suchb
#1
hello,
My tx2 working with Jetpack4.2(linux kernel 4.9.140),and I use scripts/rt-patech.sh apply the patches,rebuild kernel and reboot.
crash massage as follows:
[ 8.633097] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 8.646162] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 8.655484] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 8.665925] parse_throttle_dt_data: Num cap clks = 4
[ 8.672437] parse_throttle_dt_data: clk=mcpu type=1
[ 8.678864] parse_throttle_dt_data: clk=bcpu type=2
[ 8.685217] parse_throttle_dt_data: clk=gpu type=4
[ 8.691456] parse_throttle_dt_data: clk=emc type=3
[ 8.698740] tegra_throttle_probe: probe successful. #cdevs=4
[ 8.706616] FAN: coudln't get the regulator
[ 8.714097] device-mapper: uevent: version 1.0.3
[ 8.721118] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 8.736115] cpufreq: platform driver Initialization: pass
[ 8.743147] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 8.750984] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 8.759516] sdhci: Secure Digital Host Controller Interface driver
[ 8.766779] sdhci: Copyright(c) Pierre Ossman
[ 8.772153] sdhci-pltfm: SDHCI platform and OF driver helper
[ 8.780556] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 8.790774] CMDQ: cmdq_platfm_init successful
[ 8.797583] CQE: CMD_TIMING bit set for R1B DCMD
[ 8.797747] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 8.800475] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.800519] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 8.803483] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 8.806338] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 8.811065] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 8.811946] tegra-se-nvhost 15810000.se: initialized
[ 8.813099] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 8.813961] tegra-se-nvhost 15820000.se: initialized
[ 8.821908] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 8.822647] tegra-se-nvhost 15830000.se: initialized
[ 8.823368] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 8.824235] tegra-se-nvhost 15840000.se: initialized
[ 8.825731] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 8.826107] hidraw: raw HID events driver (C) Jiri Kosina
[ 8.827376] usbcore: registered new interface driver usbhid
[ 8.827378] usbhid: USB HID core driver
[ 8.830450] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 8.833474] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 8.833885] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 8.834080] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 8.834496] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 8.835499] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 8.835584] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 8.835657] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 8.835722] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 8.835855] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 8.836981] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 8.836984] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 8.838137] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 8.839654] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 8.840311] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 8.840534] register_ari_mca_banks: Registered MCA ROC:IOB
[ 8.840606] register_ari_mca_banks: Registered MCA ROC:CCE
[ 8.840937] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.840940] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 8.840942] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 8.840999] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841002] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 8.841004] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 8.841070] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841072] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 8.841074] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 8.841214] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841217] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 8.841219] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 8.841282] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841285] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 8.841287] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 8.841382] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841387] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 8.841389] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 8.841453] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841458] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 8.841460] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 8.841554] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841559] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 8.841583] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 8.841645] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841650] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 8.841652] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 8.841741] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841745] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 8.841747] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 8.841807] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841813] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 8.841815] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 8.841907] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841912] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 8.841914] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 8.841969] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.841975] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 8.841977] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 8.842070] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.842076] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 8.842078] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 8.842136] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.842141] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 8.842143] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 8.842217] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 8.842280] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 8.843035] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 8.843576] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 8.843714] denver_knobs_init:MTS_VERSION:43068234
[ 8.845493] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 8.845569] nvpmodel: initialized successfully
[ 8.849322] usbcore: registered new interface driver snd-usb-audio
[ 8.856884] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 8.856941] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 8.870619] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 8.870983] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 8.935335] OPE platform probe
[ 8.935426] OPE platform probe successful
[ 8.947277] tegra-asoc: sound: This is a dummy codec
[ 8.993058] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 8.993173] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 8.993246] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 8.993319] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 8.993388] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 8.993464] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 8.993534] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 8.993605] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 8.993677] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 8.993745] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 8.993818] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 8.993886] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 8.993957] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 8.994028] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 8.994103] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 8.994176] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 8.994247] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 8.994315] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 8.994383] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 8.994465] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 9.019843] u32 classifier
[ 9.019844] Actions configured
[ 9.019900] Initializing XFRM netlink socket
[ 9.020491] NET: Registered protocol family 10
[ 9.025161] NET: Registered protocol family 17
[ 9.025172] NET: Registered protocol family 15
[ 9.025238] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 9.025285] Bluetooth: RFCOMM socket layer initialized
[ 9.025295] Bluetooth: RFCOMM ver 1.11
[ 9.025299] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 9.025303] Bluetooth: HIDP socket layer initialized
[ 9.025317] 9pnet: Installing 9P2000 support
[ 9.025349] Key type dns_resolver registered
[ 9.025570] Registered cp15_barrier emulation handler
[ 9.025577] Registered setend emulation handler
[ 9.026516] registered taskstats version 1
[ 9.029380] isp 15600000.isp: initialized
[ 9.033353] nvcsi 150c0000.nvcsi: initialized
[ 9.040064] tegra-vi4 15700000.vi: initialized
[ 9.040238] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 9.040347] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 9.040455] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 9.040574] input: gpio-keys as /devices/gpio-keys/input/input2
[ 9.041028] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--3 bound
[ 9.041043] tegra-vi4 15700000.vi: subdev ov5693_sdi1 0-0036 bound
[ 9.041650] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--2 bound
[ 9.041656] tegra-vi4 15700000.vi: subdev ov5693_sdi2 8-001f bound
[ 9.042102] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 9.042107] tegra-vi4 15700000.vi: subdev ov5693_av 2-0036 bound
[ 9.073812] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:21 UTC (946688421)
[ 9.091898] mmc1: hw tuning done ...
[ 9.098619] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 9.107852] bpmp: mounted debugfs mirror
[ 9.108802] bwmgr: missing cdev-type property
[ 9.115095] spmic-ldo0: disabling
[ 9.115261] spmic-ldo1: disabling
[ 9.115418] en-vdd-sd: disabling
[ 9.115420] vdd-usb0-5v: disabling
[ 9.115421] vdd-usb1-5v: disabling
[ 9.115423] vdd-3v3: disabling
[ 9.115424] en-vdd-vcm-2v8: disabling
[ 9.115426] vdd-usb2-5v: disabling
[ 9.115427] vdd-sys-bl: disabling
[ 9.115428] ALSA device list:
[ 9.115430] #0: tegra-hda at 0x3518000 irq 383
[ 9.115431] #1: tegra-snd-t186ref-mobile-rt565x
[ 9.980009] Waiting for root device /dev/mmcblk0p1...
