original file found in the cache: remote=/home/ubuntu/simple-apps/opencv_hog/HOG local=
12666 SymbolAnalyzer Loading module: 8000-16000(57344 bytes) pgoff=0 targetFileName=/home/ubuntu/simple-apps/opencv_hog/HOG hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/HOG/D48D2D01A5AAE4A318BAB10785C7548C5BD3D832/HOG isKernel=no elfObject=yes
12666 SymbolAnalyzer Loading module: dc751000-dcf50000(8384512 bytes) pgoff=3698659328 targetFileName=[vma:dc751000-dcf50000] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer Loading module: dcf51000-dd750000(8384512 bytes) pgoff=3707047936 targetFileName=[vma:dcf51000-dd750000] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer Loading module: e0d01000-e1500000(8384512 bytes) pgoff=3771731968 targetFileName=[vma:e0d01000-e1500000] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer Loading module: e1501000-e1d00000(8384512 bytes) pgoff=3780120576 targetFileName=[vma:e1501000-e1d00000] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer Loading module: e1f01000-e2700000(8384512 bytes) pgoff=3790606336 targetFileName=[vma:e1f01000-e2700000] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer Loading module: e2701000-e2f00000(8384512 bytes) pgoff=3798994944 targetFileName=[vma:e2701000-e2f00000] hostFileName= isKernel=no elfObject=no
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libltdl.so.7.3.0 size=26288
debuglink: filename=libltdl.so.7.3.0 crc=-408022069
buildId=8644B1D04410A8E4603F117B940B53C2E00C59EB
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libltdl.so.7.3.0 local=
12666 SymbolAnalyzer Loading module: e32ba000-e32bf000(20480 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libltdl.so.7.3.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libltdl.so.7.3.0/8644B1D04410A8E4603F117B940B53C2E00C59EB/libltdl.so.7.3.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libtdb.so.1.2.12 size=46676
debuglink: filename=libtdb.so.1.2.12 crc=-1328770152
buildId=3E0EFE475E5E5D50619100FA61F59D41E7D85DD2
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libtdb.so.1.2.12 local=
12666 SymbolAnalyzer Loading module: e32c9000-e32d4000(45056 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libtdb.so.1.2.12 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libtdb.so.1.2.12/3E0EFE475E5E5D50619100FA61F59D41E7D85DD2/libtdb.so.1.2.12 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libvorbisfile.so.3.3.4 size=22112
debuglink: filename=ff5ef2d80af8f8082a5046a695986121869b4c.debug crc=295258508
buildId=12FF5EF2D80AF8F8082A5046A695986121869B4C
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libvorbisfile.so.3.3.4 local=
12666 SymbolAnalyzer Loading module: e32dd000-e32e2000(20480 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libvorbisfile.so.3.3.4 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libvorbisfile.so.3.3.4/12FF5EF2D80AF8F8082A5046A695986121869B4C/libvorbisfile.so.3.3.4 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libcanberra.so.0.2.5 size=51004
debuglink: filename=libcanberra.so.0.2.5 crc=-1608572204
buildId=62D14D07440F94FAB658975CB764DAEA5EBD7054
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libcanberra.so.0.2.5 local=
12666 SymbolAnalyzer Loading module: e32eb000-e32f7000(49152 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libcanberra.so.0.2.5 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libcanberra.so.0.2.5/62D14D07440F94FAB658975CB764DAEA5EBD7054/libcanberra.so.0.2.5 isKernel=no elfObject=yes
12666 SymbolAnalyzer Loading module: e3301000-e3b00000(8384512 bytes) pgoff=3811577856 targetFileName=[vma:e3301000-e3b00000] hostFileName= isKernel=no elfObject=no
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/gio/modules/libdconfsettings.so size=30724
debuglink: filename=libdconfsettings.so crc=-2016664823
buildId=ED2A450320E7A8AEDC6CA0BA8A277EE6DB469B24
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/gio/modules/libdconfsettings.so local=
12666 SymbolAnalyzer Loading module: e3c19000-e3c20000(28672 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/gio/modules/libdconfsettings.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libdconfsettings.so/ED2A450320E7A8AEDC6CA0BA8A277EE6DB469B24/libdconfsettings.so isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/gtk-2.0/2.10.0/engines/libmurrine.so size=121140
