Please find the kernel log below. Note after the system booted, it locked up without any messages printed on the console. This was using a non-4k monitor.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (rongs@u480fcf3621cb5876808e) (gcc version 4.8.5 (GCC) ) #26 SMP PREEMPT Thu Sep 7 22:19:52 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5d69000 s31232 r8192 d30208 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2018947
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reser"
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7971700K/8204288K available (10880K kernel code, 1815K rwdata, 6976K rodata, 1160K init, 679K bss, 167052K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
[ 0.000000] .init : 0xffffffc0011f1000 - 0xffffffc001313000 ( 1160 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0011f1000 ( 17860 KB)
[ 0.000000] .data : 0xffffffc001334000 - 0xffffffc0014f9f98 ( 1816 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009464] Console: colour dummy device 80x25
[ 0.014120] console [tty0] enabled
[ 0.017676] bootconsole [uart0] disabled
[ 0.021779] kmemleak: Kernel memory leak detector disabled
[ 0.021790] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.021802] pid_max: default: 32768 minimum: 301
[ 0.021843] Security Framework initialized
[ 0.021871] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.021880] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022234] Initializing cgroup subsys freezer
[ 0.022245] Initializing cgroup subsys debug
[ 0.022383] CPU0 ipc=752
[ 0.022391] CPU1 ipc=1024
[ 0.022399] CPU2 ipc=1024
[ 0.022407] CPU3 ipc=752
[ 0.022415] CPU4 ipc=752
[ 0.022424] CPU5 ipc=752
[ 0.022461] ASID allocator initialised with 65536 entries
[ 0.046894] tegra-id: chipid=21817.
[ 0.046906] tegra-id: opt_subrevision=1.
[ 0.046914] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.047342] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/jetson-tx2.dts
[ 0.047356] DTB Build time: Sep 11 2017 14:34:29
[ 0.062419] CPU1: Booted secondary processor [4e0f0030]
[ 0.073939] CPU2: Booted secondary processor [4e0f0030]
[ 0.085634] CPU3: Booted secondary processor [411fd073]
[ 0.097642] CPU4: Booted secondary processor [411fd073]
[ 0.109628] CPU5: Booted secondary processor [411fd073]
[ 0.109689] Brought up 6 CPUs
[ 0.109736] SMP: Total of 6 processors activated.
[ 0.109747] CPU: All CPU(s) started at EL2
[ 0.110163] devtmpfs: initialized
[ 0.128582] Initilizing CustomIPI irq domain
[ 0.128767] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.129644] pinctrl core: initialized pinctrl subsystem
[ 0.129795] OS set in device tree is L4T.
[ 0.129995] regulator-dummy: no parameters
[ 0.130099] Initializing plugin-manager
[ 0.130150] Plugin module not found
[ 0.130552] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.130860] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.131445] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.132562] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.132892] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.133138] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.133375] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.133781] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.134203] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.134472] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.134840] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.135076] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.135290] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.135532] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.137399] Adding domain adsp-pd to PM domain ape-pd
[ 0.138991] NET: Registered protocol family 16
[ 0.139632] console [pstore-1] enabled
[ 0.139643] pstore: Registered ramoops as persistent store backend
[ 0.139656] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[ 0.149180] cpuidle: using governor ladder
[ 0.153635] cpuidle: using governor menu
[ 0.154470] bpmp: waiting for handshake
[ 0.154483] bpmp: handshake completed
[ 0.154522] bpmp: synchronizing channels
[ 0.154549] bpmp: channels synchronized
[ 0.154559] bpmp: mail init ok
[ 0.154881] vdso: 2 pages (1 code @ ffffffc001339000, 1 data @ ffffffc001338000)
[ 0.154914] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.155865] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.157317] tegra_powergate_init: DONE
[ 0.157337] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/jetson-tx2.dts
[ 0.157357] DTB Build time: Sep 11 2017 14:34:29
[ 0.158185] Tegra reboot handler registered.