[ 10.021215] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 10.094839] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 10.117263] mmc0: periodic cache flush enabled
[ 10.122570] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 10.130341] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 10.135999] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 10.143097] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 10.150717] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 10.161628] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 10.212305] EXT4-fs (mmcblk0p1): recovery complete
[ 10.218208] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.227370] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 10.240784] devtmpfs: mounted
[ 10.247237] Freeing unused kernel memory: 8512K
[ 10.426549] systemd[1]: System time before build time, advancing clock.
[ 10.496880] cgroup: cgroup2: unknown option "nsdelegate"
[ 10.527530] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN)
[ 10.554406] systemd[1]: Detected architecture arm64.
[ 10.659721] systemd[1]: Set hostname to <nvidia>.
[ 10.701136] BUG: scheduling while atomic: systemd-cryptse/2215/0x00010001
[ 10.701138] Modules linked in:
[ 10.701142] CPU: 0 PID: 2215 Comm: systemd-cryptse Not tainted 4.9.140-rt93 #112
[ 10.701143] Hardware name: quill (DT)
[ 10.701144] Call trace:
[ 10.701153] [<ffffff800808b6d8>] dump_backtrace+0x0/0x198
[ 10.701156] [<ffffff800808bc9c>] show_stack+0x24/0x30
[ 10.701161] [<ffffff8008454f54>] dump_stack+0x98/0xbc
[ 10.701164] [<ffffff80080e75dc>] __schedule_bug+0x64/0x80
[ 10.701168] [<ffffff8008f346e0>] __schedule+0x540/0x598
[ 10.701170] [<ffffff8008f34780>] schedule+0x48/0xe0
[ 10.701172] [<ffffff8008f35f8c>] rt_spin_lock_slowlock+0x22c/0x308
[ 10.701174] [<ffffff8008f380d8>] rt_spin_lock+0x50/0x60
[ 10.701178] [<ffffff8008b6e61c>] cpufreq_acct_update_power+0xa4/0x280
[ 10.701180] [<ffffff80080f2b3c>] account_user_time+0xc4/0xd8
[ 10.701182] [<ffffff80080f2f6c>] irqtime_account_process_tick.isra.1+0x1fc/0x238
[ 10.701184] [<ffffff80080f3184>] account_process_tick+0xac/0xc8
[ 10.701186] [<ffffff800813cc58>] update_process_times+0x28/0x60
[ 10.701189] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 10.701191] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 10.701192] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 10.701194] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 10.701197] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 10.701200] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 10.701201] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 10.701203] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 10.701205] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 10.701206] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 10.701208] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 10.701209] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 10.701211] [<ffffff8008082df4>] el0_irq_naked+0x54/0x60
[ 10.701225] ------------[ cut here ]------------
[ 10.701230] WARNING: CPU: 0 PID: 2215 at kernel/events/core.c:3437 perf_event_task_tick+0x2cc/0x320
[ 10.701231] Modules linked in:
[ 10.701232]
[ 10.701234] CPU: 0 PID: 2215 Comm: systemd-cryptse Tainted: G W 4.9.140-rt93 #112
[ 10.701235] Hardware name: quill (DT)
[ 10.701236] task: ffffffc1e49d9e00 task.stack: ffffffc1e2ae8000
[ 10.701238] PC is at perf_event_task_tick+0x2cc/0x320
[ 10.701240] LR is at scheduler_tick+0xb8/0x180
[ 10.701242] pc : [<ffffff80081be39c>] lr : [<ffffff80080edc18>] pstate: 40400045
[ 10.701243] sp : ffffffc1f7031c80
[ 10.701245] x29: ffffffc1f7031c80 x28: ffffffc1e49d9e00
[ 10.701247] x27: ffffff800814f780 x26: 0000000000000000
[ 10.701248] x25: 0000000277923320 x24: ffffff8009814018
[ 10.701250] x23: ffffffc1e49d9e00 x22: ffffffc1f7036f38
[ 10.701251] x21: ffffff8009e4b468 x20: ffffff8009820000
[ 10.701253] x19: ffffffc1f703a9c0 x18: 0000000000000060
[ 10.701254] x17: 0000000000000000 x16: ffffffc1e49d9e00
[ 10.701255] x15: 0000000000000000 x14: 00000000018f6743
[ 10.701257] x13: 00000000000003ea x12: 0000000000000000
[ 10.701258] x11: ffffff8008f499d0 x10: 0000000000000000
[ 10.701260] x9 : ffffff8008f499d8 x8 : 00000000000003ea
[ 10.701261] x7 : 0000000000000004 x6 : ffffffc1f703a9f0
[ 10.701263] x5 : 00000000000003ed x4 : 00000041ed81a000
[ 10.701264] x3 : 000000000000000f x2 : 0000000000000040
[ 10.701265] x1 : ffffff800981cf38 x0 : ffffff800981c000
[ 10.701266]
[ 10.701267] ---[ end trace 0000000000000002 ]---
[ 10.701267] Call trace:
[ 10.701269] [<ffffff80081be39c>] perf_event_task_tick+0x2cc/0x320
[ 10.701271] [<ffffff80080edc18>] scheduler_tick+0xb8/0x180
[ 10.701273] [<ffffff800813cc5c>] update_process_times+0x2c/0x60
[ 10.701275] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 10.701277] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 10.701279] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 10.701280] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 10.701282] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 10.701283] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 10.701285] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 10.701286] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 10.701288] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 10.701290] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 10.701291] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 10.701292] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 10.701294] [<ffffff8008082df4>] el0_irq_naked+0x54/0x60
[ 10.701331] ------------[ cut here ]------------
[ 10.701333] kernel BUG at kernel/time/posix-cpu-timers.c:1301!