debuglink: filename=c92f53fc06ece04d395073f7e4f95c67e58fdc.debug crc=-202362188
buildId=69C92F53FC06ECE04D395073F7E4F95C67E58FDC
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/gtk-2.0/2.10.0/engines/libmurrine.so local=
12666 SymbolAnalyzer Loading module: e3c29000-e3c46000(118784 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/gtk-2.0/2.10.0/engines/libmurrine.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libmurrine.so/69C92F53FC06ECE04D395073F7E4F95C67E58FDC/libmurrine.so isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libunity-gtk2-parser.so.0.0.0 size=47104
debuglink: filename=d50bc2cc7e46f71fd19a1af2c7b100fcc88da8.debug crc=222356292
buildId=50D50BC2CC7E46F71FD19A1AF2C7B100FCC88DA8
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libunity-gtk2-parser.so.0.0.0 local=
12666 SymbolAnalyzer Loading module: e3c4f000-e3c5a000(45056 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libunity-gtk2-parser.so.0.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libunity-gtk2-parser.so.0.0.0/50D50BC2CC7E46F71FD19A1AF2C7B100FCC88DA8/libunity-gtk2-parser.so.0.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libcanberra-gtk.so.0.1.9 size=13888
debuglink: filename=libcanberra-gtk.so.0.1.9 crc=1991713577
buildId=29F7252AE506D8BE51DC424BFF55C8CE6E0B475F
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libcanberra-gtk.so.0.1.9 local=
12666 SymbolAnalyzer Loading module: e3c6a000-e3c6d000(12288 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libcanberra-gtk.so.0.1.9 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libcanberra-gtk.so.0.1.9/29F7252AE506D8BE51DC424BFF55C8CE6E0B475F/libcanberra-gtk.so.0.1.9 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/libcanberra-gtk-module.so size=18084
debuglink: filename=libcanberra-gtk-module.so crc=-1408974188
buildId=E391837AA8EF4940E8224E5F86C2F2CECD45CBA6
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/libcanberra-gtk-module.so local=
12666 SymbolAnalyzer Loading module: e3c76000-e3c7a000(16384 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/libcanberra-gtk-module.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libcanberra-gtk-module.so/E391837AA8EF4940E8224E5F86C2F2CECD45CBA6/libcanberra-gtk-module.so isKernel=no elfObject=yes
12666 SymbolAnalyzer Loading module: e3c84000-e4483000(8384512 bytes) pgoff=3821551616 targetFileName=[vma:e3c84000-e4483000] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer Loading module: e4484000-e4c83000(8384512 bytes) pgoff=3829940224 targetFileName=[vma:e4484000-e4c83000] hostFileName= isKernel=no elfObject=no
12666 SymbolAnalyzer Loading module: e4c84000-e5483000(8384512 bytes) pgoff=3838328832 targetFileName=[vma:e4c84000-e5483000] hostFileName= isKernel=no elfObject=no
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libOpenCL.so.1.0.0 size=22120
debuglink: filename=1a23ce055bbcedf4d13601604f9d72a79f65ca.debug crc=1540728582
buildId=BF1A23CE055BBCEDF4D13601604F9D72A79F65CA
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libOpenCL.so.1.0.0 local=
12666 SymbolAnalyzer Loading module: e5935000-e593a000(20480 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libOpenCL.so.1.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libOpenCL.so.1.0.0/BF1A23CE055BBCEDF4D13601604F9D72A79F65CA/libOpenCL.so.1.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/libunity-gtk-module.so size=14016
debuglink: filename=c03a5932c7258417b297b2bed873c7489f8976.debug crc=-318000449
buildId=58C03A5932C7258417B297B2BED873C7489F8976
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/libunity-gtk-module.so local=
12666 SymbolAnalyzer Loading module: eb709000-eb70c000(12288 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/libunity-gtk-module.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libunity-gtk-module.so/58C03A5932C7258417B297B2BED873C7489F8976/libunity-gtk-module.so isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/liboverlay-scrollbar.so size=47288