[ 0.158797] Registering Tegra186 clocks (this may take a while)...done
[ 0.160150] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.160165] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.160177] arm-smmu 12000000.iommu: stage 1 translation
[ 0.160189] arm-smmu 12000000.iommu: stage 2 translation
[ 0.160200] arm-smmu 12000000.iommu: nested translation
[ 0.160214] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.160232] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.160250] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.160263] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.160275] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.198192] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.200313] iommu: Adding device 3460000.sdhci to group 0
[ 0.200734] iommu: Adding device 3400000.sdhci to group 1
[ 0.202212] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.202460] iommu: Adding device 3160000.i2c to group 3
[ 0.202696] iommu: Adding device c240000.i2c to group 4
[ 0.202904] iommu: Adding device 3180000.i2c to group 5
[ 0.203122] iommu: Adding device 3190000.i2c to group 6
[ 0.203390] iommu: Adding device 31b0000.i2c to group 7
[ 0.203591] iommu: Adding device 31c0000.i2c to group 8
[ 0.203801] iommu: Adding device c250000.i2c to group 9
[ 0.203998] iommu: Adding device 31e0000.i2c to group 10
[ 0.205119] iommu: Adding device 3210000.spi to group 11
[ 0.205325] iommu: Adding device c260000.spi to group 12
[ 0.205541] iommu: Adding device 3240000.spi to group 13
[ 0.206036] iommu: Adding device 3100000.serial to group 14
[ 0.206243] iommu: Adding device 3110000.serial to group 15
[ 0.206443] iommu: Adding device c280000.serial to group 16
[ 0.206642] iommu: Adding device 3130000.serial to group 17
[ 0.207554] iommu: Adding device 2490000.ether_qos to group 18
[ 0.207930] iommu: Adding device b000000.rtcpu to group 19
[ 0.208229] iommu: Adding device c1a0000.aon to group 20
[ 0.208833] Wake73 for irq=42
[ 0.209023] iommu: Adding device smmu_test to group 21
[ 0.209378] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.209400] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.209419] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.209438] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.209459] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.209477] mc-err: Set intmask: 0xf3140
[ 0.209622] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.210212] Wake76 for irq=199
[ 0.210223] Wake77 for irq=199
[ 0.210233] Wake78 for irq=199
[ 0.210241] Wake79 for irq=199
[ 0.210250] Wake80 for irq=199
[ 0.210258] Wake81 for irq=199
[ 0.210266] Wake82 for irq=199
[ 0.210335] iommu: Adding device 3530000.xhci to group 22
[ 0.210581] iommu: Adding device 3550000.xudc to group 23
[ 0.211083] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.211097] tegra-pmc: ### PMC reset source: Power on reset
[ 0.211108] tegra-pmc: ### PMC reset level: L0
[ 0.211118] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.211248] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.211267] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.211366] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.211381] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.211694] iommu: Adding device 13e10000.host1x to group 24
[ 0.211850] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.212003] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.212158] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.212303] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.212455] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.212598] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.212746] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.212906] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.213183] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.213559] iommu: Adding device 15700000.vi to group 34
[ 0.213790] iommu: Adding device 15600000.isp to group 35
[ 0.214011] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.214151] iommu: Adding device 15340000.vic to group 37
[ 0.214275] iommu: Adding device 154c0000.nvenc to group 38
[ 0.214398] iommu: Adding device 15480000.nvdec to group 39
[ 0.215233] iommu: Adding device 15380000.nvjpg to group 40
[ 0.215651] iommu: Adding device 15500000.tsec to group 41
[ 0.215970] iommu: Adding device 15100000.tsecb to group 42
[ 0.217142] iommu: Adding device 15810000.se to group 43
[ 0.217435] iommu: Adding device 15820000.se to group 44
[ 0.217698] iommu: Adding device 15830000.se to group 45
[ 0.217960] iommu: Adding device 15840000.se to group 46
[ 0.218700] iommu: Adding device 17000000.gp10b to group 47
[ 0.220999] tegra-reset 5000000.clock: registered 193 resets.
