I recently purchased NV Xavier NX dev kit. I installed the SD card image from (https://developer.nvidia.com/jetson-nx-developer-kit-sd-card-image). It boots fine and I’m able to run the sample CUDA and tensorRT code.
For installing Tensorflow, I followed instructions from (Installing TensorFlow for Jetson Platform :: NVIDIA Deep Learning Frameworks Documentation)
The tensorflow fails because during compilation of grpcio wheel it encounters unknown reference to __wrap_memcpy.
The grpcio pkg it picks up is grpcio-1.31.0.tar.gz
I’ve tried the following:
- Update setuptools (using version 50.0.0)
- Update pip3 (using 20.2.2)
Any suggestions on what the issue might be and how to fix or workaround it?
There is an issue in grpcio:
Currently, please downgrade setuptools to 49.6.0 and it should work.