debuglink: filename=41d0f695a2845d4ddddc4b85d3b9c85030495b.debug crc=1987060959
buildId=1841D0F695A2845D4DDDDC4B85D3B9C85030495B
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/liboverlay-scrollbar.so local=
12666 SymbolAnalyzer Loading module: eb715000-eb720000(45056 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/gtk-2.0/modules/liboverlay-scrollbar.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/liboverlay-scrollbar.so/1841D0F695A2845D4DDDDC4B85D3B9C85030495B/liboverlay-scrollbar.so isKernel=no elfObject=yes
12666 SymbolAnalyzer Loading module: eb7e3000-ebfe2000(8384512 bytes) pgoff=3950915584 targetFileName=[vma:eb7e3000-ebfe2000] hostFileName= isKernel=no elfObject=no
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/tegra/libnvos.so size=59012
buildId=
dynsectcrc=87a641c2
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/tegra/libnvos.so local=
12666 SymbolAnalyzer Loading module: ec362000-ec370000(57344 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/tegra/libnvos.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libnvos.so/87a641c2/libnvos.so isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/tegra/libnvrm.so size=75724
buildId=
dynsectcrc=d5e9da3b
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/tegra/libnvrm.so local=
12666 SymbolAnalyzer Loading module: ec379000-ec38b000(73728 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/tegra/libnvrm.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libnvrm.so/d5e9da3b/libnvrm.so isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/tegra/libcuda.so.1.1 size=11730312
debuglink: filename=libcuda.so.debug crc=-1578002605
buildId=
dynsectcrc=0ffcd7ac
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/tegra/libcuda.so.1.1 local=
12666 SymbolAnalyzer Loading module: ec3b5000-ece51000(11124736 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/tegra/libcuda.so.1.1 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libcuda.so.1.1/0ffcd7ac/libcuda.so.1.1 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/pkcs11/p11-kit-trust.so size=137616
debuglink: filename=0110788ab0ce24aaba28fe861c7276cdb43f42.debug crc=1872367432
buildId=5F0110788AB0CE24AABA28FE861C7276CDB43F42
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/pkcs11/p11-kit-trust.so local=
12666 SymbolAnalyzer Loading module: ecf1e000-ecf3b000(118784 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/pkcs11/p11-kit-trust.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/p11-kit-trust.so/5F0110788AB0CE24AABA28FE861C7276CDB43F42/p11-kit-trust.so isKernel=no elfObject=yes
12666 SymbolAnalyzer Loading module: ecf49000-ed748000(8384512 bytes) pgoff=3975450624 targetFileName=[vma:ecf49000-ed748000] hostFileName= isKernel=no elfObject=no
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libdatrie.so.1.3.1 size=13648
debuglink: filename=libdatrie.so.1.3.1 crc=-1959979117
buildId=5F38DC36F568A2D9BD4390B8E9B14A89876755D4
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libdatrie.so.1.3.1 local=
12666 SymbolAnalyzer Loading module: ed74e000-ed751000(12288 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libdatrie.so.1.3.1 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libdatrie.so.1.3.1/5F38DC36F568A2D9BD4390B8E9B14A89876755D4/libdatrie.so.1.3.1 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libgraphite2.so.3.0.1 size=67140
debuglink: filename=0987534ef4d1f8585ba2d4ccb4754779e5efb7.debug crc=148597242
buildId=980987534EF4D1F8585BA2D4CCB4754779E5EFB7
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libgraphite2.so.3.0.1 local=
12666 SymbolAnalyzer Loading module: ed75a000-ed769000(61440 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libgraphite2.so.3.0.1 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libgraphite2.so.3.0.1/980987534EF4D1F8585BA2D4CCB4754779E5EFB7/libgraphite2.so.3.0.1 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libgpg-error.so.0.10.0 size=13664
debuglink: filename=libgpg-error.so.0.10.0 crc=-963443167
buildId=185B3FA6AA47651F1184AA57A779F8A34F13F9FA
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libgpg-error.so.0.10.0 local=