[ 0.223048] iommu: Adding device d000000.bpmp to group 48
[ 0.223289] bpmp: ping status is 0
[ 0.223433] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[ 0.223811] bpmp d000000.bpmp: probe ok
[ 0.225994] iommu: Adding device 2600000.dma to group 49
[ 0.226943] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.226993] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.227059] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.227108] GPIO line 457 (gpio-input) hogged as input
[ 0.227207] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.229036] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.229163] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.230026] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.230259] iommu: Adding device sound to group 51
[ 0.231947] iommu: Adding device 3510000.hda to group 52
[ 0.232950] iommu: Adding device adsp_audio to group 53
[ 0.234213] iommu: Adding device 2993000.adsp to group 54
[ 0.243674] vdd-ac-bat: 5000 mV
[ 0.246015] vdd-1v8-ap: 1800 mV
[ 0.247456] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.247940] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.264607] SCSI subsystem initialized
[ 0.264980] usbcore: registered new interface driver usbfs
[ 0.265037] usbcore: registered new interface driver hub
[ 0.265135] usbcore: registered new device driver usb
[ 0.269083] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.269485] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.269593] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.270942] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.271065] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.283892] media: Linux media interface: v0.10
[ 0.283983] Linux video capture interface: v2.00
[ 0.287977] pps_core: LinuxPPS API ver. 1 registered
[ 0.288008] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.288063] PTP clock support registered
[ 0.289099] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.289149] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.290991] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.293095] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.293299] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.293411] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.298596] vddio-ddr: at 1125 mV
[ 0.302433] avdd_dsi_csi: 1200 mV
[ 0.306436] vdd-1v8: 1800 mV
[ 0.310434] vdd-3v3-sys: 3300 mV
[ 0.311557] spmic-ldo0: at 1800 mV
[ 0.312382] spmic-ldo1: at 800 mV
[ 0.318432] vddio-3v3: 3300 mV
[ 0.319061] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.321178] vdd-rtc: at 800 mV
[ 0.321862] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.325176] spmic-ldo6: at 1500 mV
[ 0.329175] vdd-pex-1v05: 1000 mV
[ 0.329735] dvdd-pex: 1000 mV
[ 0.329998] max77620 4-003c: max77620 probe successful
[ 0.330253] Advanced Linux Sound Architecture Driver Initialized.
[ 0.331227] en-vdd-sd: 3300 mV
[ 0.331802] en-vdd-cam: 1800 mV
[ 0.333632] vdd-hdmi: 5000 mV
[ 0.333803] vdd-usb0-5v: 5000 mV
[ 0.333968] vdd-usb1-5v: 5000 mV
[ 0.337631] en-vdd-ts-1v8: 1800 mV
[ 0.341632] en-vdd-ts-hv-3v3: 3300 mV
[ 0.342119] en-vdd-disp-3v3: 3300 mV
[ 0.342603] en-mdm-pwr-3v7: 3700 mV
[ 0.343089] en-vdd-disp-1v8: 1800 mV
[ 0.343576] en-vdd-cam-hv-2v8: 2800 mV
[ 0.344071] en-vdd-cam-1v2: 1200 mV
[ 0.344572] vdd-fan: 5000 mV
[ 0.344681] vdd-3v3: 3300 mV
[ 0.345370] dis-vdd-1v2: 1200 mV
[ 0.345478] en-vdd-vcm-2v8: 2800 mV
[ 0.345984] vdd-usb2-5v: 5000 mV
[ 0.346092] vdd-sys-bl: 3300 mV
[ 0.346785] en-vdd-sys: 1200 mV
[ 0.348307] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.349989] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.350371] clocksource: Switched to clocksource arch_sys_counter
[ 0.369521] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.369803] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.370253] nvmap_page_pool_init: Total RAM pages: 2009309
[ 0.370269] nvmap_page_pool_init: nvmap page pool size: 251163 pages (981 MB)
[ 0.370449] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.374822] Wake76 for irq=199
[ 0.374835] Wake77 for irq=199
[ 0.374844] Wake78 for irq=199
[ 0.374854] Wake79 for irq=199
[ 0.374862] Wake80 for irq=199
[ 0.374870] Wake81 for irq=199
[ 0.374878] Wake82 for irq=199
[ 0.375604] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.375793] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.375909] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.375985] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.376333] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.376475] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.376620] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.376760] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.377052] isomgr_init(): iso emc max clk=1866000KHz
[ 0.377063] isomgr_init(): max_iso_bw=26870400KB
[ 0.377139] NET: Registered protocol family 2
[ 0.377431] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.377636] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.377927] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.377982] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.378033] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.378190] NET: Registered protocol family 1
[ 0.378424] RPC: Registered named UNIX socket transport module.
[ 0.378438] RPC: Registered udp transport module.
[ 0.378449] RPC: Registered tcp transport module.
[ 0.378459] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.378572] Trying to unpack rootfs image as initramfs...
