I installed Tensorflow using this guide
Installing TensorFlow for Jetson Platform
Using Jetpack version 5.1, Please find attached screenshot
Could you share the package version you installed with us?
>>> tf.__version__
We have verified the 2.11.0+nv23.01 package on Orin+JetPack 5.1
TensorFlow can detect GPU correctly.
>>> tf.config.list_physical_devices('GPU')
[PhysicalDevice(name='/physical_device:GPU:0', device_type='GPU')]
Hi
It’s 2.11 and nv23.01
Do you have debugging tips to find out what’s wrong? I have no idea how to proceed with this on Orin
Do you get the output of tf.__version__?
Could you share it with us first?
A common cause is that there are multiple TensorFlow installed, and some are not \built with CUDA.
I removed all pip packages and installed it again. it is working now. Thank you for your help.
Good to know this.
Thanks for the update.