12666 SymbolAnalyzer Loading module: ed773000-ed776000(12288 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libgpg-error.so.0.10.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libgpg-error.so.0.10.0/185B3FA6AA47651F1184AA57A779F8A34F13F9FA/libgpg-error.so.0.10.0 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libdbus-1.so.3.7.6 size=165920
debuglink: filename=d054acc7ec44bebdd87a31320aa374132f2dcf.debug crc=-1130971952
buildId=2DD054ACC7EC44BEBDD87A31320AA374132F2DCF
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libdbus-1.so.3.7.6 local=
12666 SymbolAnalyzer Loading module: ed780000-ed7a8000(163840 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libdbus-1.so.3.7.6 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libdbus-1.so.3.7.6/2DD054ACC7EC44BEBDD87A31320AA374132F2DCF/libdbus-1.so.3.7.6 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libnih-dbus.so.1.0.0 size=30124
debuglink: filename=7d5aedf49be75e6ccac57321d14a4fae41eb82.debug crc=-1791217744
buildId=287D5AEDF49BE75E6CCAC57321D14A4FAE41EB82
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libnih-dbus.so.1.0.0 local=
12666 SymbolAnalyzer Loading module: ed7b1000-ed7b7000(24576 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libnih-dbus.so.1.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libnih-dbus.so.1.0.0/287D5AEDF49BE75E6CCAC57321D14A4FAE41EB82/libnih-dbus.so.1.0.0 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libnih.so.1.0.0 size=66996
debuglink: filename=b6e4b49d1461cd9dcc1fe30a9417de19873983.debug crc=-407769138
buildId=77B6E4B49D1461CD9DCC1FE30A9417DE19873983
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libnih.so.1.0.0 local=
12666 SymbolAnalyzer Loading module: ed7c1000-ed7d1000(65536 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libnih.so.1.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libnih.so.1.0.0/77B6E4B49D1461CD9DCC1FE30A9417DE19873983/libnih.so.1.0.0 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libcgmanager.so.0.0.0 size=83312
debuglink: filename=96dd1e7401bea23b698116a1041762cfaa8eb7.debug crc=1521752734
buildId=FD96DD1E7401BEA23B698116A1041762CFAA8EB7
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libcgmanager.so.0.0.0 local=
12666 SymbolAnalyzer Loading module: ed7da000-ed7ee000(81920 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libcgmanager.so.0.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libcgmanager.so.0.0.0/FD96DD1E7401BEA23B698116A1041762CFAA8EB7/libcgmanager.so.0.0.0 isKernel=no elfObject=yes
ELF file info:filename=/home/ubuntu/opencv-3.1.0/lib/libopencv_flann.so.3.1.0 size=340694
buildId=BAA8A2BCEF10C9C82BA6953B8FC3D9BA71401BC8
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/home/ubuntu/opencv-3.1.0/lib/libopencv_flann.so.3.1.0 local=
12666 SymbolAnalyzer Loading module: ed7f7000-ed827000(196608 bytes) pgoff=0 targetFileName=/home/ubuntu/opencv-3.1.0/lib/libopencv_flann.so.3.1.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libopencv_flann.so.3.1.0/BAA8A2BCEF10C9C82BA6953B8FC3D9BA71401BC8/libopencv_flann.so.3.1.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnpps.so.7.0.73 size=2444176
buildId=
dynsectcrc=f19641cf
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnpps.so.7.0.73 local=
12666 SymbolAnalyzer Loading module: ed832000-eda84000(2433024 bytes) pgoff=0 targetFileName=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnpps.so.7.0.73 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libnpps.so.7.0.73/f19641cf/libnpps.so.7.0.73 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libXdmcp.so.6.0.0 size=13740
debuglink: filename=libXdmcp.so.6.0.0 crc=-884609955
buildId=E89657C50B7AAF61FC5E55A89582D636BD120734
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libXdmcp.so.6.0.0 local=
12666 SymbolAnalyzer Loading module: edab6000-edab9000(12288 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libXdmcp.so.6.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libXdmcp.so.6.0.0/E89657C50B7AAF61FC5E55A89582D636BD120734/libXdmcp.so.6.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libXau.so.6.0.0 size=9640