[ 0.391848] host1x 13e10000.host1x: initialized
[ 0.392597] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.394688] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.394786] audit: initializing netlink subsys (disabled)
[ 0.394815] audit: type=2000 audit(0.384:1): initialized
[ 0.401219] io scheduler noop registered (default)
[ 0.404089] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.405237] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.406258] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.407279] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.410086] tsec 15500000.tsec: initialized
[ 0.411171] tsec 15100000.tsecb: initialized
[ 0.412871] nvdec 15480000.nvdec: initialized
[ 0.415686] falcon 15340000.vic: initialized
[ 0.416662] falcon 154c0000.nvenc: initialized
[ 0.417635] falcon 15380000.nvjpg: initialized
[ 0.418321] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.418835] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.419336] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.419836] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.420339] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.420855] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.421369] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.421892] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.423028] DC OR NODE connected to /host1x/sor1
[ 0.423221] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.423238] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.423279] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.423407] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 0.423429] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=1500000, max_bw=1500000
[ 0.430397] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.430416] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.430433] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.430476] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.430490] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.430740] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.432541] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.432655] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.432674] PD DISP0 index2 UP
[ 0.433539] PD DISP1 index3 UP
[ 0.433721] PD DISP2 index4 UP
[ 0.433736] kfuse 3830000.kfuse: initialized
[ 0.434953] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.435475] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.436468] tegra-i2c 3180000.i2c: no acknowledge from address 0x2c
[ 0.436917] max310x: probe of 2-002c failed with error -121
[ 0.438208] console [ttyS0] disabled
[ 0.438249] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.485512] Unsupported HDMI VIC 64, ignoring
[ 0.485523] PD DISP2 index4 DOWN
[ 0.485678] PD DISP1 index3 DOWN
[ 0.485824] PD DISP0 index2 DOWN
[ 0.487593] tegradc 15210000.nvdisplay: probed
[ 2.510788] console [ttyS0] enabled
[ 2.512928] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.513985] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.514216] serial-tegra 3130000.serial: RX in PIO mode
[ 2.515086] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.525062] Console: switching to colour frame buffer device 240x67
[ 2.525881] brd: module loaded
[ 2.530977] loop: module loaded
[ 2.531182] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.531199] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.531203] nct1008_nct72 7-004c: starting parse dt
[ 2.531284] nct1008_nct72 7-004c: success parsing dt
[ 2.531395] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.543080] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.567855] tmp451: Enabled overheat logging at 104.00C
[ 2.567993] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.568037] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.570322] THERMAL EST: found 3 subdevs
[ 2.570334] THERMAL EST num_resources: 0
[ 2.570345] [THERMAL EST subdev 0]
[ 2.570384] [THERMAL EST subdev 1]
[ 2.570396] [THERMAL EST subdev 2]
[ 2.570707] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.570714] THERMAL EST: thz register success.
[ 2.570842] THERMAL EST: end of probe, return err: 0
[ 2.571052] tegra_profiler: Branch: Dev
[ 2.571062] tegra_profiler: Version: 1.109
[ 2.571070] tegra_profiler: Samples version: 37
[ 2.571078] tegra_profiler: IO version: 21
[ 2.571092] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571102] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.571112] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.571123] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.571146] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.571150] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.571153] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571184] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.571188] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571192] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.571195] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.571198] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.571397] tegra_profiler: auth: init
[ 2.574867] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.574878] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.575939] scsi host0: tegra_ahci
[ 2.576316] scsi host1: tegra_ahci
[ 2.576493] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.576496] ata2: DUMMY
[ 2.577401] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.577872] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.578305] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.579188] tun: Universal TUN/TAP device driver, 1.6
[ 2.579191] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.579359] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.579361] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.579400] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.579402] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.580391] PPP generic driver version 2.4.2
[ 2.580520] PPP BSD Compression module registered
[ 2.580527] PPP Deflate Compression module registered
[ 2.580545] PPP MPPE Compression module registered
[ 2.580556] NET: Registered protocol family 24
[ 2.580604] usbcore: registered new interface driver r8152
[ 2.580639] usbcore: registered new interface driver asix
[ 2.580666] usbcore: registered new interface driver ax88179_178a
[ 2.580693] usbcore: registered new interface driver cdc_ether
[ 2.580730] usbcore: registered new interface driver smsc95xx
[ 2.580790] usbcore: registered new interface driver net1080
[ 2.580816] usbcore: registered new interface driver cdc_subset
[ 2.580842] usbcore: registered new interface driver zaurus
[ 2.580888] usbcore: registered new interface driver cdc_ncm
[ 2.581130] Wake76 for irq=199
[ 2.581133] Wake77 for irq=199
[ 2.581135] Wake78 for irq=199
[ 2.581137] Wake79 for irq=199
[ 2.581139] Wake80 for irq=199
[ 2.581141] Wake81 for irq=199
[ 2.581142] Wake82 for irq=199
[ 2.581192] tegra-xotg xotg: usb2 phy is not available yet
[ 2.581884] usbcore: registered new interface driver usb-storage
[ 2.581960] usbcore: registered new interface driver usbserial
[ 2.581984] usbcore: registered new interface driver ftdi_sio
[ 2.582004] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.582030] usbcore: registered new interface driver option
[ 2.582048] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.582072] usbcore: registered new interface driver pl2303
[ 2.582089] usbserial: USB Serial support registered for pl2303
[ 2.582273] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.583388] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c 82 4b
[ 2.583944] libphy: dwc_phy: probed
[ 2.584788] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.647390] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 2.647536] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.711685] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.713844] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.713857] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.713995] i2c /dev entries driver
[ 2.714969] gspca_main: v2.14.0 registered
[ 2.715014] usbcore: registered new interface driver gspca_zc3xx
[ 2.715251] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.716944] FAN dev name: pwm-fan
[ 2.716987] FAN:gpio request success.