[ 10.701335] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 10.701338] Modules linked in:
[ 10.701340] CPU: 0 PID: 2215 Comm: systemd-cryptse Tainted: G W 4.9.140-rt93 #112
[ 10.701340] Hardware name: quill (DT)
[ 10.701341] task: ffffffc1e49d9e00 task.stack: ffffffc1e2ae8000
[ 10.701345] PC is at run_posix_cpu_timers+0xf0/0xf8
[ 10.701346] LR is at update_process_times+0x50/0x60
[ 10.701347] pc : [<ffffff8008143bf0>] lr : [<ffffff800813cc80>] pstate: 40400045
[ 10.701348] sp : ffffffc1f7031d00
[ 10.701350] x29: ffffffc1f7031d00 x28: ffffffc1e49d9e00
[ 10.701351] x27: ffffff800814f780 x26: 0000000000000000
[ 10.701353] x25: 0000000277923320 x24: ffffff8009814018
[ 10.701354] x23: ffffff8009e49688 x22: ffffffc1f7035680
[ 10.701355] x21: ffffffc1f7035c70 x20: 0000000000000001
[ 10.701357] x19: ffffffc1e49d9e00 x18: 0000000000000b7d
[ 10.701358] x17: 0000000000000001 x16: 0000000000000000
[ 10.701359] x15: 0000000000000000 x14: 0000000000000b1b
[ 10.701361] x13: 0000000000003c20 x12: 0000000000000400
[ 10.701362] x11: 0000000000000001 x10: 0000000000000b20
[ 10.701363] x9 : ffffffc1f7031b90 x8 : ffffffc1e49da980
[ 10.701365] x7 : 0000000000000000 x6 : 0000000000000400
[ 10.701366] x5 : 00000000000002f0 x4 : 0000000000000000
[ 10.701367] x3 : 0000000000000000 x2 : 0000000000000000
[ 10.701368] x1 : 00000041ed81a000 x0 : 0000000000000040
[ 10.701369]
[ 10.701370] Process systemd-cryptse (pid: 2215, stack limit = 0xffffffc1e2ae8000)
[ 10.701371] Call trace:
[ 10.701373] [<ffffff8008143bf0>] run_posix_cpu_timers+0xf0/0xf8
[ 10.701374] [<ffffff800813cc80>] update_process_times+0x50/0x60
[ 10.701376] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 10.701378] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 10.701380] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 10.701381] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 10.701383] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 10.701384] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 10.701386] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 10.701387] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 10.701389] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 10.701390] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 10.701392] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 10.701393] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 10.701395] [<ffffff8008082df4>] el0_irq_naked+0x54/0x60
[ 11.505369] ---[ end trace 0000000000000003 ]---
[ 11.597477] systemd[2213]: /lib/systemd/system-generators/systemd-cryptsetup-generator terminated by signal SEGV.
[ 11.632562] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 11.650866] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 11.884855] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.896613] systemd[1]: Created slice User and Session Slice.
[ 11.905301] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.913517] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.923965] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.931826] systemd[1]: Reached target Swap.
[ 11.946478] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
suchb
#2
add crash log
[ 10.938992] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.947952] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 10.961099] devtmpfs: mounted
[ 10.966948] Freeing unused kernel memory: 8512K
[ 11.174260] cgroup: cgroup2: unknown option "nsdelegate"
[ 11.194439] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN)
[ 11.218946] systemd[1]: Detected architecture arm64.
[ 11.254751] systemd[1]: Set hostname to <nvidia>.
[ 11.293964] BUG: scheduling while atomic: systemd-hiberna/2222/0x00010001
[ 11.293966] BUG: scheduling while atomic: systemd-system-/2224/0x00010001
[ 11.293977] Modules linked in:
[ 11.293978] BUG: scheduling while atomic: systemd-getty-g/2221/0x00010001
[ 11.293980] Modules linked in:
[ 11.293983] Modules linked in:
[ 11.293986] CPU: 5 PID: 2222 Comm: systemd-hiberna Not tainted 4.9.140-rt93 #112
[ 11.293988] Hardware name: quill (DT)
[ 11.293990] Call trace:
[ 11.293998] [<ffffff800808b6d8>] dump_backtrace+0x0/0x198
[ 11.294001] [<ffffff800808bc9c>] show_stack+0x24/0x30
[ 11.294006] [<ffffff8008454f54>] dump_stack+0x98/0xbc
[ 11.294009] [<ffffff80080e75dc>] __schedule_bug+0x64/0x80
[ 11.294014] [<ffffff8008f346e0>] __schedule+0x540/0x598
[ 11.294016] [<ffffff8008f34780>] schedule+0x48/0xe0
[ 11.294018] [<ffffff8008f35f8c>] rt_spin_lock_slowlock+0x22c/0x308
[ 11.294021] [<ffffff8008f380d8>] rt_spin_lock+0x50/0x60
[ 11.294024] [<ffffff8008b6e658>] cpufreq_acct_update_power+0xe0/0x280
[ 11.294027] [<ffffff80080f2f20>] irqtime_account_process_tick.isra.1+0x1b0/0x238
[ 11.294029] [<ffffff80080f3184>] account_process_tick+0xac/0xc8
[ 11.294033] [<ffffff800813cc58>] update_process_times+0x28/0x60
[ 11.294036] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 11.294038] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 11.294040] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 11.294041] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 11.294044] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 11.294047] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 11.294049] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 11.294050] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 11.294052] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 11.294054] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 11.294056] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 11.294057] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 11.294058] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 11.294062] [<ffffff8008219548>] ptep_clear_flush+0x68/0x90
[ 11.294065] [<ffffff8008203a78>] wp_page_copy+0x2c0/0x7d8
[ 11.294067] [<ffffff8008204edc>] do_wp_page+0xc4/0x5d0
[ 11.294069] [<ffffff8008208fe0>] handle_mm_fault+0x830/0xc90