debuglink: filename=libXau.so.6.0.0 crc=2015090205
buildId=C993DDBCD753E6C2DB180E71F10236E76041B117
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libXau.so.6.0.0 local=
12666 SymbolAnalyzer Loading module: edac2000-edac4000(8192 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libXau.so.6.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libXau.so.6.0.0/C993DDBCD753E6C2DB180E71F10236E76041B117/libXau.so.6.0.0 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libexpat.so.1.6.0 size=95788
debuglink: filename=libexpat.so.1.6.0 crc=-1526409514
buildId=8FDA051477003C4D4E8A734776A57D22AC9E899D
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libexpat.so.1.6.0 local=
12666 SymbolAnalyzer Loading module: edacd000-edae2000(86016 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libexpat.so.1.6.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libexpat.so.1.6.0/8FDA051477003C4D4E8A734776A57D22AC9E899D/libexpat.so.1.6.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libthai.so.0.2.0 size=23956
debuglink: filename=libthai.so.0.2.0 crc=-192795887
buildId=4D3BF896CED78C9B3D83630BB7CBD04D2E5DA3E4
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libthai.so.0.2.0 local=
12666 SymbolAnalyzer Loading module: edaee000-edaf3000(20480 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libthai.so.0.2.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libthai.so.0.2.0/4D3BF896CED78C9B3D83630BB7CBD04D2E5DA3E4/libthai.so.0.2.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0.927.0 size=231308
debuglink: filename=e4af93177baf3e97a324535a43786f66e2f05c.debug crc=497793146
buildId=3DE4AF93177BAF3E97A324535A43786F66E2F05C
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0.927.0 local=
12666 SymbolAnalyzer Loading module: edafc000-edb34000(229376 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libharfbuzz.so.0.927.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libharfbuzz.so.0.927.0/3DE4AF93177BAF3E97A324535A43786F66E2F05C/libharfbuzz.so.0.927.0 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libresolv-2.19.so size=55168
debuglink: filename=libresolv-2.19.so crc=1684980886
buildId=8E2C700EB7A2767E890B19DB455A6CE2133850C8
dynsectcrc=
sepfile: filename=/usr/lib/debug/lib/arm-linux-gnueabihf/libresolv-2.19.so size=244384
12666 SymbolAnalyzer Debugging file found in the cache: remote=/usr/lib/debug/lib/arm-linux-gnueabihf/libresolv-2.19.so local=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libresolv-2.19.so/8E2C700EB7A2767E890B19DB455A6CE2133850C8/debug/libresolv-2.19.so
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libresolv-2.19.so local=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libresolv-2.19.so/8E2C700EB7A2767E890B19DB455A6CE2133850C8/debug/libresolv-2.19.so
12666 SymbolAnalyzer ELF file section is empty : section=.text filename=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libresolv-2.19.so/8E2C700EB7A2767E890B19DB455A6CE2133850C8/debug/libresolv-2.19.so
12666 SymbolAnalyzer Loading module: edb3d000-edb4a000(53248 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libresolv-2.19.so hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libresolv-2.19.so/8E2C700EB7A2767E890B19DB455A6CE2133850C8/libresolv-2.19.so isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libselinux.so.1 size=84004
debuglink: filename=3531729d64d9000fae6e2d3e272862af16751a.debug crc=-2035011255
buildId=E13531729D64D9000FAE6E2D3E272862AF16751A
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libselinux.so.1 local=
12666 SymbolAnalyzer Loading module: edb55000-edb69000(81920 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libselinux.so.1 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libselinux.so.1/E13531729D64D9000FAE6E2D3E272862AF16751A/libselinux.so.1 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libp11-kit.so.0.0.0 size=155172
debuglink: filename=c306c0b31a85ea75c2c63766c9a6f6a734f5fb.debug crc=858790710
buildId=50C306C0B31A85EA75C2C63766C9A6F6A734F5FB
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libp11-kit.so.0.0.0 local=