[ 2.716993] FAN: can't find tach_gpio
[ 2.717015] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.717155] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 2.717158] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.717162] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.717452] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.717455] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.717458] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.717461] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.717464] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.717467] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.717469] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.717472] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.717475] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.717478] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.718205] device-mapper: uevent: version 1.0.3
[ 2.718384] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.718694] sdhci: Secure Digital Host Controller Interface driver
[ 2.718695] sdhci: Copyright(c) Pierre Ossman
[ 2.718699] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.718959] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.719223] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.719438] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.719866] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.719980] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.721353] usbcore: registered new interface driver usbhid
[ 2.721354] usbhid: USB HID core driver
[ 2.724713] nvadsp 2993000.adsp: in probe()...
[ 2.726116] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.726147] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.726381] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.737179] Denver: backdoor interface is NOT available.
[ 2.739237] coresight-tmc 8030000.etf: TMC initialized
[ 2.741411] coresight-tmc 8050000.etr: TMC initialized
[ 2.741877] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.742475] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.743009] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.743510] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.743964] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.744651] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.745277] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.745911] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.746546] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.746575] Module initialized successfully
[ 2.750247] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.751866] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.752128] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.752478] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.752525] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.752569] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.752612] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.752651] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.752690] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.752732] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.752871] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.752873] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.753530] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.753533] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.753535] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.753538] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.753541] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.753543] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.753545] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.753575] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.758277] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.759210] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.759312] camchar: rtcpu character device driver loaded
[ 2.764284] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.764678] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.764912] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.765533] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.765565] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.765593] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.765626] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.765654] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.765683] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.765710] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.765740] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.765769] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.765796] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.765824] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.765853] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.765882] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.765911] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.765939] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.765988] **** A57 ECC: Enabled
[ 2.765991] tegra18_a57_serr_init: on CPU 0 a A57 Core
[ 2.766144] parse_throttle_dt_data: Num cap clks = 4
[ 2.766147] parse_throttle_dt_data: clk=mcpu type=1
[ 2.766149] parse_throttle_dt_data: clk=bcpu type=2
[ 2.766157] parse_throttle_dt_data: clk=gpu type=4
[ 2.766159] parse_throttle_dt_data: clk=emc type=3
[ 2.766716] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.766818] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 2.770152] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.770372] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.770562] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.770791] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.774654] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.810373] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.810598] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.810646] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.810720] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.810761] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.811031] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.844367] mmc0: MAN_BKOPS_EN bit is not set
[ 2.851622] mmc0: Skipping tuning since strobe enabled
[ 2.854408] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 2.854445] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.859130] mmc0: periodic cache flush enabled
[ 2.859138] mmc0: new HS400 MMC card at address 0001
[ 2.859402] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.859521] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.859633] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.859742] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.860857] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 2.906396] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.906852] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.105167] mmc1 tuning done saved tap delay=66
[ 3.105171] mmc1: hw tuning done ...