[ 11.294071] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 11.294072] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 11.294074] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 11.294075] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 11.294078] CPU: 0 PID: 2224 Comm: systemd-system- Tainted: G W 4.9.140-rt93 #112
[ 11.294079] Hardware name: quill (DT)
[ 11.294080] Call trace:
[ 11.294084] [<ffffff800808b6d8>] dump_backtrace+0x0/0x198
[ 11.294086] [<ffffff800808bc9c>] show_stack+0x24/0x30
[ 11.294089] [<ffffff8008454f54>] dump_stack+0x98/0xbc
[ 11.294090] ------------[ cut here ]------------
[ 11.294092] [<ffffff80080e75dc>] __schedule_bug+0x64/0x80
[ 11.294097] WARNING: CPU: 5 PID: 2222 at kernel/events/core.c:3437 perf_event_task_tick+0x2cc/0x320
[ 11.294099] [<ffffff8008f346e0>] __schedule+0x540/0x598
[ 11.294102] Modules linked in:
[ 11.294102] [<ffffff8008f34780>] schedule+0x48/0xe0
[ 11.294104] [<ffffff8008f35f8c>] rt_spin_lock_slowlock+0x22c/0x308
[ 11.294104]
[ 11.294106] [<ffffff8008f380d8>] rt_spin_lock+0x50/0x60
[ 11.294107] CPU: 5 PID: 2222 Comm: systemd-hiberna Tainted: G W 4.9.140-rt93 #112
[ 11.294109] [<ffffff8008b6e658>] cpufreq_acct_update_power+0xe0/0x280
[ 11.294110] Hardware name: quill (DT)
[ 11.294112] [<ffffff80080f2f20>] irqtime_account_process_tick.isra.1+0x1b0/0x238
[ 11.294112] task: ffffffc1ea29da00 task.stack: ffffffc1e2b68000
[ 11.294114] [<ffffff80080f3184>] account_process_tick+0xac/0xc8
[ 11.294115] PC is at perf_event_task_tick+0x2cc/0x320
[ 11.294116] [<ffffff800813cc58>] update_process_times+0x28/0x60
[ 11.294118] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 11.294119] LR is at scheduler_tick+0xb8/0x180
[ 11.294121] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 11.294122] pc : [<ffffff80081be39c>] lr : [<ffffff80080edc18>] pstate: 40400045
[ 11.294124] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 11.294124] sp : ffffffc1f70a4c80
[ 11.294126] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 11.294128] x29: ffffffc1f70a4c80
[ 11.294129] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 11.294131] x28: ffffffc1ea29da00 [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 11.294133] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 11.294135] x27: ffffff800814f780
[ 11.294135] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 11.294138] x26: 0000000000000000 [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 11.294140] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 11.294142] x25: 000000029adb6a00
[ 11.294143] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 11.294144] x24: ffffff8009814018 [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 11.294146] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 11.294149] x23: ffffffc1ea29da00
[ 11.294149] [<ffffff8008453450>] copy_page+0x40/0xb0
[ 11.294151] x22: ffffffc1f70a9f38 [<ffffff800820920c>] handle_mm_fault+0xa5c/0xc90
[ 11.294153] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 11.294156] x21: ffffff8009e4b468
[ 11.294156] [<ffffff80080a326c>] do_translation_fault+0x6c/0x80
[ 11.294157] x20: ffffff8009820000 [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 11.294159] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 11.294161] x19: ffffffc1f70ad9c0
[ 11.294161] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 11.294162] x18: 0000000000000000
x17: 0000000000000002 x16: 0000000000000000
[ 11.294166] x15: 0000000000000001 x14: 0000000000b1688c
[ 11.294174] x13: 00000000000007b9 x12: 0000000000000000
[ 11.294176] CPU: 1 PID: 2221 Comm: systemd-getty-g Tainted: G W 4.9.140-rt93 #112
[ 11.294179] x11: ffffff8008f499d0
[ 11.294180] Hardware name: quill (DT)
[ 11.294182] x10: 00000000000000a7
[ 11.294185] Call trace:
[ 11.294208] x8 : 00000000000007b9 [<ffffff800808b6d8>] dump_backtrace+0x0/0x198
[ 11.294211] ------------[ cut here ]------------
[ 11.294217] x7 : 0000000000000004
[ 11.294218] [<ffffff800808bc9c>] show_stack+0x24/0x30
[ 11.294222] WARNING: CPU: 0 PID: 2224 at kernel/events/core.c:3437 perf_event_task_tick+0x2cc/0x320
[ 11.294229] x6 : ffffffc1f70ad9f0 [<ffffff8008454f54>] dump_stack+0x98/0xbc
[ 11.294232] Modules linked in:
[ 11.294239] [<ffffff80080e75dc>] __schedule_bug+0x64/0x80
[ 11.294249] x5 : 00000000000007dc
[ 11.294250] [<ffffff8008f346e0>] __schedule+0x540/0x598
[ 11.294251]
[ 11.294261] x4 : 00000041ed88d000 [<ffffff8008f34780>] schedule+0x48/0xe0
[ 11.294264] CPU: 0 PID: 2224 Comm: systemd-system- Tainted: G W 4.9.140-rt93 #112
[ 11.294269] [<ffffff8008f35f8c>] rt_spin_lock_slowlock+0x22c/0x308
[ 11.294270] Hardware name: quill (DT)
[ 11.294276] x3 : 000000000000000f
[ 11.294277] [<ffffff8008f380d8>] rt_spin_lock+0x50/0x60
[ 11.294279] task: ffffffc1ea29ad00 task.stack: ffffffc1e2bb4000
[ 11.294285] x2 : 0000000000000040 [<ffffff8008b6e658>] cpufreq_acct_update_power+0xe0/0x280
[ 11.294288] PC is at perf_event_task_tick+0x2cc/0x320
[ 11.294294] x1 : ffffff800981cf38
[ 11.294295] [<ffffff80080f2b3c>] account_user_time+0xc4/0xd8
[ 11.294296] x0 : ffffff800981c000 LR is at scheduler_tick+0xb8/0x180
[ 11.294301] [<ffffff80080f2f6c>] irqtime_account_process_tick.isra.1+0x1fc/0x238
[ 11.294304] pc : [<ffffff80081be39c>] lr : [<ffffff80080edc18>] pstate: 40400045
[ 11.294304]
[ 11.294309] [<ffffff80080f3184>] account_process_tick+0xac/0xc8
[ 11.294311] sp : ffffffc1f7031c80
[ 11.294311] ---[ end trace 0000000000000002 ]---
[ 11.294316] [<ffffff800813cc58>] update_process_times+0x28/0x60
[ 11.294318] x29: ffffffc1f7031c80
[ 11.294319] Call trace:
[ 11.294325] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 11.294329] x28: ffffffc1ea29ad00 [<ffffff80081be39c>] perf_event_task_tick+0x2cc/0x320
[ 11.294334] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 11.294337] [<ffffff80080edc18>] scheduler_tick+0xb8/0x180
[ 11.294341] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 11.294345] x27: ffffff800814f780
[ 11.294345] [<ffffff800813cc5c>] update_process_times+0x2c/0x60