12666 SymbolAnalyzer Loading module: edb73000-edb95000(139264 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libp11-kit.so.0.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libp11-kit.so.0.0.0/50C306C0B31A85EA75C2C63766C9A6F6A734F5FB/libp11-kit.so.0.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libtasn1.so.6.2.0 size=46696
debuglink: filename=6c2d8144969fc543af41569618085e749815e4.debug crc=1621526610
buildId=876C2D8144969FC543AF41569618085E749815E4
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libtasn1.so.6.2.0 local=
12666 SymbolAnalyzer Loading module: edba2000-edbad000(45056 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libtasn1.so.6.2.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libtasn1.so.6.2.0/876C2D8144969FC543AF41569618085E749815E4/libtasn1.so.6.2.0 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libgcrypt.so.11.8.2 size=376604
debuglink: filename=2c86c4901cbd001a753449661cdd232c0e0c75.debug crc=-755291749
buildId=A42C86C4901CBD001A753449661CDD232C0E0C75
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libgcrypt.so.11.8.2 local=
12666 SymbolAnalyzer Loading module: edbb6000-edc0f000(364544 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libgcrypt.so.11.8.2 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libgcrypt.so.11.8.2/A42C86C4901CBD001A753449661CDD232C0E0C75/libgcrypt.so.11.8.2 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libogg.so.0.8.1 size=17684
debuglink: filename=libogg.so.0.8.1 crc=-91614342
buildId=44EA093FEB4E65AAEBF78401573ED7C241AA92D3
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libogg.so.0.8.1 local=
12666 SymbolAnalyzer Loading module: edc1a000-edc1e000(16384 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libogg.so.0.8.1 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libogg.so.0.8.1/44EA093FEB4E65AAEBF78401573ED7C241AA92D3/libogg.so.0.8.1 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/libudev.so.1.3.5 size=46572
debuglink: filename=59a0b4c84d5dfda54dfcdf7493ec6a0cf0d34d.debug crc=-1638300755
buildId=2959A0B4C84D5DFDA54DFCDF7493EC6A0CF0D34D
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/libudev.so.1.3.5 local=
12666 SymbolAnalyzer Loading module: edc27000-edc32000(45056 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/libudev.so.1.3.5 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libudev.so.1.3.5/2959A0B4C84D5DFDA54DFCDF7493EC6A0CF0D34D/libudev.so.1.3.5 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/liborc-0.4.so.0.18.0 size=328892
debuglink: filename=1f775f4e40a45356eb6865584991a9b7908fd0.debug crc=-1181805372
buildId=521F775F4E40A45356EB6865584991A9B7908FD0
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/liborc-0.4.so.0.18.0 local=
12666 SymbolAnalyzer Loading module: edc3c000-edc88000(311296 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/liborc-0.4.so.0.18.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/liborc-0.4.so.0.18.0/521F775F4E40A45356EB6865584991A9B7908FD0/liborc-0.4.so.0.18.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libIlmThread.so.6.0.0 size=18076
debuglink: filename=8cc0034e63f9950c3788f97a5a481d84c975aa.debug crc=-29897673
buildId=5E8CC0034E63F9950C3788F97A5A481D84C975AA
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libIlmThread.so.6.0.0 local=
12666 SymbolAnalyzer Loading module: edc94000-edc98000(16384 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libIlmThread.so.6.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libIlmThread.so.6.0.0/5E8CC0034E63F9950C3788F97A5A481D84C975AA/libIlmThread.so.6.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libIex.so.6.0.0 size=80896
debuglink: filename=663d362cc88144b4e5c103d34ce0bdc9968910.debug crc=1511350286
buildId=1C663D362CC88144B4E5C103D34CE0BDC9968910
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libIex.so.6.0.0 local=
12666 SymbolAnalyzer Loading module: edca1000-edcb3000(73728 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libIex.so.6.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libIex.so.6.0.0/1C663D362CC88144B4E5C103D34CE0BDC9968910/libIex.so.6.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libjbig.so.0 size=41036
buildId=8F02A6BD002C0568279DD80225E049DFA2DFFB33