[ 3.105178] mmc1: tuning_window[0]: 0xffffffff
[ 3.105185] mmc1: tuning_window[1]: 0xffffe3ff
[ 3.105190] mmc1: tuning_window[2]: 0xf1ffffff
[ 3.105196] mmc1: tuning_window[3]: 0x7fffffff
[ 3.105201] mmc1: tuning_window[4]: 0x0
[ 3.105206] mmc1: tuning_window[5]: 0x0
[ 3.105242] mmc1: tuning_window[6]: 0x0
[ 3.105248] mmc1: tuning_window[7]: 0x0
[ 3.105252] sdhci: Tap value: 66 | Trim value: 5
[ 3.105256] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.111924] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.111972] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.228287] tegradc 15210000.nvdisplay: fb registered
[ 4.234840] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 4.241150] PD DISP0 index2 UP
[ 4.246514] PD DISP1 index3 UP
[ 4.251090] PD DISP2 index4 UP
[ 4.257353] Parent Clock set for DC plld2
[ 4.266545] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 4.294179] tegra-se-nvhost 15810000.se: initialized
[ 4.301765] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.310406] tegra-se-nvhost 15820000.se: initialized
[ 4.317881] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.326476] tegra-se-nvhost 15830000.se: initialized
[ 4.333838] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.342463] tegra-se-nvhost 15840000.se: initialized
[ 4.349946] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.361648] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.373497] cpufreq: platform driver Initialization: pass
[ 4.380625] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ 4.388734] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.396361] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.407481] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.418430] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x32b897
[ 4.426474] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.433420] Unsupported HDMI VIC 64, ignoring
[ 4.440830] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.441602] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 4.442523] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.444957] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.445095] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.446236] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.446240] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.449662] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.450723] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.462445] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.463533] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.463985] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.464503] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.464511] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.464533] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.465487] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.465488] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.466228] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.477285] OPE platform probe
[ 4.477398] OPE platform probe successful
[ 4.493108] tegra-snd-t186ref-mobile-rt565x sound: 4: XXXX Probe defered until codec is inited
[ 4.493490] GACT probability NOT on
[ 4.493500] Mirror/redirect action on
[ 4.493513] u32 classifier
[ 4.493514] Actions configured
[ 4.493540] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.494255] ipip: IPv4 over IPv4 tunneling driver
[ 4.494609] Initializing XFRM netlink socket
[ 4.494968] NET: Registered protocol family 10
[ 4.495665] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.495722] NET: Registered protocol family 17
[ 4.495735] NET: Registered protocol family 15
[ 4.495776] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.495787] 8021q: 802.1Q VLAN Support v1.8
[ 4.496069] Registered cp15_barrier emulation handler
[ 4.496086] Registered setend emulation handler
[ 4.497550] registered taskstats version 1
[ 4.501078] isp 15600000.isp: initialized
[ 4.504723] nvcsi 150c0000.nvcsi: initialized
[ 4.506023] GPIO line 201 (isp-reset-n) hogged as output/low
[ 4.506294] GPIO line 202 (isp-standby) hogged as output/high
[ 4.506569] GPIO line 205 (moosejaw-south-uart-reset) hogged as output/high
[ 4.506839] GPIO line 215 (moosejaw_south_led) hogged as output/high
[ 4.506910] gpiochip_add_data: registered GPIOs 200 to 215 on device: tca9539
[ 4.518119] Wake76 for irq=199
[ 4.518120] Wake77 for irq=199
[ 4.518121] Wake78 for irq=199
[ 4.518122] Wake79 for irq=199
[ 4.518122] Wake80 for irq=199
[ 4.518123] Wake81 for irq=199
[ 4.518124] Wake82 for irq=199
[ 4.518399] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.518400] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.542436] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.542437] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.542688] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.543386] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.543953] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.544445] gpio tegra-gpio wake12 for gpio=77(J:5)
[ 4.545032] LDO1: 1175 <--> 1200 mV at 1200 mV
[ 4.570997] gpio tegra-gpio wake12 for gpio=77(J:5)
[ 4.599124] MICVDD: 900 <--> 3300 mV at 2500 mV
[ 4.599152] Adding alias for supply MICVDD,(null) -> MICVDD,spi3.0
[ 4.599400] Adding alias for supply MICVDD,(null) -> MICVDD,spi3.0
[ 4.599401] Adding alias for supply DBVDD2,(null) -> DBVDD2,spi3.0
[ 4.599403] Adding alias for supply DBVDD3,(null) -> DBVDD3,spi3.0
[ 4.599404] Adding alias for supply CPVDD,(null) -> CPVDD,spi3.0
[ 4.599405] Adding alias for supply SPKVDDL,(null) -> SPKVDDL,spi3.0
[ 4.599406] Adding alias for supply SPKVDDR,(null) -> SPKVDDR,spi3.0
[ 4.600396] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.600431] tegra-xotg xotg: update_id_state: ID floating
[ 4.600435] tegra-xotg xotg: update_vbus_state: VBUS detected
[ 4.600449] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.602008] tegra-xotg xotg: otg: gadget gadget registered
[ 4.602010] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 4.602012] tegra-xotg xotg: otg: host not registered yet
[ 4.602013] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.602052] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.602453] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.674408] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 4.674412] tegra-usb-cd usb_cd: set current 0ma
[ 4.674419] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.675117] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.675119] tegra-xudc-new 3550000.xudc: device mode on
[ 6.453620] tegra-snd-t186ref-mobile-rt565x sound: 3: XXXX Probe defered until codec is inited
[ 6.454249] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 6.454314] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 6.454418] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 6.454618] input: gpio-keys as /devices/gpio-keys/input/input2
[ 6.454882] tegra-snd-t186ref-mobile-rt565x sound: 2: XXXX Probe defered until codec is inited
[ 6.487926] tegra_rtc c2a0000.rtc: setting system clock to 2017-09-11 23:49:19 UTC (1505173759)
[ 6.517668] bpmp: mounted debugfs mirror
[ 6.518118] [dram-timers] DRAM derating cdev registered.