[ 11.294350] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 11.294353] x26: 0000000000000000 [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 11.294359] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 11.294362] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 11.294369] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 11.294372] x25: 000000029adb65c0
[ 11.294372] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 11.294377] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 11.294380] x24: ffffff8009814018 [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 11.294383] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 11.294385] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 11.294390] x23: ffffffc1ea29ad00
[ 11.294391] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 11.294393] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 11.294397] x22: ffffffc1f7036f38 [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 11.294400] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 11.294405] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 11.294407] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 11.294412] x21: ffffff8009e4b468
[ 11.294412] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 11.294415] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 11.294419] x20: ffffff8009820000 [<ffffff8008082df4>] el0_irq_naked+0x54/0x60
[ 11.294422] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 11.294424] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 11.294425] x19: ffffffc1f703a9c0
[ 11.294425] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 11.294427] x18: 0000000000000060 [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 11.294430] [<ffffff8008219548>] ptep_clear_flush+0x68/0x90
[ 11.294433] x17: 0000000000000002
[ 11.294433] [<ffffff8008203a78>] wp_page_copy+0x2c0/0x7d8
[ 11.294435] x16: 0000000000000000 [<ffffff8008204edc>] do_wp_page+0xc4/0x5d0
[ 11.294437] [<ffffff8008208fe0>] handle_mm_fault+0x830/0xc90
[ 11.294439] x15: 0000000000000000
[ 11.294439] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 11.294441] x14: 0000000000000000 [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 11.294443] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 11.294444] x13: 0000000000000009
[ 11.294444] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 11.294445] x12: 0000000000000000
x11: ffffff8008f499d0 x10: 0000000000000005
[ 11.294449] x9 : ffffff8008f499d8 x8 : 0000000000000009
[ 11.294450] x7 : 0000000000000004 x6 : ffffffc1f703a9f0
[ 11.294451] x5 : 000000000000040f x4 : 00000041ed81a000
[ 11.294453] x3 : 000000000000000f x2 : 0000000000000040
[ 11.294454] x1 : ffffff800981cf38 x0 : ffffff800981c000
[ 11.294454]
[ 11.294455] ---[ end trace 0000000000000003 ]---
[ 11.294456] Call trace:
[ 11.294458] [<ffffff80081be39c>] perf_event_task_tick+0x2cc/0x320
[ 11.294459] ------------[ cut here ]------------
[ 11.294461] [<ffffff80080edc18>] scheduler_tick+0xb8/0x180
[ 11.294462] kernel BUG at kernel/time/posix-cpu-timers.c:1301!
[ 11.294464] [<ffffff800813cc5c>] update_process_times+0x2c/0x60
[ 11.294465] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 11.294467] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 11.294469] Modules linked in:
[ 11.294470] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 11.294471] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 11.294473] CPU: 5 PID: 2222 Comm: systemd-hiberna Tainted: G W 4.9.140-rt93 #112
[ 11.294475] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 11.294475] Hardware name: quill (DT)
[ 11.294477] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 11.294478] task: ffffffc1ea29da00 task.stack: ffffffc1e2b68000
[ 11.294479] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 11.294481] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 11.294482] PC is at run_posix_cpu_timers+0xf0/0xf8
[ 11.294483] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 11.294484] LR is at update_process_times+0x50/0x60
[ 11.294485] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 11.294487] pc : [<ffffff8008143bf0>] lr : [<ffffff800813cc80>] pstate: 40400045
[ 11.294489] ------------[ cut here ]------------
[ 11.294491] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 11.294491] sp : ffffffc1f70a4d00
[ 11.294498] WARNING: CPU: 1 PID: 2221 at kernel/events/core.c:3437 perf_event_task_tick+0x2cc/0x320
[ 11.294500] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 11.294502] x29: ffffffc1f70a4d00
[ 11.294505] Modules linked in:
[ 11.294505] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 11.294507] x28: ffffffc1ea29da00 [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 11.294511]
[ 11.294514] [<ffffff8008453450>] copy_page+0x40/0xb0
[ 11.294518] x27: ffffff800814f780
[ 11.294519] CPU: 1 PID: 2221 Comm: systemd-getty-g Tainted: G W 4.9.140-rt93 #112
[ 11.294521] [<ffffff800820920c>] handle_mm_fault+0xa5c/0xc90
[ 11.294523] x26: 0000000000000000 [ 11.294524] Hardware name: quill (DT)
[ 11.294526] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 11.294529] task: ffffffc1e4540000 task.stack: ffffffc1e2b40000
[ 11.294532] [<ffffff80080a326c>] do_translation_fault+0x6c/0x80
[ 11.294535] x25: 000000029adb6a00
[ 11.294536] PC is at perf_event_task_tick+0x2cc/0x320
[ 11.294538] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 11.294540] x24: ffffff8009814018 [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 11.294542] LR is at scheduler_tick+0xb8/0x180
[ 11.294544] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 11.294549] x23: ffffff8009e49688
[ 11.294550] pc : [<ffffff80081be39c>] lr : [<ffffff80080edc18>] pstate: 40400045
[ 11.294553] x22: ffffffc1f70a8680 sp : ffffffc1f7048c80
[ 11.294558] x21: ffffffc1f70a8c70
[ 11.294560] x29: ffffffc1f7048c80
[ 11.294563] x20: 0000000000000000 x28: ffffffc1e4540000 x19: ffffffc1ea29da00
[ 11.294573] x27: ffffff800814f780
[ 11.294574] x18: 0000000000000f28 [ 11.294574] ------------[ cut here ]------------
[ 11.294579] x26: 0000000000000000 [ 11.294580] kernel BUG at kernel/time/posix-cpu-timers.c:1301!