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libjbig.so.0 local=
12666 SymbolAnalyzer Loading module: edcbd000-edcc4000(28672 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libjbig.so.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libjbig.so.0/8F02A6BD002C0568279DD80225E049DFA2DFFB33/libjbig.so.0 isKernel=no elfObject=yes
ELF file info:filename=/lib/arm-linux-gnueabihf/liblzma.so.5.0.0 size=95804
debuglink: filename=27597d60163e65a0a0d819f9e517f821f7cc33.debug crc=2139251110
buildId=1D27597D60163E65A0A0D819F9E517F821F7CC33
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/lib/arm-linux-gnueabihf/liblzma.so.5.0.0 local=
12666 SymbolAnalyzer Loading module: edccf000-edce5000(90112 bytes) pgoff=0 targetFileName=/lib/arm-linux-gnueabihf/liblzma.so.5.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/liblzma.so.5.0.0/1D27597D60163E65A0A0D819F9E517F821F7CC33/liblzma.so.5.0.0 isKernel=no elfObject=yes
ELF file info:filename=/home/ubuntu/opencv-3.1.0/lib/libopencv_calib3d.so.3.1.0 size=1026568
buildId=CF0CC71A6B1253729A4E3F584582D8BCCBD3E2F7
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/home/ubuntu/opencv-3.1.0/lib/libopencv_calib3d.so.3.1.0 local=
12666 SymbolAnalyzer Loading module: edcf0000-eddcc000(901120 bytes) pgoff=0 targetFileName=/home/ubuntu/opencv-3.1.0/lib/libopencv_calib3d.so.3.1.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libopencv_calib3d.so.3.1.0/CF0CC71A6B1253729A4E3F584582D8BCCBD3E2F7/libopencv_calib3d.so.3.1.0 isKernel=no elfObject=yes
ELF file info:filename=/home/ubuntu/opencv-3.1.0/lib/libopencv_cudaimgproc.so.3.1.0 size=5058343
buildId=A75CF773A14120D3274222B9A9F36BE5FB1B200B
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/home/ubuntu/opencv-3.1.0/lib/libopencv_cudaimgproc.so.3.1.0 local=
12666 SymbolAnalyzer Loading module: eddd5000-ee1da000(4214784 bytes) pgoff=0 targetFileName=/home/ubuntu/opencv-3.1.0/lib/libopencv_cudaimgproc.so.3.1.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libopencv_cudaimgproc.so.3.1.0/A75CF773A14120D3274222B9A9F36BE5FB1B200B/libopencv_cudaimgproc.so.3.1.0 isKernel=no elfObject=yes
ELF file info:filename=/home/ubuntu/opencv-3.1.0/lib/libopencv_cudafilters.so.3.1.0 size=46512360
buildId=331BBC0252963EDE0186C264CA1B3CC587FFF9F0
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/home/ubuntu/opencv-3.1.0/lib/libopencv_cudafilters.so.3.1.0 local=
12666 SymbolAnalyzer Loading module: ee201000-f0a95000(42549248 bytes) pgoff=0 targetFileName=/home/ubuntu/opencv-3.1.0/lib/libopencv_cudafilters.so.3.1.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libopencv_cudafilters.so.3.1.0/331BBC0252963EDE0186C264CA1B3CC587FFF9F0/libopencv_cudafilters.so.3.1.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libcufft.so.7.0.73 size=9078136
buildId=
dynsectcrc=d50b7ede
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libcufft.so.7.0.73 local=
12666 SymbolAnalyzer Loading module: f0aa9000-f12d8000(8581120 bytes) pgoff=0 targetFileName=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libcufft.so.7.0.73 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libcufft.so.7.0.73/d50b7ede/libcufft.so.7.0.73 isKernel=no elfObject=yes
ELF file info:filename=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnppi.so.7.0.73 size=23959104
buildId=
dynsectcrc=10128524
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnppi.so.7.0.73 local=
12666 SymbolAnalyzer Loading module: f13e7000-f2ab5000(23912448 bytes) pgoff=0 targetFileName=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnppi.so.7.0.73 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libnppi.so.7.0.73/10128524/libnppi.so.7.0.73 isKernel=no elfObject=yes
ELF file info:filename=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnppc.so.7.0.73 size=395860
buildId=
dynsectcrc=f74cabd9
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnppc.so.7.0.73 local=
12666 SymbolAnalyzer Loading module: f2aff000-f2b5e000(389120 bytes) pgoff=0 targetFileName=/usr/local/cuda-7.0/targets/armv7-linux-gnueabihf/lib/libnppc.so.7.0.73 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libnppc.so.7.0.73/f74cabd9/libnppc.so.7.0.73 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libxcb.so.1.1.0 size=71296