[ 6.521786] spmic-ldo0: disabling
[ 6.521970] spmic-ldo1: disabling
[ 6.522114] en-vdd-sd: disabling
[ 6.522116] en-vdd-cam: disabling
[ 6.522118] vdd-usb0-5v: disabling
[ 6.522119] vdd-usb1-5v: disabling
[ 6.522122] en-vdd-disp-3v3: disabling
[ 6.522124] en-mdm-pwr-3v7: disabling
[ 6.522125] en-vdd-disp-1v8: disabling
[ 6.522128] en-vdd-cam-1v2: disabling
[ 6.522129] vdd-fan: disabling
[ 6.522131] vdd-3v3: disabling
[ 6.522133] en-vdd-vcm-2v8: disabling
[ 6.522134] vdd-usb2-5v: disabling
[ 6.522136] vdd-sys-bl: disabling
[ 6.522138] LDO1: disabling
[ 6.528129] ALSA device list:
[ 6.528175] #0: tegra-hda at 0x3518000 irq 400
[ 6.529392] tegra-vi4 15700000.vi: initialized
[ 6.531092] tegra-snd-t186ref-mobile-rt565x sound: 1: XXXX Probe defered until codec is inited
[ 12.086367] random: nonblocking pool is initialized
[ 12.283615] tegradc 15210000.nvdisplay: hdmi: plugged
[ 12.347189] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 12.354039] EXT4-fs (mmcblk0p1): recovery complete
[ 12.365231] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.374797] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 12.384894] devtmpfs: mounted
[ 12.389670] Freeing unused kernel memory: 1160K (ffffffc0011f1000 - ffffffc001313000)
[ 12.399178] Freeing alternatives memory: 96K (ffffffc001313000 - ffffffc00132b000)
[ 12.467144] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 12.487238] systemd[1]: Detected architecture arm64.
[ 12.505590] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 12.623194] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.634774] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 12.644824] systemd[1]: Listening on Journal Audit Socket.
[ 12.654040] systemd[1]: Reached target Encrypted Volumes.
[ 12.663264] systemd[1]: Listening on udev Control Socket.
[ 12.672493] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 12.684833] systemd[1]: Listening on Syslog Socket.
[ 12.692661] systemd[1]: Reached target User and Group Name Lookups.
[ 12.701836] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 12.711446] systemd[1]: Reached target Swap.
[ 12.718794] systemd[1]: Created slice System Slice.
[ 12.726758] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.736039] systemd[1]: Listening on LVM2 poll daemon socket.
[ 12.745065] systemd[1]: Reached target Remote File Systems (Pre).
[ 12.757901] systemd[1]: Reached target Remote File Systems.
[ 12.766518] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.775438] systemd[1]: Listening on udev Kernel Socket.
[ 12.783846] systemd[1]: Created slice User and Session Slice.
[ 12.792640] systemd[1]: Reached target Slices.
[ 12.800230] systemd[1]: Listening on Journal Socket.
[ 12.813640] systemd[1]: Starting Load Kernel Modules...
[ 12.823590] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 12.838883] systemd[1]: Starting Set console keymap...
[ 12.849003] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.860664] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 12.871982] systemd[1]: Mounting Debug File System...
[ 12.881809] systemd[1]: Started Braille Device Support.
[ 12.892655] systemd[1]: Starting Journal Service...
[ 12.903658] systemd[1]: Mounted Debug File System.
[ 12.912541] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 12.924203] systemd[1]: Failed to start Load Kernel Modules.
[ 12.935587] systemd[1]: systemd-modules-load.service: Unit entered failed state.
[ 12.944776] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
[ 12.954739] systemd[1]: Started Set console keymap.
[ 12.963832] systemd[1]: Started Remount Root and Kernel File Systems.
[ 12.974439] systemd[1]: Started Create Static Device Nodes in /dev.
[ 12.985863] systemd[1]: Started Journal Service.