[ 11.294585] x17: 0000000000000005
[ 11.294587] x25: 000000029adb7660
[ 11.294590] x16: 0000000000000000 x24: ffffff8009814018 x15: 000000000000009d x14: 0000000000002b3b
[ 11.294603] x23: ffffffc1e4540000
[ 11.294606] x22: ffffffc1f704df38 x13: 0000000000011892
[ 11.294614] x12: 0000000000000400 x21: ffffff8009e4b468
[ 11.294619] x20: ffffff8009820000 x11: 0000000000000400
[ 11.294627] x10: 0000000000000000 x19: ffffffc1f70519c0
[ 11.294634] x18: 0000000000000060 x9 : 000000000196eca1
[ 11.294640] x8 : 00000000000002f0 x17: 0000000000000000
[ 11.294645] x16: ffffffc1e4540000 x7 : 0000000000001490
[ 11.294650] x6 : ffffffc1ea298fd0 x15: 0000000000000000
[ 11.294657] x14: 0000000000000f28 x5 : ffffff8008f49910
[ 11.294662] x4 : 0000000000000005 x13: 0000000000000405
[ 11.294667] x12: 0000000000000000 x3 : 0000000000000004
[ 11.294672] x2 : 0000000000000000 x11: ffffff8008f499d0
[ 11.294679] x10: 0000000000000004 x1 : 00000041ed88d000
[ 11.294684] x0 : 0000000000000040 x9 : ffffff8008f499d8
[ 11.294688] x8 : 0000000000000405
[ 11.294693] Process systemd-hiberna (pid: 2222, stack limit = 0xffffffc1e2b68000)
[ 11.294696] x7 : 0000000000000004
[ 11.294696] Call trace:
[ 11.294704] x6 : ffffffc1f70519f0 [<ffffff8008143bf0>] run_posix_cpu_timers+0xf0/0xf8
[ 11.294707] [<ffffff800813cc80>] update_process_times+0x50/0x60
[ 11.294712] x5 : 000000000000040a
[ 11.294712] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 11.294718] x4 : 00000041ed831000 [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 11.294721] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 11.294725] x3 : 000000000000000f
[ 11.294725] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 11.294730] x2 : 0000000000000040 [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 11.294733] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 11.294738] x1 : ffffff800981cf38
[ 11.294738] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 11.294743] x0 : ffffff800981c000 [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 11.294747] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 11.294749]
[ 11.294750] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 11.294753] ---[ end trace 0000000000000004 ]---
[ 11.294755] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 11.294757] Call trace:
[ 11.294759] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 11.294760] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 11.294764] [<ffffff80081be39c>] perf_event_task_tick+0x2cc/0x320
[ 11.294768] [<ffffff8008219548>] ptep_clear_flush+0x68/0x90
[ 11.294772] [<ffffff80080edc18>] scheduler_tick+0xb8/0x180
[ 11.294776] [<ffffff8008203a78>] wp_page_copy+0x2c0/0x7d8
[ 11.294781] [<ffffff800813cc5c>] update_process_times+0x2c/0x60
[ 11.294784] [<ffffff8008204edc>] do_wp_page+0xc4/0x5d0
[ 11.294788] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 11.294790] [<ffffff8008208fe0>] handle_mm_fault+0x830/0xc90
[ 11.294794] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 11.294797] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 11.294801] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 11.294803] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 11.294807] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 11.294809] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 11.294813] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 11.294815] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 11.294819] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 11.294828] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 11.294831] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 11.294836] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 11.294840] [<ffffff8008092b74>] handle_IPI+0x1b4/0x308
[ 11.294842] [<ffffff8008080d90>] gic_handle_irq+0xa8/0xb0
[ 11.294845] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 11.294884] ------------[ cut here ]------------
[ 11.294886] kernel BUG at kernel/time/posix-cpu-timers.c:1301!
[ 13.405880] ---[ end trace 0000000000000005 ]---
[ 13.405881] Internal error: Oops - BUG: 0 [#2] PREEMPT SMP
[ 13.405883] Modules linked in:
[ 13.406926] CPU: 0 PID: 2224 Comm: systemd-system- Tainted: G D W 4.9.140-rt93 #112
[ 13.406927] Hardware name: quill (DT)
[ 13.406928] task: ffffffc1ea29ad00 task.stack: ffffffc1e2bb4000
[ 13.406932] PC is at run_posix_cpu_timers+0xf0/0xf8
[ 13.406935] LR is at update_process_times+0x50/0x60
[ 13.406936] pc : [<ffffff8008143bf0>] lr : [<ffffff800813cc80>] pstate: 40400045
[ 13.406936] sp : ffffffc1f7031d00
[ 13.406938] x29: ffffffc1f7031d00 x28: ffffffc1ea29ad00
[ 13.406940] x27: ffffff800814f780 x26: 0000000000000000
[ 13.406941] x25: 000000029adb65c0 x24: ffffff8009814018
[ 13.406943] x23: ffffff8009e49688 x22: ffffffc1f7035680
[ 13.406944] x21: ffffffc1f7035c70 x20: 0000000000000000
[ 13.406945] x19: ffffffc1ea29ad00 x18: 0000000000000f28
[ 13.406947] x17: 0000000000000003 x16: 0000000000000000
[ 13.406948] x15: 0000000000000141 x14: 0000000000008123
[ 13.406949] x13: 000000000000d7ff x12: 0000000000000400
[ 13.406951] x11: 0000000000000400 x10: 0000000000000000
[ 13.406952] x9 : 000000000220975f x8 : 00000000000002f0
[ 13.406953] x7 : 0000000000001490 x6 : 00000000021bbe95
[ 13.406954] x5 : ffffff8008f49910 x4 : 0000000000000000
[ 13.406956] x3 : 0000000000000002 x2 : 0000000000000000
[ 13.406957] x1 : 00000041ed81a000 x0 : 0000000000000040
[ 13.406957]
[ 13.406959] Process systemd-system- (pid: 2224, stack limit = 0xffffffc1e2bb4000)
[ 13.406959] Call trace:
[ 13.406962] [<ffffff8008143bf0>] run_posix_cpu_timers+0xf0/0xf8
[ 13.406963] [<ffffff800813cc80>] update_process_times+0x50/0x60
[ 13.406966] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 13.406968] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 13.406970] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 13.406971] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 13.406973] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 13.406975] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 13.406977] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 13.406978] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 13.406981] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 13.406982] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 13.406983] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 13.406985] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 13.406987] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 13.406990] [<ffffff8008453450>] copy_page+0x40/0xb0
[ 13.406991] [<ffffff800820920c>] handle_mm_fault+0xa5c/0xc90
[ 13.406993] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 13.406994] [<ffffff80080a326c>] do_translation_fault+0x6c/0x80
[ 13.406995] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 13.406997] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 13.406998] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 13.411326] ------------[ cut here ]------------
[ 13.411327] kernel BUG at kernel/locking/rtmutex.c:1070!