debuglink: filename=56cba467166a8ad9f582a12a3abf2d88721c98.debug crc=28315546
buildId=5E56CBA467166A8AD9F582A12A3ABF2D88721C98
dynsectcrc=
sepfile: filename=/usr/lib/debug/.build-id/5e/56cba467166a8ad9f582a12a3abf2d88721c98.debug size=162942
12666 SymbolAnalyzer Debugging file found in the cache: remote=/usr/lib/debug/.build-id/5e/56cba467166a8ad9f582a12a3abf2d88721c98.debug local=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libxcb.so.1.1.0/5E56CBA467166A8AD9F582A12A3ABF2D88721C98/debug/libxcb.so.1.1.0
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libxcb.so.1.1.0 local=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libxcb.so.1.1.0/5E56CBA467166A8AD9F582A12A3ABF2D88721C98/debug/libxcb.so.1.1.0
12666 SymbolAnalyzer ELF file section is empty : section=.text filename=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libxcb.so.1.1.0/5E56CBA467166A8AD9F582A12A3ABF2D88721C98/debug/libxcb.so.1.1.0
12666 SymbolAnalyzer Loading module: f2b68000-f2b79000(69632 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libxcb.so.1.1.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libxcb.so.1.1.0/5E56CBA467166A8AD9F582A12A3ABF2D88721C98/libxcb.so.1.1.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libxcb-render.so.0.0.0 size=21928
debuglink: filename=3bd4246eee6c346570897fc0a183fddc55e113.debug crc=728910368
buildId=943BD4246EEE6C346570897FC0A183FDDC55E113
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libxcb-render.so.0.0.0 local=
12666 SymbolAnalyzer Loading module: f2b82000-f2b87000(20480 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libxcb-render.so.0.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libxcb-render.so.0.0.0/943BD4246EEE6C346570897FC0A183FDDC55E113/libxcb-render.so.0.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0.0.0 size=9640
debuglink: filename=c2e4df47a39e7c5721a7323095b9cc2b8ef554.debug crc=-687291416
buildId=66C2E4DF47A39E7C5721A7323095B9CC2B8EF554
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0.0.0 local=
12666 SymbolAnalyzer Loading module: f2b90000-f2b92000(8192 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libxcb-shm.so.0.0.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libxcb-shm.so.0.0.0/66C2E4DF47A39E7C5721A7323095B9CC2B8EF554/libxcb-shm.so.0.0.0 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libfreetype.so.6.11.1 size=386908
debuglink: filename=77ccc8d410cb84bff3e3a368756e218a270de2.debug crc=1311788874
buildId=F477CCC8D410CB84BFF3E3A368756E218A270DE2
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libfreetype.so.6.11.1 local=
12666 SymbolAnalyzer Loading module: f2b9c000-f2bf7000(372736 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libfreetype.so.6.11.1 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libfreetype.so.6.11.1/F477CCC8D410CB84BFF3E3A368756E218A270DE2/libfreetype.so.6.11.1 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libpixman-1.so.0.30.2 size=481120
debuglink: filename=libpixman-1.so.0.30.2 crc=757706714
buildId=BDCE7CA60C2244B89269A1B2621B01FC7D5170AB
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libpixman-1.so.0.30.2 local=
12666 SymbolAnalyzer Loading module: f2c03000-f2c74000(462848 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libpixman-1.so.0.30.2 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libpixman-1.so.0.30.2/BDCE7CA60C2244B89269A1B2621B01FC7D5170AB/libpixman-1.so.0.30.2 isKernel=no elfObject=yes
ELF file info:filename=/usr/lib/arm-linux-gnueabihf/libXext.so.6.4.0 size=39064
debuglink: filename=libXext.so.6.4.0 crc=-1538313202
buildId=9555BE14258294C7DD0A76569D8BBDDB8C24D3CF
dynsectcrc=
12666 SymbolAnalyzer Original file found in the cache: remote=/usr/lib/arm-linux-gnueabihf/libXext.so.6.4.0 local=
12666 SymbolAnalyzer Loading module: f2c81000-f2c8a000(36864 bytes) pgoff=0 targetFileName=/usr/lib/arm-linux-gnueabihf/libXext.so.6.4.0 hostFileName=/home/test/.tegraprofiler/NVIDIA Corporation/Tegra Profiler/cache/libXext.so.6.4.0/9555BE14258294C7DD0A76569D8BBDDB8C24D3CF/libXext.so.6.4.0 isKernel=no elfObject=yes
12666 SymbolAn