[ 13.063572] systemd-journald[278]: Received request to flush runtime journal from PID 1
[ 13.103329] cfg80211: World regulatory domain updated:
[ 13.111234] cfg80211: DFS Master region: unset
[ 13.115678] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 13.132710] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.143335] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.153691] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.164066] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 13.175858] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 13.187690] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 13.198107] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.208370] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 13.302007] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 14.312919] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 14.314382] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 14.314396] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 14.315197] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 14.315218] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 14.315332] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 14.315335] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.315338] usb usb1: Product: xHCI Host Controller
[ 14.315340] usb usb1: Manufacturer: Linux 4.4.38 xhci-hcd
[ 14.315341] usb usb1: SerialNumber: 3530000.xhci
[ 14.315608] hub 1-0:1.0: USB hub found
[ 14.315629] hub 1-0:1.0: 4 ports detected
[ 14.315993] tegra-snd-t186ref-mobile-rt565x sound: 0: XXXX Probe defered until codec is inited
[ 14.330495] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 14.330502] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 14.330662] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 14.330665] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.330667] usb usb2: Product: xHCI Host Controller
[ 14.330669] usb usb2: Manufacturer: Linux 4.4.38 xhci-hcd
[ 14.330670] usb usb2: SerialNumber: 3530000.xhci
[ 14.330907] hub 2-0:1.0: USB hub found
[ 14.330925] hub 2-0:1.0: 3 ports detected
[ 14.331273] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 14.331472] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 14.388978] MICVDD: supplied by vdd-1v8-ap
[ 14.579374] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 14.579531] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 14.579624] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 14.579718] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 14.579809] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 14.579898] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 14.580008] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 14.580098] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 14.580189] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 14.580283] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 14.580375] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 14.580466] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 14.580556] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 14.580645] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 14.580737] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 14.580847] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 14.580954] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 14.581046] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 14.581140] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 14.581230] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 14.585047] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 14.585159] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 14.585192] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 14.585218] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 14.626363] usb 1-2: new low-speed USB device number 2 using xhci-tegra
[ 14.680240] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input3
[ 14.680955] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "wm5110-aif1" registered
[ 14.762074] usb 1-2: feature bit otg_vbus_off set
[ 14.762079] usb 1-2: New USB device found, idVendor=04b3, idProduct=3025
[ 14.762081] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 14.762083] usb 1-2: Product: USB NetVista Full Width Keyboard.
[ 14.762085] usb 1-2: Manufacturer: LITE-ON Technology
[ 14.762342] usb 1-2: ep 0x81 - rounding interval to 128 microframes, ep desc says 192 microframes
[ 14.762676] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 14.769090] input: LITE-ON Technology USB NetVista Full Width Keyboard. as /devices/3530000.xhci/usb1/1-2/1-2:1.0/0003:04B3:3025.0001/input/input4
[ 14.822579] hid-generic 0003:04B3:3025.0001: input,hidraw0: USB HID v1.10 Keyboard [LITE-ON Technology USB NetVista Full Width Keyboard.] on usb-3530000.xhci-2/input0
[ 15.978279] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 15.978283] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 17.832424] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.842569] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 17.851608] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.005157] gk20a 17000000.gp10b: railgate is disabled.
[ 19.095156] CPU1: shutdown
[ 19.097871] psci: CPU1 killed.
[ 19.122370] CPU2: shutdown
[ 19.125120] psci: CPU2 killed.
Ubuntu 16.04.3 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: nvidia (automatic login)
Last login: Mon Sep 11 22:02:08 UTC 2017 from 10.63.72.236 on pts/8
[ 19.234640] PD DISP2 index4 DOWN
[ 19.234810] PD DISP1 index3 DOWN
[ 19.234886] PD DISP0 index2 DOWN
Welcome to Ubuntu 16.04.3 LTS (GNU/Linux 4.4.38 aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
57 packages can be updated.
0 updates are security updates.
nvidia@tegra-ubuntu:~$ [ 19.245363] PD DISP0 index2 UP
[ 19.246338] PD DISP1 index3 UP
[ 19.248533] PD DISP2 index4 UP
[ 19.250392] Parent Clock set for DC plld2
[ 19.251813] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 22.410375] PD DISP2 index4 DOWN
[ 22.410546] PD DISP1 index3 DOWN
[ 22.410627] PD DISP0 index2 DOWN
[ 22.421052] PD DISP0 index2 UP
[ 22.421881] PD DISP1 index3 UP
[ 22.421960] PD DISP2 index4 UP
[ 22.423424] Parent Clock set for DC plld2
[ 22.424785] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 23.544587] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 23.554025] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
