However, tensorflow is not able to detect the Jetson GPU.
print("Num GPUs Available: ", len(tf.config.experimental.list_physical_devices(‘GPU’)))
Num GPUs Available: 0
I have made sure that there is just one version of TF installed. I have also tried versions 2.17, 2.16, 2.15 for JetPack 6.0. Any idea how to fix this?
Update: I reinstalled 2.15 from scratch again. This time, the GPU is detected, but I get these warnings.
import tensorflow as tf
2024-07-04 08:30:28.028028: E external/local_xla/xla/stream_executor/cuda/cuda_dnn.cc:9373] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered
2024-07-04 08:30:28.028148: E external/local_xla/xla/stream_executor/cuda/cuda_fft.cc:607] Unable to register cuFFT factory: Attempting to register factory for plugin cuFFT when one has already been registered
2024-07-04 08:30:28.030501: E external/local_xla/xla/stream_executor/cuda/cuda_blas.cc:1534] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered
does this mean tensorflow will not be able to use cuDNN and cuBLAS?