[ 13.746604] ---[ end trace 0000000000000006 ]---
[ 13.747703] Internal error: Oops - BUG: 0 [#3] PREEMPT SMP
[ 13.747708] Modules linked in:
[ 13.747714] CPU: 1 PID: 2221 Comm: systemd-getty-g Tainted: G D W 4.9.140-rt93 #112
[ 13.747716] Hardware name: quill (DT)
[ 13.747718] task: ffffffc1e4540000 task.stack: ffffffc1e2b40000
[ 13.747725] PC is at run_posix_cpu_timers+0xf0/0xf8
[ 13.747727] LR is at update_process_times+0x50/0x60
[ 13.747730] pc : [<ffffff8008143bf0>] lr : [<ffffff800813cc80>] pstate: 40400045
[ 13.747731] sp : ffffffc1f7048d00
[ 13.747735] x29: ffffffc1f7048d00 x28: ffffffc1e4540000
[ 13.747738] x27: ffffff800814f780 x26: 0000000000000000
[ 13.747742] x25: 000000029adb7660 x24: ffffff8009814018
[ 13.747745] x23: ffffff8009e49688 x22: ffffffc1f704c680
[ 13.747748] x21: ffffffc1f704cc70 x20: 0000000000000001
[ 13.747751] x19: ffffffc1e4540000 x18: 0000000000000f28
[ 13.747754] x17: 0000000000000001 x16: 0000000000000000
[ 13.747757] x15: 0000000000000000 x14: 00000000000073ec
[ 13.747760] x13: 000000000000d351 x12: 0000000000000400
[ 13.747764] x11: 0000000000000001 x10: 0000000000000b20
[ 13.747767] x9 : ffffffc1f7048b90 x8 : ffffffc1e4540b80
[ 13.747770] x7 : 0000000000000000 x6 : 0000000000000400
[ 13.747773] x5 : 0000000000000400 x4 : 0000000000000001
[ 13.747775] x3 : 0000000000000000 x2 : 0000000000000000
[ 13.747778] x1 : 00000041ed831000 x0 : 0000000000000040
[ 13.747779]
[ 13.747782] Process systemd-getty-g (pid: 2221, stack limit = 0xffffffc1e2b40000)
[ 13.747783] Call trace:
[ 13.747788] [<ffffff8008143bf0>] run_posix_cpu_timers+0xf0/0xf8
[ 13.747791] [<ffffff800813cc80>] update_process_times+0x50/0x60
[ 13.747795] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 13.747798] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 13.747802] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 13.747805] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 13.747809] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 13.747812] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 13.747815] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 13.747818] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 13.747822] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 13.747826] [<ffffff8008092b74>] handle_IPI+0x1b4/0x308
[ 13.747829] [<ffffff8008080d90>] gic_handle_irq+0xa8/0xb0
[ 13.747831] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 14.008098] Internal error: Oops - BUG: 0 [#4] PREEMPT SMP
[ 14.008102] ---[ end trace 0000000000000007 ]---
[ 14.008105] Modules linked in:
[ 14.008108] CPU: 5 PID: 2222 Comm: systemd-hiberna Tainted: G D W 4.9.140-rt93 #112
[ 14.008111] Hardware name: quill (DT)
[ 14.008112] task: ffffffc1ea29da00 task.stack: ffffffc1e2b68000
[ 14.008116] PC is at rt_spin_lock_slowlock+0x2dc/0x308
[ 14.008117] LR is at rt_spin_lock_slowlock+0x68/0x308
[ 14.008119] pc : [<ffffff8008f3603c>] lr : [<ffffff8008f35dc8>] pstate: 604003c5
[ 14.010038] sp : ffffffc1f70a46a0
[ 14.010041] x29: ffffffc1f70a46a0 x28: 0000007f89b13000
[ 14.010043] x27: ffffffc1e29c9268 x26: ffffffc1e1027898
[ 14.010044] x25: 00000000000003c0 x24: 0400000000000001
[ 14.010046] x23: 0000000000000001 x22: 0000000000000000
[ 14.010047] x21: ffffffc1f70a4700 x20: ffffffc1ea29da00
[ 14.010048] x19: ffffffc1e44362a0 x18: 0000000000000000
[ 14.010050] x17: 0000000000000000 x16: ffffffc1ea29da00
[ 14.010051] x15: ffffffffffffffff x14: ffffffc1eb3eeb19
[ 14.010052] x13: ffffffc1eb3eeb15 x12: 0000000000000000
[ 14.010054] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 14.010055] x9 : fefefefefeff2fff x8 : 7f7f7f7f7f7f7f7f
[ 14.010056] x7 : 09422c3337303330 x6 : 0000007fc9b13000
[ 14.010058] x5 : 0000000000000000 x4 : 0000000080000000
[ 14.010059] x3 : ffffffc1e44362b8 x2 : ffffffc1ea29da01
[ 14.010060] x1 : ffffffc1ea29da00 x0 : ffffffc1ea29da00
[ 14.010061]
[ 14.010062] Process systemd-hiberna (pid: 2222, stack limit = 0xffffffc1e2b68000)
[ 14.010063] Call trace:
[ 14.010065] [<ffffff8008f3603c>] rt_spin_lock_slowlock+0x2dc/0x308
[ 14.010068] [<ffffff8008f380d8>] rt_spin_lock+0x50/0x60
[ 14.010071] [<ffffff80082048a8>] zap_pte_range+0xa8/0x618
[ 14.010073] [<ffffff80082054e8>] unmap_page_range+0x100/0x1f8
[ 14.010075] [<ffffff8008205654>] unmap_single_vma+0x74/0xc8
[ 14.010077] [<ffffff80082059b0>] unmap_vmas+0x70/0xe0
[ 14.010079] [<ffffff800820ea48>] exit_mmap+0x98/0x118
[ 14.010082] [<ffffff80080affac>] mmput+0x54/0x110
[ 14.010085] [<ffffff80080b96bc>] do_exit+0x26c/0xa18
[ 14.010088] [<ffffff800808be88>] bug_handler.part.2+0x0/0x88
[ 14.010090] [<ffffff800808bed0>] bug_handler.part.2+0x48/0x88
[ 14.010092] [<ffffff800808bf4c>] bug_handler+0x3c/0x48
[ 14.010093] [<ffffff80080841d4>] brk_handler+0x7c/0xd0
[ 14.010095] [<ffffff8008080c4c>] do_debug_exception+0x84/0x120
[ 14.010096] [<ffffff8008082254>] el1_dbg+0x18/0xa4
[ 14.010099] [<ffffff800813cc80>] update_process_times+0x50/0x60
[ 14.010101] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 14.010103] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 14.010105] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 14.010106] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 14.010109] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 14.010111] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 14.010113] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 14.010114] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 14.010116] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 14.010118] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 14.010119] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 14.010120] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 14.010122] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 14.010125] [<ffffff8008219548>] ptep_clear_flush+0x68/0x90
[ 14.010127] [<ffffff8008203a78>] wp_page_copy+0x2c0/0x7d8
[ 14.010129] [<ffffff8008204edc>] do_wp_page+0xc4/0x5d0
[ 14.010130] [<ffffff8008208fe0>] handle_mm_fault+0x830/0xc90
[ 14.010132] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 14.010133] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 14.010135] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 14.010136] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 14.430216] ---[ end trace 0000000000000008 ]---
[ 14.436316] Fixing recursive fault but reboot is needed!
[ 14.436318] BUG: scheduling while atomic: systemd-hiberna/2222/0x00000002
[ 14.436319] Modules linked in:
[ 14.436321] CPU: 5 PID: 2222 Comm: systemd-hiberna Tainted: G D W 4.9.140-rt93 #112
[ 14.436322] Hardware name: quill (DT)
[ 14.436323] Call trace:
[ 14.436327] [<ffffff800808b6d8>] dump_backtrace+0x0/0x198
[ 14.436330] [<ffffff800808bc9c>] show_stack+0x24/0x30
[ 14.436334] [<ffffff8008454f54>] dump_stack+0x98/0xbc
[ 14.436337] [<ffffff80080e75dc>] __schedule_bug+0x64/0x80
[ 14.436341] [<ffffff8008f346e0>] __schedule+0x540/0x598
[ 14.436343] [<ffffff8008f34780>] schedule+0x48/0xe0
[ 14.436345] [<ffffff80080b9c8c>] do_exit+0x83c/0xa18
[ 14.436347] [<ffffff800808be88>] bug_handler.part.2+0x0/0x88
[ 14.436349] [<ffffff800808bed0>] bug_handler.part.2+0x48/0x88
[ 14.436351] [<ffffff800808bf4c>] bug_handler+0x3c/0x48
[ 14.436352] [<ffffff80080841d4>] brk_handler+0x7c/0xd0
[ 14.436354] [<ffffff8008080c4c>] do_debug_exception+0x84/0x120
[ 14.436355] [<ffffff8008082254>] el1_dbg+0x18/0xa4
[ 14.436356] [<ffffff8008f380d8>] rt_spin_lock+0x50/0x60
[ 14.436359] [<ffffff80082048a8>] zap_pte_range+0xa8/0x618
[ 14.436361] [<ffffff80082054e8>] unmap_page_range+0x100/0x1f8
[ 14.436363] [<ffffff8008205654>] unmap_single_vma+0x74/0xc8
[ 14.436364] [<ffffff80082059b0>] unmap_vmas+0x70/0xe0
[ 14.436366] [<ffffff800820ea48>] exit_mmap+0x98/0x118
[ 14.436367] [<ffffff80080affac>] mmput+0x54/0x110
[ 14.436369] [<ffffff80080b96bc>] do_exit+0x26c/0xa18
[ 14.436371] [<ffffff800808be88>] bug_handler.part.2+0x0/0x88
[ 14.436373] [<ffffff800808bed0>] bug_handler.part.2+0x48/0x88
[ 14.436374] [<ffffff800808bf4c>] bug_handler+0x3c/0x48
[ 14.436376] [<ffffff80080841d4>] brk_handler+0x7c/0xd0
[ 14.436377] [<ffffff8008080c4c>] do_debug_exception+0x84/0x120
[ 14.436378] [<ffffff8008082254>] el1_dbg+0x18/0xa4
[ 14.436380] [<ffffff800813cc80>] update_process_times+0x50/0x60
[ 14.436382] [<ffffff800814f748>] tick_sched_handle.isra.5+0x38/0x70
[ 14.436383] [<ffffff800814f7cc>] tick_sched_timer+0x4c/0x90
[ 14.436385] [<ffffff800813da48>] __hrtimer_run_queues+0x100/0x440
[ 14.436387] [<ffffff800813ead4>] hrtimer_interrupt+0xa4/0x268
[ 14.436389] [<ffffff8008bd2754>] tegra186_timer_isr+0x34/0x48
[ 14.436391] [<ffffff8008125b40>] __handle_irq_event_percpu+0x68/0x2a8
[ 14.436392] [<ffffff8008125dc8>] handle_irq_event_percpu+0x48/0x80
[ 14.436394] [<ffffff8008125e78>] handle_irq_event+0x78/0xc0
[ 14.436396] [<ffffff8008129dd8>] handle_fasteoi_irq+0xc0/0x230
[ 14.436397] [<ffffff8008124b1c>] generic_handle_irq+0x34/0x50
[ 14.436398] [<ffffff8008125208>] __handle_domain_irq+0x68/0xc0
[ 14.436400] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 14.436401] [<ffffff80080823e8>] el1_irq+0xe8/0x198
[ 14.436403] [<ffffff8008219548>] ptep_clear_flush+0x68/0x90
[ 14.436405] [<ffffff8008203a78>] wp_page_copy+0x2c0/0x7d8
[ 14.436407] [<ffffff8008204edc>] do_wp_page+0xc4/0x5d0
[ 14.436408] [<ffffff8008208fe0>] handle_mm_fault+0x830/0xc90
[ 14.436410] [<ffffff80080a2ff0>] do_page_fault+0x338/0x548
[ 14.436411] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[ 14.436412] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[ 14.436414] [<ffffff8008082bc8>] el0_da+0x20/0x24
[ 17.626608] random: crng init done
sumitg
#3
Please try after doing below change in rt-patch.sh.
./config --file ../arch/arm64/configs/tegra_defconfig\
--enable PREEMPT_RT_FULL\
--disable CPU_IDLE_TEGRA18X\
--disable CPU_IDLE_TEGRA19X\
--disable CPU_FREQ_GOV_SCHEDUTIL\
--enable PREEMPT_RT_FULL \
--disable DEBUG_PREEMPT \
--disable CPU_IDLE_TEGRA18X \
--disable CPU_FREQ_TIMES \
--disable CPU_FREQ_GOV_SCHEDUTIL \
--disable CPU_FREQ_GOV_INTERACTIVE || any_failure=1
suchb
#4
Thanks sumitg,
it works.
Linux nvidia 4.9.140-rt93 #111 SMP PREEMPT RT Thu Nov 14 16:18:13 CST 2019 aarch64 aarch64 aarch64 GNU/Linux
